Ktk833 Samba Member
Joined: April 04, 2017 Posts: 28 Location: Nairobi, Kenya
Posted: Fri May 03, 2019 5:32 am Post subject: Re: 1 - 2 - 4 - 3 Firing Order 009 Distributor |
Also to add, I did valve clearance with a 0.005 in but let it more loose to compensate for the lack of a 0.006in gauge. I saw in a diffeeent manual that the gap to 1800cc and other years have the gap at 0.008in. I don't know much about the history (year) - it doesn't have the engine no (genuine as it looks rather own stamped)...but as mentioned, it is a 2.0ltr with solid lifters. |
Ktk833 Samba Member
Posted: Sat May 04, 2019 8:06 am Post subject: Re: 1 - 2 - 4 - 3 Firing Order 009 Distributor |
djkeev wrote: |
Ktk833 wrote: |
Hi.
I was glad to find this post. I have a type 4 engine. I do not have any prior history other than it has had problems since its overhaul.............
Please assist. |
I think this is a HUGE overlooked clue.
"it has had problems since its overhaul"
When assembling an engine there are certain procedures that MUST BE FOLLOWED.
#1 is to properly align the gear on the crank with the gear on the camshaft.
Oh, they will mesh at any point on their circumference but the engine will only run properly at but ONE point on their circumference.
If the cam and crank gear are not in properly syncronization, the engine will NEVER run properly, if at all.
Now, lets look at the camshaft drive gear.
It has an offset slot in the top that meshs with the distributor drive tooth.
The distributor gear can be installed in any pisition and not affect if the engine runs ......... PROVIDED that the plug wires are put in the proper spot and in the proper order.
If the distributor gear isn't installed as per factory specs, the marking (notch) on the distributor body will mean nothing, just ignore the mark and install the wires in the proper spots on the cap.
What are the proper spots?
You need to rotate the engine to Top Dead Center #1 cylinder. Wherever the rotor is pointing? Install the cap noting where the rotor is pointing in relation to the cap......... THAT is the #1 Spot on the cap, put your #1 wire there.
A problem....... both #1 and #3 share the same crank matk / case seam as their Top Dead Center. You've got a 50/50 chance of being correct. You can increase your idds to 100% by removing the valve cover on #1 cylinder and see if the rockers are both at rest. A little bit of wiggle and at the same angle.
If one is depressed it will be tight. If it is, rotate the engine one full revolution and check the rockers again. They should both be at rest now.
Once #1 TDC is verified, install the other wires 1432 counter clockwise. It will NOT be any other firing order.
Dave |
Hi.
Have you (or someone else) ever made that error of mismatching the cam & crank gears? I wonder- how would the engine run (say it was a gears-tooth-miss)? I'm really trying to establish if I will have to split the block. |
fes Samba Member
Joined: January 26, 2011 Posts: 999 Location: Prince Edward Island
Posted: Sat May 04, 2019 8:41 am Post subject: Re: 1 - 2 - 4 - 3 Firing Order 009 Distributor |
If the gears were misaligned the engine would run like crap as the lobes of the cam would not be in the right position to engage the lifters at the correct time..
I can't say whether or not this is your problem but i doubt it..however if your rings were not staggered then what else was missed during the build?
It sounds to me you have timing problems..
Find TDC..(make sure you are at top dead center on #1 not #3) note the position of the rotor and hook #1 up there and connect wires 4-3-2 clockwise at the cap..
Have you checked the points?..have a dwell meter?
Have a timing light?
If the points are good,.16,or 45-50 degrees dwell, and the rubbing block is fine, Static time to 0 using a test light, by way of rotating the pulley to O on the timing scale, ground the clip of the tester light on a suitable ground, then touching the light to the green wire on the coil.. rotate the distributor until the light comes on..
Snug the pinch bolt and start the engine..it's an .009 so you shouldn't have any hoses to plug..
Using the timing light, bring the RPM up to 3000 and set the timing to 28 degrees BTDC..
Wherever the timing lands at idle is where it's going to be timed..
This method is the only way to time your engine..Your manual might say to time at 5 ATDC, but this will likely not be your case, you have non stock carbs, and a distributor that VW had never intended for that engine..
Good luck
-Matt _________________ '68 Campmobile-Pedro
'15 Golf-Stella Blau
'56 Oval-The Turd (for now) |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Sun May 05, 2019 10:44 am Post subject: Re: 1 - 2 - 4 - 3 Firing Order 009 Distributor |
Ktk833 wrote: |
djkeev wrote: |
Ktk833 wrote: |
Hi.
Please assist. |
Dave |
Hi.
I once bought a used Ford that had just recently had some major engine overhaul work done.
Shortly afterwards on a trip about 100 miles from home , the engine suddenly developed a serious knock and then a piston found its way through the side of the engine block.
I had a good used complete engine installed, ... and not long after that the knock suddenly returned again.
This time I was close enough to home to be able to shut it down and not run it again before any serious engine damage had occurred.
After a good deal of head scratching, I discovered that the used engine was not entirely complete and the distributor from the original engine had been reused.
