jazzed Samba Member
Joined: August 03, 2002 Posts: 628 Location: Eugene, OR
Posted: Thu Aug 04, 2011 3:03 pm Post subject: Fuel Pump Woes |
Went out to start the '66 today and it wouldn't start. Plenty of gas, but I noticed none in the fuel filter. Took off both lines from the fuel pump and determined the line to the filter is clear, and that there's plenty of gas flowing through the line from the tank. Could this be anything but the fuel pump? I suppose I could measure the pushrod, but that seems pretty unlikely, no? The gasket is pretty funky, but it wasn't leaking. If there's anything else I should be checking, would appreciate input. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51145 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Aug 04, 2011 3:44 pm Post subject: |
Put the end of the line from the pump to carb in a soda bottle and crank for 15-30 seconds, if it pumps a fair bit of gas into the bottle suspect the needle and seat in the carb, it may be sticking shut. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
jazzed Samba Member
Posted: Thu Aug 04, 2011 3:54 pm Post subject: |
busdaddy wrote: |
Put the end of the line from the pump to carb in a soda bottle and crank for 15-30 seconds, if it pumps a fair bit of gas into the bottle suspect the needle and seat in the carb, it may be sticking shut. |
Thanks. I've got dual carbs and I know that fuel isn't even going through the filter, much less into the carbs. |
Split 66' Samba Member
Joined: October 07, 2010 Posts: 1256 Location: Bay Area, California
Posted: Thu Aug 04, 2011 4:24 pm Post subject: |
I put my fuel filter right below the tank and behind the firewall. Do you have your filter between the fuel pump and the carbs? Do you have a fuel pressure regulator for the dual carbs? _________________ "OG = Original German" -- TheSamba.com dictionary |
jazzed Samba Member
Posted: Thu Aug 04, 2011 6:15 pm Post subject: |
Split 66' wrote: |
I put my fuel filter right below the tank and behind the firewall. Do you have your filter between the fuel pump and the carbs? Do you have a fuel pressure regulator for the dual carbs? |
My fuel filter is about 6" above the fuel pump, between the carbs. Not sure if I have a fuel pressure regulator or not. What would it look like? |
kombisutra Samba Member
Joined: October 02, 2003 Posts: 4127 Location: San Anselmo, 10 miles North Of San Francisco
Posted: Thu Aug 04, 2011 7:15 pm Post subject: |
If it's been a while since the bus has run, the pump -unlikely but it happened to me last month- may need to be primed. Even though my pump was getting fuel to the bottom of the pump, the pump wouldn't suck it up until I took the pump off and primed it on the bench. Works great now. |
Posted: Thu Aug 04, 2011 7:23 pm Post subject: |
You can't miss seeing the regulator, if you had one; doesn't sound like you do.
Try what busdaddy recommended, if you are getting nothing out of the output side of the pump, and you are certain that gas is flowing correctly into the input side of the pump, you must have a busted diaphragm, or the lever in there broke, or maybe one of the e-clips came off.
Does your pump screw together, or is it sealed? _________________ "OG = Original German" -- TheSamba.com dictionary |
jazzed Samba Member
Posted: Thu Aug 04, 2011 9:09 pm Post subject: |
Split 66' wrote: |
Does your pump screw together, or is it sealed? |
It's sealed. The priming idea seems well worth a shot, Kombisutra. |
Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1855 Location: S>E>Alabama
Posted: Fri Aug 05, 2011 3:40 am Post subject: Fuel pump |
Change over to an electric pump from CB and all of your troubles will go away. It has a built in filter, quiet and is regulated.ther are two versions available , one [email protected] and one @5 or so.If you are running cads you will still need the Holley fuel regulator to get down to 1.75 sweet spot that Kaddies loke. Just my .02 _________________ 71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse |
