modok Samba Member
Joined: October 30, 2009 Posts: 26743 Location: Colorado Springs
baked beetle Samba Member
Joined: September 23, 2006 Posts: 1162 Location: Alberta, Canada
Posted: Sat Aug 20, 2011 8:01 pm Post subject: |
but it looks soooooo cool _________________ These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
____________________
66' His
57' Theirs
63' Hers
62' Drag Bug - Theirs 13.1 @ 101 mph (GONE) |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Sat Aug 20, 2011 8:11 pm Post subject: |
That setup is just begging for a turbo!! _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Sat Aug 20, 2011 8:14 pm Post subject: |
It helps make wheelies on take off. Priceless. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
XxonValdez Samba Member
Joined: February 01, 2008 Posts: 264 Location: San Diego, CA
Posted: Sat Aug 20, 2011 8:21 pm Post subject: |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Sat Aug 20, 2011 9:29 pm Post subject: |
I bet I could make more HP with a Weber 38mm DGAS on a progressive manifold. I can feel my spark plugs fouling just looking at it!
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
hemi Samba Member
Joined: December 15, 2007 Posts: 76 Location: cleveland ohio
just my 2 pennies what good would all that be with factory end castings. |
Type 5 Joe Banned
Joined: January 18, 2003 Posts: 1795 Location: Oregon
Posted: Sat Aug 20, 2011 9:37 pm Post subject: |
They should call that "Johnny spanks his Monkey" |
modok Samba Member
Posted: Sat Aug 20, 2011 9:44 pm Post subject: |
That carb setup is NUTS
Yeah, it does not make sense and it will never run right on any normal vw engine, BUT, it is so over the top it's like a new record.
That's snorkelstang's intake right there |
bomberbaja Samba Member
Joined: January 18, 2010 Posts: 549 Location: Tri-Cities WA
Posted: Sat Aug 20, 2011 10:12 pm Post subject: |
modok wrote: |
except snorkelstang has a V8(?) in the front |
modok Samba Member
Posted: Sat Aug 20, 2011 10:14 pm Post subject: |
yeah, that's what it's for, a v-8
the vw part is just the display fixture |
Posted: Sat Aug 20, 2011 10:22 pm Post subject: |
If you were to not hook up 1 carb and block all the passages in one throat of the other carb so it only flows on one side it would proably run ok.
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
blacktruck Samba Member
Posted: Sun Aug 21, 2011 8:08 am Post subject: |
earthquake wrote: |
Casey |
with just a little more work one could be a spare |
AlteWagen Troll
Posted: Sun Aug 21, 2011 8:31 am Post subject: |
That guy must have lost it, he is also selling a set of 48 dell tri jets for $700!!! |
craigman Samba Member
Posted: Sun Aug 21, 2011 8:46 am Post subject: |
Holy $hit man! |
MinamiKotaro Samba Member
Joined: July 18, 2008 Posts: 1039 Location: Somewhere in TN
Posted: Sun Aug 21, 2011 8:51 am Post subject: |
That negates the biggest advantage of a dual-carb setup, having a hole per cylinder. _________________ 1967 VW Beetle
2276cc
MegaSquirt-extra v3.57
Check out my ongoing story. |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Sun Aug 21, 2011 10:17 am Post subject: |
Technically, there's still one hole per cylinder. They just aren't seperated. Like the Offspring said: Ya gotta keep 'em seperated! _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Sun Aug 21, 2011 10:53 am Post subject: |
WHAT!!!
No carb heat? It'll never run well without carb heat.
Come to think of it - it probably won't run with heat - not well anyway. Nothing more than a large funnel shoehorning air/fuel into the stock end castings.
Someone with more $'s than brains probably will buy it. I wonder if it'll clear the deck lid. _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
Lionhart94010 Samba Member
Joined: January 04, 2005 Posts: 1417 Location: SF Bay Area / Silicon Valley / So Cal
Posted: Sun Aug 21, 2011 11:12 am Post subject: |
Just Plain Ridiculous! It shows how little understanding the creator/owner has in regards to carbureting an engine :0(
Carburetor Sizing ( Many others)
http://www.csgnetwork.com/cfmcalc.html
http://www.classictruckshop.com/garage/shopmathcfm2.php _________________ Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm |
AlteWagen Troll
Posted: Sun Aug 21, 2011 11:59 am Post subject: |
I think he is just trying to get rid of other junk parts.
Stock end castings = free
Johnny 4 skin manifold = worthless
Duals to plenum adapter = who the hell thought this shit up?
Dells = probably bought them not knowing they were side draft |
