Barndoor doortop thread
Lowdown Dirty Rat
Lowdown Dirty Rat is offline
PostPosted: Fri Aug 12, 2011 2:33 pm    Post subject: Barndoor doortop thread Reply with quote
It seems that pretty much the only barndoor body work not being repo'd now is the doortops. So I thought it would be useful to have a thread discussing how unique they are. (I've missed those BD detail threads Smile)
Answering questions like-
Are there differences through the BD years aside from the obvious 2 quarterlight types?
What parts can be used/hacked of late split doortops?
My personal interest is the part I have circled in red. Is this identical on later splits. One of my 51 doortops has this piece completely twisted and was wondering if I could weld on a late split section.
limeybish
limeybish is offline
PostPosted: Fri Aug 12, 2011 3:20 pm    Post subject: Reply with quote
I beleive they are all the same except the tops on a barndoor have a body number pressed on the top of the frame,but 52s and under have a different quarter light are different catch,???hope this helps you out .
Franz
Franz is offline
PostPosted: Fri Aug 12, 2011 5:00 pm    Post subject: Reply with quote
No, the outer seal is different. 53+ door tops use an outer seal similar to a pop-out. 52- attaches differently. What rubber is used to rebuild 52- door tops?
Brian_1952
Brian_1952 is offline
PostPosted: Fri Aug 12, 2011 6:41 pm    Post subject: Reply with quote
There not that rare
(20-024785)Ambulance (20-037784)truck (20-035850)panel
(20-035778)kombi
WANTED 52 parts and NOS sheet-metal
Lowdown Dirty Rat
PostPosted: Sat Aug 13, 2011 7:29 am    Post subject: Reply with quote
Brian_Mccue wrote:
There not that rare
Fancy selling a couple cheap then? Wink
So is it right that 53+ barndoor owners can just fit any late year split door top and it be correct (not counting glass)? Confused
But for pre53 not only is the quarterlight unique but so is the frame due to the metal trim used to pinch the rubber seal?
Below is a rather useless pic of my 51 frame with what's left of the original seal.
And heres why I needed the section circled in red Shocked
Perhaps I can straighten it Confused Sad
Lowdown Dirty Rat
PostPosted: Mon Aug 22, 2011 11:20 am    Post subject: Reply with quote
^^^ Correct Question Question
nane_cox
nane_cox is offline
PostPosted: Mon Mar 12, 2012 2:44 pm    Post subject: Reply with quote
hello,
can someone help me to find the correct seal for the piano hinge popout window on the front door please (reproduction part Question )?
It's for a 1952 frame
thanks
RockStock
RockStock is offline
PostPosted: Wed Sep 19, 2018 1:49 am    Post subject: Re: Barndoor doortop thread Reply with quote
A couple of small differences I've noticed
Frame lower bar > catch channel [no.47] screws [no.48] changed from flat headed screws
to phillips headed screws
sometime between 1953 & 1955. Would be good to narrow that down.
Also the 53-55 vent window catch tab echoes the barndoor safari tabs.
Flat, no rib, convex top curve.
Guess the tab design changed in 55/6?
Edit: Greg N says tab was updated sometime in 57
-StockRocks-
djfordmanjack
djfordmanjack is offline
PostPosted: Thu Sep 20, 2018 11:11 pm    Post subject: Re: Barndoor doortop thread Reply with quote
can confirm part of this Chris. my Sept 55 Wolfsburg still has the same flat tab.
62 Dickholmer, custom color Seeblau L360
Wolfsburg Classics
Banned
Wolfsburg Classics is offline
PostPosted: Mon Sep 24, 2018 3:21 pm    Post subject: Re: Barndoor doortop thread Reply with quote
The latch plate change happened in November 1957 #303 ... when they changed from flat top to dished top...the Safari dash tabs followed the same change.
The slot headed screws on the slider latch plate were used up till around mid '60 i think before changing to Phillips head,they used the same screw for the license light lense on post '58 Buses.
