vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Thu Aug 08, 2013 11:25 pm Post subject: |
Max Welton wrote: |
I say it was a cooincidence. Running lean at idle under no load for a few minutes isn't going to kill anything.
Max |
I agree, there is no way it would die like that at idle, even at WOT it would take longer than 5 sec to kill. |
vlad01 Samba Member
Posted: Thu Aug 08, 2013 11:29 pm Post subject: |
supaninja wrote: |
I'm with max, there is no way the motor popped while idling at no load lean, hell when my fuel pump clogged up 50 miles from home I was WOT at 18.0+ AFR's... a lot, and the motor is still fine. |
you were no were near stoich, it wouldn't do damage. |
jarred Samba Member
Posted: Sat Aug 10, 2013 7:08 am Post subject: |
I'll post high rpm testing with a scope soon, probably next week. With the chip manufacturer's reference wheel tooth geometry the sensor is good to 15 kHz (cycles/second) which translates to 900,000 rpm (cycles/minute) divided by triggers on the wheel, or 1,800,000 rpm/triggers with the 1:2 reduction in the distributor. But, with that tooth geometry I can only get 44 teeth in the distributor, or 22 triggers per crank rotation. So that makes for ~81,000 rpm bandwidth. Fast enough? 22 is obviously less than the standard 36-1 wheel, but I know people have run type 4 engines on the 8 holes in the backside of the flywheel. In discussion with the chip manufacturer there shouldn't be any problem in bumping that up to 26 to 32 per crank rev. The prototype only has 16 per crank rev because I CNC machined it with a 1/8" carbide bit. The final version will be water jet which can cut the small geometry.
The advance mechanism in a distributor only rotates the points plate. In my setup the trigger is mounted on the shaft so there wouldn't be any way to use the distributor's mechanical or vacuum advance. You wouldn't want to anyway, the advantage of programmable spark is the ability to nail the advance curve for maximum power. |
jarred Samba Member
piledriver Samba Member
Joined: June 05, 2003 Posts: 184 Location: In my bunker, beside my wall. (Howe, Tx)
Posted: Sun Sep 15, 2013 10:36 am Post subject: |
I'm running with 6 "teeth" (pressure plate bolt through holes) on the flywheel again: If you have a solid signal it's no issue except perhaps at cranking RPM, and not much then. (equivalent to 12 in the distributor)
You will be just fine. _________________ Current daily driver---73 Square, 1.8L T4, MS3+MS3X/sequential w/LS2 coils 80 miles/day. |
jarred Samba Member
Posted: Sun Sep 15, 2013 8:10 pm Post subject: |
I think I've run across your flywheel setup and considered doing it myself. But I own cars with both type 1 and 4 engines so I thought this could work for all the above. Yours is running fine? The 16 tooth was just a prototype, the smallest I can machine with given the end mill I had at the time. The Hall sensor can pick up 3 mm teeth before the pulse width begins to decrease. So, I'm going to try ~26 tooth (13 on crank equivalent) which is about as small as I care to machine. Could be water jet cut instead, but I was quoted a $200 minimum for about 12 pieces. |
Posted: Mon Sep 16, 2013 10:55 am Post subject: |
I'd stay with 24 as MS2/3 "generic wheel" code requires even# crank teeth:
It would see 26 in the distributor as 13 on crank as noted, which would need custom wheel code.
I suspect other ecus have similar requirements...
Also, 24-1 would be seen as 12-1 and allow fallback if you lost the sync sensor.
I actually just switched back to the 6/1 setup to make room for an serp belt ac pulley I made from a Ford PS pump unit... I still prefer having the sensors out of harms way. If I ever pull the motor I'll drill 5 more holes to go 12-1.
Setting up the noise filters with a new sensor for my flywheel with an extra balance hole "visible" to the sensor is always interesting. (depends on the sensor) _________________ Current daily driver---73 Square, 1.8L T4, MS3+MS3X/sequential w/LS2 coils 80 miles/day. |
jarred Samba Member
Posted: Tue Sep 17, 2013 7:37 am Post subject: |
Good point, 24-1 it is then. Are you using a VR or Hall effect sensor? |
Posted: Wed Sep 18, 2013 11:37 am Post subject: |
jarred wrote: |
I have used both, but prefer Hall as it is far simpler to use and wire in practice and can be troubleshot with a DVM. I'm using Hall sensors at this time.
If you are looking to production, Hall sensors would be compatible with all versions of MS w/o additional supporting hardware.
