Brake Help
vanagon91
vanagon91 is offline
PostPosted: Wed Aug 10, 2011 5:52 pm    Post subject: Brake Help Reply with quote
Are the front brakes drums and shoes on a 1958 thru 1964 bug larger than the stock brakes on a 1956? And can they be used on the 56 ? Do you also have to change the wheel cylinders with the shoes and drums? And which backing plate do you have to use? Thanks,Sam
L378
L378 is offline
PostPosted: Wed Aug 10, 2011 6:07 pm    Post subject: Reply with quote
mid 58 & up brakes (front & rear) are not the same as earlier brakes. Basically everything is different. Backing plates, shoes, drums, cylinders. So if you go later you will be changing everything. earlier brake components are available except backing plates which you can pick up from thesamba classifieds or swap meets. Earlier brake parts are a little more expensive but not that much. Only reason I'd go with later brakes would be a bit more stopping power.
Snort
Snort is offline
PostPosted: Wed Aug 10, 2011 6:59 pm    Post subject: Reply with quote
As the previous post says, all the later front brake components are different from the Oval Bug setup, but they fit on the spindles exactly the same, so they are a good improvement. You will then have 22mm wheel cylinders in the front instead of 19mm cylinders.
If you change the fronts to the newer style, then you might want to consider improving the rears as well. If you still have the original rear brakes, you can put your original front wheel cylinders on the rear. Your front 19mm cylinders are same size as the 58-64 rears. They fit exactly the same as the original rear 17mm wheel cylinders and no other changes are needed to backing plates, shoes or drums.
bill may
bill may is offline
PostPosted: Thu Aug 11, 2011 8:37 am    Post subject: Reply with quote
58-64 front and rear brakes can be used complete on 57 and older. notice completebacking plates outwards. if you wish to keep ebrakes coming in from rear then use 57 older ebrake cables by using right on left and left on right,otherwise use 58-64 ebrake cables coming in front as normal 58 onwards.
the 58-64 drums can be machined on lip to clear 57 and older brakes(backing plate rim) as 57 down drums are almost non existant,while 58-64 can be found easily.
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
EMPIImp69
EMPIImp69 is offline
PostPosted: Fri Aug 19, 2011 7:50 am    Post subject: Reply with quote
What about bearings front and rear? We are switching over to 58-64 drums and brakes on a '56 Oval. Will the bearings in the front 58-64 drums be ok on the '56 front spindles? Also will there be any issues using the 58-64 rear drums and backing plates on the '56 as far as the bearings? thanks
1969 Empi Imp #1325
1963 Ragtop Bug
Use this to balance your wide 5 steelies -->
http://www.thesamba.com/vw/classifieds/detail.php?id=1830990
Snort
Snort is offline
PostPosted: Fri Aug 19, 2011 8:16 am    Post subject: Reply with quote
The bearings are the same on the front.
The bearings are the same on the rear. I've only found one minor difference between the Oval and Square rear backing plates worth mentioning as it relates to the bearings, and that is the Square backing plates I measured are slightly thicker than the Oval. While this could cause an issue with the rear wheel bearing O-rings sealing, I doubt you would have trouble with it. It's more important to keep the axle tube and bearing covers matched for the correct year as they have significant design changes. Keep Oval bearing covers with Oval axle tubes, and so on.
bill may
bill may is offline
PostPosted: Fri Aug 19, 2011 11:47 am    Post subject: Reply with quote
read my post above yours.
www.sv2s.com
SBS #100
tisius
tisius is offline
PostPosted: Mon Oct 19, 2015 6:24 am    Post subject: Reply with quote
I'm confused now.
So '58-64' rear backing plates work with split bug (or oval) axle tube and split bug (or oval) bearing covers?
No chance on leaking O-ring there?
I'm asking because I have a split bug axle and split bug bearing cover, and '58-'64 backing plate and '58-'64 drum (I don't have a '58-'64 bearing cover unfortunately).
Should I be OK when using the split (or oval) bearing covers with the '58-'64 rear backing plate? Or do I really need to source '58-'64 bearing covers?
Does anyone have experience with this combination being leak-free?
Thanks in advance for your replies.
drive it like you just robbed the bank
.... if it ain't dutch, it ain't much!
Snort
Snort is offline
PostPosted: Mon Oct 19, 2015 2:12 pm    Post subject: Reply with quote
There is always a chance for a leak. Keep your oil slinger in place and give it a try. It will probably be fine.
Bearing covers should match the design of the axle tube or bearing housing. Early tubes/housings, early covers.
tisius
tisius is offline
PostPosted: Tue Oct 20, 2015 4:47 am    Post subject: Reply with quote
OK, thanks for the clear answer!
Yep, then I'll give it a try with the split bug axle and split bug bearing cover, + 58-64 backing plate and other brake components 58-64.
