Saguache Samba Member
Joined: December 28, 2009 Posts: 360 Location: Gunnison, CO
Posted: Wed Mar 14, 2012 4:55 am Post subject: |
Alright, yep the bendable stuff looks easier. Joel, how much did you end up buying and using? Going to have to figure out how to get the headliner up there too. _________________ Matt Thyer
http://zenoswagen.wordpress.com/ |
Posted: Wed Mar 14, 2012 4:58 am Post subject: |
Very cool Shepherdsond, do you have any photos of the area above your windows? Looks like you're putting in cleats, what are you going to build there. _________________ Matt Thyer
Escorial Syncro Samba Member
Joined: May 02, 2004 Posts: 437 Location: Manitou Springs, CO
Posted: Wed Mar 14, 2012 6:55 am Post subject: |
Saguache wrote: |
Alright, yep the bendable stuff looks easier. Joel, how much did you end up buying and using? Going to have to figure out how to get the headliner up there too. |
I bought a roll of 4' X 50', and the actual name is Prodex. I know I miss spelled it previously, sorry. This quantity is probably enough to do two vans, so adjust your order accordingly. I just know I'll be using a lot of this stuff, so I bought extra.
Note: the only negative I've found with using this product is that there are some subtle waves in the foil. Probably just a result of the manufacturing process. Anyway, those subtle waves do telegraph through the headliner when all is done. Not bad, and I can live with it. You can see some of the waves in my photos.
Best of luck, keep us posted as to how it works out. Joel _________________ Joel Lane
1985 Vanagon converted to syncro, ALH TDI, Reimo Primus top with Westy interior
2002 Toyota Tundra 4x4
1974 Honda CL360 Scrambler (for sale!) |
shepherdsond Samba Member
Joined: April 25, 2005 Posts: 439 Location: Bellingham, WA
Posted: Wed Mar 14, 2012 7:29 am Post subject: |
Matt,
This is the area above the window, the top strip is to screw the LED lights into (the lights will of course be attached on top of the headliner when it is in) and the lower strip which is just above the window is for a curtain track. I have epoxied all sorts of bits of wood like this in any place where I think I might want to attach something in the future (like netting pockets for example). I have also glued some thin plywood strips (you can see them in my last post) to the roof in case I want a curtain hanging down to block off the top space for warmth. The plywood is 1/2" like the insulation so it should not show when the headliner is in. I am working slow, I keep thinking of new things! I have not decided yet whether to put in a forward bulkhead to make the front into a cupboard (I would have to remove a window to get it in).
_________________ 87 Syncro Hightop Camper
3 knobs + solid shaft
2.2 Phase II Subaru
Hi-Top build thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=534517 |
Posted: Wed Mar 14, 2012 8:03 am Post subject: |
In terms of quantity I purchased 5 sheets of Microcell foam (Full Sheet 60" x 72" x 1/2"). These were cut down to 4'x4' to reduce shipping. I tried to get some locally to avoid shipping but prices were much higher. It ended up at about $200 and I think I will have quite a bit left over. _________________ 87 Syncro Hightop Camper
2.2 Phase II Subaru
Jedi Samba Member
Joined: October 23, 2007 Posts: 734 Location: Cool California
Posted: Wed Mar 14, 2012 9:36 am Post subject: |
Great job guys.
The family and I hopped in the ride the other day and headed off to SF to go to the Academy of science. Great place! Then we decided to head down to SantaCruz via Hwy 1 to go visit some friends.Here are a few shots of Golden Gate park and some right around HalfMoon Bay.Enjoy
_________________ 1961 Westfalia SO23 Mango Green/Seagull grey
1961 Westfalia SO34 T/BW
1961 Westfalia SO34 SWR
1964 Westfalia SO33 pearl white
1965 Westfalia SO42 Velvet green
1986 Syncro Wolfram grey with black int GL
1986 Syncro Doka
1987 Syncro Sevana beige Adventurewagen
1987 syncro Sevana beige GL
1973 Pumpkin orange Thing
2 1963 Rag top bug's
1965 Manx
1970 Single cab
1971 combi
1990 Vanagon GL
2007 Audi A4 3.2L quattro |
Posted: Wed Mar 14, 2012 3:48 pm Post subject: |
Jedi,
You have probably posted this somewhere but if so I missed it. Did you convert your AW interior to a Westy? Best of both worlds in my opinion, very nice. _________________ 87 Syncro Hightop Camper
2.2 Phase II Subaru
Jedi Samba Member
Posted: Wed Mar 14, 2012 10:07 pm Post subject: |
Yes I did. It is the best of both worlds _________________ 1961 Westfalia SO23 Mango Green/Seagull grey
1986 Syncro Doka
1965 Manx
1970 Single cab
1971 combi
1990 Vanagon GL
alain riaud Samba Member