It wasn't until V3 boards that MS mainboards had VR amp hardware, and even then I still prefer Hall sensors. _________________ Current daily driver---73 Square, 1.8L T4, MS3+MS3X/sequential w/LS2 coils 80 miles/day. |
jarred Samba Member
Posted: Wed Sep 25, 2013 4:22 pm Post subject: |
Hall is definitely easiest to deal with and what I have been testing so far.
I've setup and run an engine on EDIS which is pretty straightforward. I was just looking over the Tuner Studio MS setup for generic trigger wheels. It seems that you can use any tooth count, not just 24-1, 36-1, etc. as long as the number divided by two is still an even number (even crank triggers). So for the purpose of attaining theoretically more accurate timing (if it matters) 28-1 would be preferred to 24-1 without any drawback. I ask because I'm re-machining the cap to be more like a distributor cap with it being located on the OD of the distributor rather than the ID. I originally used the ID to save on material cost but the ID being part of the casting and not a machined surface is likely to not be very dimensionally accurate... and the 009 distributor for example has been built in 3 countries in at least as many plants. Anyway, the larger cap means I can fit a larger wheel in so i figure I might as well do it. |
Posted: Thu Sep 26, 2013 12:55 am Post subject: |
Above a certain tooth count, I suspect you are nuking rubble.
I'll be trying out a 16-1 wheel in a Mallory Unilite I have had gathering dust for >10 years.
It (or some variant) looks like a VERY easy way to go sequential. Only one sensor required.
You could do the same with a std Bosch distributor, you would probably want a better hall sensor (points location w/custom wheel above it ala compufire, only using a gear tooth sensor w/integral magnet) _________________ Current daily driver---73 Square, 1.8L T4, MS3+MS3X/sequential w/LS2 coils 80 miles/day. |
jarred Samba Member
Posted: Thu Sep 26, 2013 11:52 am Post subject: |
Maybe you didn't look at my youtube vids? I have a hall sensor, machined wheel, and a machined cap that houses the hall sensor which mounts up using the stock b*tch clips. Takes about 3 minutes to install the hard parts and will fit many bosch distributors. Twisting the distributor as normal aligns the wheel with TDC. With a 24-1 wheel I tested it to 10,000 rpm and produces a perfect 5V digital signal on an oscilloscope. I'm just moving on to prototype #2 to fix a couple of things I didn't like in #1. This is a much cheaper solution than scrounging up a Mallory and it uses a modern hall effect sensor: internal magnet for field biasing, automatic gain adjustment, bandwidth to 40 kHz, automotive spec temperature range, zero speed tooth detection, and the ability to switch any voltage up to 24 volts. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Thu Sep 26, 2013 12:29 pm Post subject: |
jarred, what is your car/truck #990 at the Mt. Hood Rally? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
jarred Samba Member
Posted: Fri Sep 27, 2013 7:24 am Post subject: |
I co-own Hintz's old RX7 turbo. The frame/sheet metal that one of the differential mount bolts into is coming apart so we are probably out for the season. |
Posted: Fri Sep 27, 2013 9:28 am Post subject: |
Oh, well it sure looks like Fun! _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Fri Sep 27, 2013 12:13 pm Post subject: |
jarred wrote: |
Maybe you didn't look at my youtube vids? . |
Nope, I'm late to the discussion.
The only reason I'm doing this is to try it, (and I needed the pulley end location for a serpentine AC pulley)
Mallory happened to be easiest/cheapest for me, as I happened to have one handy .
We have a similar discussion going on over at STF where I was suggesting exactly what you apparently are already making, so "two thumbs up".
If you need a beta tester let me know, but it sounds like a slam dunk. _________________ Current daily driver---73 Square, 1.8L T4, MS3+MS3X/sequential w/LS2 coils 80 miles/day. |
jarred Samba Member
Posted: Fri Sep 27, 2013 2:36 pm Post subject: |
Yeah, I think it's a lot easier than all the bracketry on other EDIS style installations. After I test it on a vehicle I'll probably start offering them for sale. What is STF? |
supersuk Samba Member
Joined: December 20, 2010 Posts: 958 Location: Honolulu, Hawaii
ravivos Samba Member
Posted: Sun Dec 29, 2013 8:48 am Post subject: |
Are these trigger wheels still available?
was thinking converting my ongoing build 2021cc T34 engine to MegaJolt... any thoughts?
Ravivos. |
