Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Tue Dec 13, 2011 5:05 pm Post subject: |
Ok, here is a question that I didn't feel needed its own thread:
What is the shore power voltage in NA?
I ask this because my Westy is a Euro-Spec (220v), and I can't seem to find a 110v replacement for the power converter.
Anybody? _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
Timwhy Samba Member
Posted: Tue Dec 13, 2011 5:13 pm Post subject: |
Ok, I didn't think I would need to go into detail, but here it is:
Next year we plan on shipping Domo to NA, and travel around US and Canada for a year or so.
Domo is a 220v user. I will need to convert him to a 110v user. The ORIGINAL Westfalia converter under the bench seat is NOT a dual-volt user. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Last edited by Team WorldTour on Tue Dec 13, 2011 5:17 pm; edited 1 time in total |
kamzcab86 Samba Moderator
Posted: Tue Dec 13, 2011 5:16 pm Post subject: |
Domo wrote: |
Anybody? |
120/110V
Maybe this will help: http://buyersguide.bargainoffers.com/voltage_guide.shtml ? _________________ ~Kamz
2016 Golf GTI S
Timwhy Samba Member
Posted: Tue Dec 13, 2011 5:28 pm Post subject: |
That guy loves the phrase 'vice versa'! _________________ 1990 Feldjäger Syncro AAZ
Click to view image
RBEmerson Samba Member
Joined: November 05, 2011 Posts: 2108 Location: SE PA
Posted: Tue Dec 13, 2011 7:49 pm Post subject: |
Jes' lurkin'. For now... _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
FNGRUVN Samba Member
Joined: October 27, 2007 Posts: 2237 Location: Fort Collins, CO
Posted: Tue Dec 13, 2011 8:38 pm Post subject: |
Once you figure out what you do need to take, I suggest you make a check-off list of those items. Nothings worse than being out in BFE only to discover you forgot something really important like water. Yeah, I forgot the water once. Another time we forgot our folding table that we really rely on. Make a list...check it twice.
Speaking of water.....the wife and I did some backpack-type camping this year. We bought one of those water filters so we didn't have to carry water. It's basically a bag with a filter at the bottom of it and a tube to drain the filtered water into your clean container. Catadyne or Katadyne(can't remember) is the brand. Works great and now we don't have to carry as much water in the van as we used to. We'll just make more. _________________ "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin |
SpudlyHotPotato Samba Member
Joined: April 27, 2010 Posts: 150 Location: Phoenix, AZ
Posted: Tue Dec 13, 2011 11:07 pm Post subject: |
We rarely spend time cleaning dishes while camping. It helps that my husband's cooking makes me want to lick the plate clean. He uses a nonstick skillet for breakfast burritos and everything just peels right off.
Aside from the nonstick pan method, I can't say enough good things about a wok! We figured out that the wok will nest inside the sink with the stovetop folded down on top of it. It's just a Cost Plus cheapo wok. The key is to season it. Do this at home while cooking across a number of meals. You heat it on high until the metal turns kind of blue, use a high heat oil, chop up scallions and bacon and garlic and just keep swiping around on the inside for awhile until those ingredients get all wilted. This starts the seasoning process. Then you have to continue to be careful with it, not ever using scrubbies or soap on it.
This is apparently the old Chinese way of using woks. We totally never knew this and then our vegan chef friend told us about it. The key is to open the pores of the metal and fill it with oils, which helps it to become a non stick surface. Once your wok is seasoned, then you don't need to use soap on it anymore. Just use a paper towel and salt for abrasion to clean it off post-cooking. Once it becomes a seasoned wok, it turns black and slick. It's kind of dreamy, not having to clean much and knowing there's a whole civilization's history backing up the validity of this laziness.
Here's a link to see more about this process: http://www.thaifoodandtravel.com/features/wokcare.html
We have a spice wheel we fill up and a squeezy bottle full of olive oil. Then we have loads of veggies and tofu, which is in a sealed cooler-safe container. Slice up ingredients, toss it all in the wok and add spices constantly: hot meal with very little post-meal cleanup.