That distributor apparently had a faulty electronic ignition module inside of it which was ultimately responsible for randomly causing a severe detonation condition that destroyed the original engine ... twice ... and nearly destroyed the used engine as well.
After replacing that relatively inexpensive ignition module, the car ran fine for several years.
I didn't look back in this thread to see if the stock points are being used, or if they have been replaced by a Pertronix or equivalent.
If an electronic ignition module has been installed, it it possible that it may be faulty.
If not, then it also may be possible that something else inside the distributor is not functioning properly. |
Ktk833 Samba Member
Posted: Tue May 07, 2019 7:45 am Post subject: Re: 1 - 2 - 4 - 3 Firing Order 009 Distributor |
I agree with you KGcoupe...I am beginning to suspect the distributor.
Fes, a question- how does one measure dwell angle? I thought by just doing the points gap, that takes care of all the rest...kindly enlighten me.
Thanks.
As an update, I did split the block...the timing marks were in order. I'm just about reassembling it back and should be ready in a night or 2 (not rushing just to be certain it all mates up well...hoping to get a better response). |
Ktk833 Samba Member
Posted: Thu May 09, 2019 11:30 am Post subject: Re: 1 - 2 - 4 - 3 Firing Order 009 Distributor |
Hi.
Someone please enlighten me about the pistons and piston rings.
I've just realized that as much as all the pistons are of 93.89mm, they are of 2 different pairs - one pair has compression ring slots larger than the other pair... and happens to be like the previous guy bought a set of rings and fit the same on all pistons...so a pair has its rings awfully sagging. What to do??? Get another set of thicker rings to fit onto the 2 pairs??? Each pair is positioned at 1/4 and 2/3 |
fes Samba Member
Posted: Fri May 10, 2019 12:46 pm Post subject: Re: 1 - 2 - 4 - 3 Firing Order 009 Distributor |
You measure dwell with a dwell meter, It takes a positive and negative connection to the battery, A "C" clamp that attaches to your Number one spark plug wire and a green connector that hooks up to the negative on the coil..You can buy them pretty cheap on Ebay and most have an RPM reader on them as well.. You set with .16 feeler gauge first to get you in range, then with dwell meter, you want to be about 45-50 degrees..this tells you if you may need to open or close the gap slightly to achieve near perfection.
Your second question about piston sizes and rings etc, It sounds to me that you have a 2l, a type 4 engine that you stated in this thread.
What vehicle is this engine in? A bus or a Ghia or something else? I ask because there's not a lot of type 4 activity on this thread as most of us are running the type1 engine or some variation..
You may consider starting a new thread on the Performance/Engines etc forum, or bay window..
In the meantime, you need to know what style 94mm pistons you have and possibly the brand..they don't sound like stock, or the ring set you have is not matched..
Why did you go ahead and split the case? You're in a whole new ball game now..much careful inspection and measuring to do..did you remove the crank and cam to inspect the bearings?..did you pull the lifters before splitting the case and inspect them as well as the pushrods? Are they hydraulic or solid? Did you keep them organized and matched in the sequence you removed them?
Just seems like a lot of unnecessary work to confirm the alignment of the dots on the cam and crank gears, before you really even figured out the firing order..
I wish you luck all the same
Ktk833 Samba Member
Posted: Fri May 10, 2019 4:39 pm Post subject: Re: 1 - 2 - 4 - 3 Firing Order 009 Distributor |
Hi Matt.
Thank you for the info about the dwell meter. I'll plan to invest in one. I will consider the new thread...thanks for that too.
Why I split the case...I chose to start my process from in, eliminating all possibilities as I inspected the state of the engine...now that I had plenty of issues and wouldn't want to have it as my trend all the way that I desire to get the most out of this engine.
I did follow the book- keeping things organized to have them back exactly where they came from. I had earlier inspected the lifters and confirmed they were solid type...this was before I did my valve clearance the very first time.
I did inspect things inside and all was quite ok...so now can go narrowing down with the assistance of the information like which you are helping me with.
Thank you once again. I am confident, with the help of guys like you, the engine will definitely run and be reliable.
Regards.
PAT |
Ktk833 Samba Member
Posted: Sun Jun 28, 2020 2:03 am Post subject: Re: 1 - 2 - 4 - 3 Firing Order 009 Distributor |
Hi.
Some update on the engine- I reassembled, was able to fit Zenith carbs and synchronize them. The engine runs fairly well...yet I expect more off the bigger engine.
Where I am at now is on ignition timing... it seems the engine runs better on a slight retard.
Would anyone have resources on the different ignition timing system for this type of engines? On a manual I was reading online (unfortunately I can't trace the same), it spoke of a 15 degrees retard for the engine. Others I watch say 7.5 BTDC
PLEASE HELPWITH LEADS TO HELPFUL MATERIAL.
Thanks. |
A-Wild Samba Member
Joined: January 14, 2013 Posts: 48 Location: Edmond, OK
Posted: Sun Jan 16, 2022 8:13 pm Post subject: Re: 1 - 2 - 4 - 3 Firing Order 009 Distributor |
following _________________ 1971 Clementine Orange VW Convertible
1971 Karmann Ghia Coupe - Bahia Red |