Posted: Thu Mar 15, 2012 1:16 am Post subject: Vanagon turbo diesel |
[/img]
Uploaded with ImageShack.us[img]
[img]
Uploaded with ImageShack.us[/img]
[/img] |
nuhu Samba Member
Posted: Thu Mar 15, 2012 9:06 am Post subject: |
Jedi wrote: |
Yes I did. It is the best of both worlds |
Hi Jedi. What is the total height of your van? Do you know how much taller the AW top is compared to a Westfalia poptop? Thanks. |
Posted: Thu Mar 15, 2012 9:54 am Post subject: |
nuhu wrote: |
Jedi wrote: |
Thanks for the reminder nuhu, I need to get the ladder out and measure mine after the lift so I know what I can and can't fit under. I believe I'm pushing 9 or 10 feet right now. _________________ Matt Thyer
Posted: Thu Mar 15, 2012 9:56 am Post subject: |
BTW, Thanks Shepard and Joel for answering my questions. Joel what are you using as a headliner? I need to order a roll and then some because this spring after the lighting and the insulation go in, I'm going to line the top and the van. I was looking at marine carpets (without backing) but I'm still shopping around. _________________ Matt Thyer
Jedi Samba Member
Posted: Thu Mar 15, 2012 10:42 am Post subject: |
nuhu wrote: |
Jedi wrote: |
My syncro is 8 and a half ft tall _________________ 1961 Westfalia SO23 Mango Green/Seagull grey
1986 Syncro Doka
1965 Manx
1970 Single cab
1971 combi
1990 Vanagon GL
Posted: Thu Mar 15, 2012 4:57 pm Post subject: |
Saguache wrote: |
BTW, Thanks Shepard and Joel for answering my questions. Joel what are you using as a headliner? I need to order a roll and then some because this spring after the lighting and the insulation go in, I'm going to line the top and the van. I was looking at marine carpets (without backing) but I'm still shopping around. |
Hello Matt,
I used a product that goes by several names, but you can find it called Flexform or Ozite. It comes in many shades and colors. With all the contours these various tops have, I found you need an extremely light and flexible material. This stuff comes in 80 inch wide sheets, so I was able to stretch it and end up with almost no seams, and it hugged all the angles and soft corners. It's kind of a fuzzy stuff, a lot like a trunk liner or the stuff they put on bass boxes or audio speakers. I was cautioned by all the upholstery shops I asked to keep the roof material as light possible so it wouldn't fall down over time. So this stuff was about as light as I found.
BTW, the Prodex insulation ran about $50 for the hole top. _________________ Joel Lane
Posted: Thu Mar 15, 2012 7:16 pm Post subject: |
Escorial Syncro wrote: |
Saguache wrote: |
Hello Matt,
BTW, the Prodex insulation ran about $50 for the hole top. |
Hot damn, I just dropped a wad on new CVs so $50 doesn't sound so bad. Thanks for the pointer to Ozite/Flexform. I was out in the van this afternoon considering the difficulty of installing anything in that space (above my head). _________________ Matt Thyer
wildenbeast Samba Member
Posted: Fri Mar 16, 2012 10:33 am Post subject: |
Two more images to ponder over;
this one was in the classifieds awhile back, selling the roof for $1600
_________________ - Bill, '93 Eurovan Syncro Weekender (2.5 manual ACU) |
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Fri Mar 16, 2012 10:51 am Post subject: |
drool |
J Charlton Samba Member
Joined: August 24, 2007 Posts: 1546 Location: The True North Strong and Free
Posted: Sun Mar 25, 2012 5:33 pm Post subject: hightop solar panel |
As more and more tops get into circulation, more and more folks are doing some nice installations of accessories.
These pics are of a solar panel that has been installed on a top on a syncro.
Nice tidy installation!! _________________ NAHT hightop availability May 18 2023 -
Bend Oregon - for Oregon, California- (7 tot , 3 available), Kennewick Wa (6 tot, 1 available), Small Car Performance Fife Wa. (7 tot 4 avail ), Fairbanks Alaska (1 tot 0 avail)
Future availability TBD : Springfield Mass. Staunton Va, Florida, Colorado, Grand Junction Co., SLC probably late 2024 |
Posted: Mon Mar 26, 2012 6:37 am Post subject: High top interior |
A couple of pics of the interior of a hightop as finished by Joel Lane. The van owners are currently on their first long distance cruise with the van.
Front bulkhead, LED lights, strutted access door to front storage.
This pic shows the bed extension in the upright position. Joel has developed a latch/lock to hold the extension in the upright position to secure all of the "stuff" while on the road.
You can also see the power vent - quite nice to change the air in the van quickly. _________________ NAHT hightop availability May 18 2023 -
