eng622 Samba Member
Joined: December 31, 2020 Posts: 63 Location: Nottinghamshire
Posted: Sun Jan 30, 2022 3:01 pm Post subject: Driveshaft oil leak on 1974 200 |
| Car has rear disc brakes. Oil is leaking out of the wheel end of one driveshaft. Appears to miss the disc and runs down the wheel to the rim when stood. Not a lot of oil just a smear getting on to the tyre but can see some all round the wheel rim after a long run. What needs replacing. |
eng622 Samba Member
Posted: Sun Jan 30, 2022 3:02 pm Post subject: Re: Driveshaft oil leak on 1974 200 |
| 1200 cc not the irs super |
Starbucket Samba Member
Posted: Sun Jan 30, 2022 3:05 pm Post subject: Re: Driveshaft oil leak on 1974 200 |
| Smell it to see if it's brake fluid or trans. oil. Is there any "Growling" when you drive? |
Dan the workingstiff Samba Member
Joined: July 03, 2006 Posts: 828 Location: Downriver, MI
Posted: Mon Jan 31, 2022 8:58 am Post subject: Re: Driveshaft oil leak on 1974 200 |
Brake fluid has a strange feeling to once on your fingers. Not at all slippery like gear lube. _________________ '69 Beetle
'66 FG buggy
My other air-cooled's
'76 IH 1200
'75 IH 1200 |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33414 Location: Hot Arizona
Posted: Mon Jan 31, 2022 9:27 am Post subject: Re: Driveshaft oil leak on 1974 200 |
Brake fluid should dissolve in water.
Gear oil has a distinctive odor, and is not miscible with water. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
eng622 Samba Member
Posted: Mon Jan 31, 2022 2:44 pm Post subject: Re: Driveshaft oil leak on 1974 200 |
Oil leak. Looking at the spares that came with the car I see two hub seal kits, so now I know why.
Reading about the kit there is a metal spacer/ring which is supposed to be chamfered on one inner edge and opposite outer edge, but mine look almost plain. It is said not to use these. Advice. |
Posted: Mon Jan 31, 2022 3:04 pm Post subject: Re: Driveshaft oil leak on 1974 200 |
| I would use the old spacers with the chamfer and inspect the axel boots while you are under there. |
