tangojeff Samba Member
Posted: Wed Aug 24, 2011 9:33 am Post subject: |
Last month, when I picked up my Westy from getting a repaint in Savanah Biege, the ol' body shop owner said to me, "You know I could have shot the lower side panels with Gravel Guard before we painted on the gold. Tough stuff, it would have looked like the sides of your Miata; not too conspicuous and pretty hard to chip, too." Maybe next time? |
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Wed Aug 24, 2011 11:13 am Post subject: |
I had that on one of my other vanagons, it works great...however it looks like orange peel from hell and everyone always says "man you sure did a bad job on the bottom" |
Bruce Wayne Samba Member
Posted: Wed Aug 24, 2011 11:28 am Post subject: |
2 years old. Plastikote is the brand. cost me a whole $54. used a roller to put it on.touched up a couple of spots earlier this year. also did the front bumper. hit it with some tire cleaner when you want it to it look "new" again. pic is from NWMF last week.
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 1868 Location: Pittsburgh PA (ish)
Posted: Wed Aug 24, 2011 7:42 pm Post subject: |
I am thinking of doing this to my syncro that has almost nothing but rock chips on the bottom portion (almost all the paint is gone!). There is not yet any surface rust but it will inevitably start so it makes sense to prevent it.
With that said, the body could use a paint job. However, I don't plan to do a paint job just yet. If i put the LineX treatment on the bottom portion is there any reason why that would make it harder to paint properly down the road?
I wouldn't be painting over it. |
Terry Kay Banned
Posted: Wed Aug 24, 2011 8:03 pm Post subject: |
The only problem here would be getting a sharp masking line where the bedliner ends, or starts at the body line.
Lumpy don't make for good masking. _________________ T.K. |
Posted: Fri Aug 26, 2011 9:31 pm Post subject: |
finished.
Terry Kay Banned
Posted: Sat Aug 27, 2011 8:11 am Post subject: |
Looks Nice.
I know the black is readily available, but I for one would go with the Monochromatic / same color as the body look & tint the bedliner.
Blends in a little better with the whole thought----
Other than that -- it came out nice. _________________ T.K. |
PIRATE Samba Member
Joined: May 05, 2005 Posts: 253 Location: San clemente CA
Posted: Sat Aug 27, 2011 8:37 am Post subject: |
purplepeopleeater wrote: |
finished.
What product did you use?
Did you do it yourself?
What was your method of application?
Close up photos of texture please.
Thanks _________________ 2003 jetta wagon
1987 westfalia 2wd
1987 Syncro GL
1964 vespa vbb 150
1973 vespa sprint
2005 toyota tacoma Ole reliable |
Posted: Sat Aug 27, 2011 8:47 am Post subject: |
Terry Kay wrote: |
Looks Nice.
Other than that -- it came out nice. |
Im with you on that TK, I could have tinted a batch to the sane color code as my paint, but I have a ton of bolt on stuff that is black including my plate bumpers and I think it flows alot better all matching....white plate bumpers would be gross. |
Herr Motorspiele Samba Member
Posted: Sat Aug 27, 2011 10:21 am Post subject: |
Thanks |
x2
I'd like to see a close up of the line in the valley where you stopped. I'm in the process of sanding and can't decide where to cut it. Also can't quite decide on the front wheel/door jamb area. |
Californio Samba Member
Posted: Sat Aug 27, 2011 11:32 am Post subject: |
Yes, the valley/where to stop issue is important and it'd be nice to see closeups.
I just got a Durabak color chip in the mail. Dark grey, looks like the color to go with on my white Syncro.
Is Durabak any good? I'm planning on sanding the lower panels down with 150 grit and wire brushing out the rust/crap in the seams first but with that, does this stuff hold on? |
I used raptor, they have it in black or a color of your choice.
I used the gun they have in the kit....sanded the heck outta it and made sure it was "paint ready" you want to make sure its prepped gooood.
Posted: Sat Aug 27, 2011 11:33 am Post subject: |
That pic shows where it got kinda wavy... I copied go westy pretty much |
dlb154 Samba Member
Joined: December 27, 2006 Posts: 359 Location: Reno, NV
Posted: Sat Aug 27, 2011 2:04 pm Post subject: |
Look great up close and from a distance. Nice job.
When you masked off for sanding, how did you control sanding right to the edge without grinding through the masking? Did that masking stay in place and get a new strip over it before spraying the bed liner?
Has anyone used that green Frog masking for interior household painting? I wonder if that's a good masking tape to use rather than the typical blue. It's designed to expand and seal for a cleaner line. |
Posted: Sat Aug 27, 2011 2:05 pm Post subject: |
I sanded right up over the masking tape, some areas I had to retape...I hand sanded the area leading up to the edge.
hopefully it doesn't pull back from the edge, Its fresh paint so I think i'm safe. |
The Raven Samba Member
Posted: Sat Aug 27, 2011 2:08 pm Post subject: |
dlb154 wrote: |
I used it on a boat when I did the antifoul paint, good stuff and did it's job well. |
Terry Kay Banned
Posted: Sat Aug 27, 2011 4:40 pm Post subject: |
I wonder why you didn't run the tape with the body line--would have made it a little easier to follow.
In masking, I would have used 1/8th or 16th fine line first, then 3/4 taped over it with the masking paper attached to the tape off of the masking roll.
You can see if the tape is running straight pretty easy with the fine line tape first. _________________ T.K. |
PIRATE Samba Member
Posted: Sat Aug 27, 2011 6:05 pm Post subject: |
You did a great job the texture looks great that raptor product looks awesome . I've heard the prep is really important it's just so hard when you have a fresh paint job .
1987 westfalia 2wd
1987 Syncro GL
1964 vespa vbb 150
1973 vespa sprint
Posted: Sat Aug 27, 2011 8:51 pm Post subject: |
Terry Kay wrote: |
You can see if the tape is running straight pretty easy with the fine line tape first. |
I did follow A body line, yes thats how I tapped it.
Actually, I used duct tape and stole the neighbors sunday newspaper while filling my a/c with redtek without any manifold gauges and my a/c still doesn't blow cold.
Honuak Samba Member
Posted: Sat Aug 27, 2011 9:10 pm Post subject: |
I doubt it matters that much but when I did mine the paint guy told me that tinting bedliner affects the durability of the product. Black is toughest because it has no additives. Still, I bet the pigmented stuff is still plenty tough. I went with black cuz it happened to go well with my overall look. |