I can't say we've ever boiled water in the van. But when we use the stove, we always line the backsplash with aluminum foil to catch any overspray and prevent the heat from warping the rubber stovetop edge. After camping we just peel that part off and it's instantly clean again. _________________ Rebuilt 2.1 in a 1985 manual Camper
"Those things are over kill and I want a set" - Jedi
"All my work explores the human desire or obsession for utopias, and the structure of all my works is the search for utopias lost and rediscovered." - Marguerite Young
www.bewilderknits.com |
Honuak Samba Member
Posted: Tue Dec 13, 2011 11:33 pm Post subject: |
I've used seawater and sand too, works well.
I also have a ZODI pressure washer. Its basically a stainless pressure washer. You can go to the hardware store and buy one of almost equal quality at less than half the price. The ZODI holds about 2.5 gallons and comes in really handy. I like that it is totally portable and I can put it on the campfire, the little tripod it comes with or pour hot water in it from the stove (it too tall to sit directly on the stovetop. While in motion I secure it to the front table leg and I can use it in the sink too, thereby keeping my tank water mostly for drinking/cooking etc. I usually put stream/lake water in the ZODI.
SAMBA!
Oh and I keep a good stash of kipper-snacks on hand. |
debbiej Samba Member
Joined: December 14, 2008 Posts: 1556 Location: las cruces, nm
Posted: Wed Dec 14, 2011 6:39 am Post subject: |
This pressure washer sounds great. I looked at a website that has several kinds. Which do you have? |
rubbachicken Samba Member
Posted: Wed Dec 14, 2011 2:25 pm Post subject: |
one thing i've figured out since we have been sleeping in lucy, it's not always easy to find flat ground, so i use the original jack to level out the back, we figure out which way the ground leans, park the sliding door on the high side, and use the jack to lift it level, in either the front or rear jacking point, i always leave a note on the dash, to remind me that there's a jack under us
also that ingles supermarkets that have a starbucks in them, usually have free wifi _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
Honuak Samba Member
Posted: Wed Dec 14, 2011 8:32 pm Post subject: |
debbiej wrote: |
I currently have a ZODI brand pressure sprayer. But any stainless chemical sprayer would work. They come in various sizes from hardware outlets. On the one I used to have I modified the hose (longer) for better showering. The ZODI kit I have came with a tripod and burner designed for the diposable propane canisters. I've only used it that way a few times but the tripod would make a good portable stand for cooking big pots of whatever too. The quality of the pump, valves and hose etc on the ZODI is better than what you get at hardware stores but both function the same.
Happy Camping! |
Posted: Thu Dec 15, 2011 6:15 am Post subject: |
Thanks! |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
MacDude Samba Member
Joined: July 26, 2014 Posts: 101 Location: Bonny Doon
Posted: Sat Aug 09, 2014 2:02 pm Post subject: |
another thing about eggs is that if you get local fresh eggs, they can be stored at room temp. no need to take cooler/fridge space. _________________ '84 Wolfsburg Westfalia
'90 White Multivan (currently not running) |
syncrswim Samba Member
Joined: January 03, 2015 Posts: 14 Location: Austin TX
Posted: Wed Aug 05, 2015 6:33 am Post subject: Cash in $1s, 5s, and 10s |
Cash in $1s, 5s, and 10s...
For those pay-at-the-entry, unstaffed campsites. It saves stuffing twenties in for $10 sites, with no change available. |
danfromsyr Samba Member
Posted: Wed Aug 05, 2015 6:41 am Post subject: Re: Cash in $1s, 5s, and 10s |
syncrswim wrote: |
...For those pay-at-the-entry, unstaffed campsites. It saves stuffing twenties in for $10 sites, with no change available. |
Abscate wrote: |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed Aug 05, 2015 6:55 am Post subject: |
There it is:
_________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
jimf909 Samba Member
Posted: Wed Aug 05, 2015 7:21 am Post subject: |
Well, who reads the subject line? I thought it came from the blue too. _________________ - Jim
Abscate wrote: |
