Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Mon Aug 22, 2011 10:17 am Post subject: VW or Audi 16" Compact Spare |
I'm wondering if anybody's tried fitting a late model 16 x 4 compact spare over their big brakes up front or in the clamshell?
It seems as though it could be a solution to the spare tire conundrum for those of us running 16" wheels. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Zeitgeist 13 Samba Member
Posted: Mon Aug 22, 2011 2:45 pm Post subject: |
That's a great question. I'm still spareless since switching over to 16", and it makes me nervous. I'll bet the load rating would be off considerably _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
buildyourown Samba Member
Posted: Mon Aug 22, 2011 3:55 pm Post subject: |
I did this with a steel Passat wheel. You can get them on ebay for less than $100. Just make sure it's the narrow one. Can't remember if it's 5.5" or 6" wide.
With a small spacer under the bolt securing the clamshell, everything fits great. |
a914622 Samba Member
Joined: July 29, 2004 Posts: 840 Location: Westend of HWY2 , Wash
Posted: Mon Aug 22, 2011 4:25 pm Post subject: |
The audi V8 has a 17 inch spare donut that has a 99 load rating. Fits the clam shell and fits even my big brakes.
jcl _________________ 87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru |
D Clymer Samba Member
Joined: December 22, 2005 Posts: 2978 Location: Issaquah, WA
Posted: Mon Aug 22, 2011 5:50 pm Post subject: |
Yeah, I don't think load rating would be an issue since C-sized Audis actually out-weigh Vanagons by quite a bit. However, I would be concerned that the center bore would be too small to fit over the Vanagon front spindle stub. Audis have a 57mm center bore while Vanagons require at least 63mm to get around the grease cap flange.
David |
connorsvw2 Samba Member
Joined: August 16, 2008 Posts: 347 Location: Denver, CO
Posted: Mon Aug 22, 2011 8:12 pm Post subject: |
Center bore is easily machined at a wheel refinishing center-mine cost $40 for 4 steel wheels. Not sure how they will look at boring s space saver, though... _________________ '85 Westy Wolfsburg camper/2002 2.5 Subaru since 2003.
'85 GTI 1.8L 1-owner 8v-gave up on 9A 2.0L 16v transplant. Keeping her stock!
'99 Passat 1.8T Variant-AKA "The Money Pit". Still limping along...
'09 Subaru Outback XT 5-speed, 245 hp rocket (wife's car) |
Posted: Mon Aug 22, 2011 8:28 pm Post subject: |
Mmm, I hadn't really considered the centre hole problem - darn!
I don't really care about the load rating - I don't think it will explode in a hundred mile drive. If its a little weak I'd be driving accordingly, eh? _________________ '84 Vanagon GL 1.9 WBX
furrylittleotter Samba Member
Joined: May 19, 2008 Posts: 1506 Location: West Seattle
Posted: Mon Mar 03, 2014 12:07 pm Post subject: |
Great idea, using a narrow spare. Any progress?
Neil2 |
danfromsyr Samba Member
Posted: Mon Mar 03, 2014 12:13 pm Post subject: |
This is what my brother did on his van.. was a lucky find in the junkyard.
but are about $100 on fleabay. from Audi A8s
http://www.ebay.com/sch/i.html?_trksid=p2050601.m5...;_from=R40
a914622 wrote: |
jcl |
Abscate wrote: |
Posted: Mon Mar 03, 2014 4:06 pm Post subject: |
[quote=
That's a good solution if you don't have a Posi diff. Its almost 5% bigger than stock and would wreak havoc with my Peloquin...[/quote]
That's why you put it on the front and the front on the rear.
5 minutes. |
Posted: Mon Mar 03, 2014 7:09 pm Post subject: |
furrylittleotter wrote: |
5 minutes. |
Yeah - five minutes on the narrow shoulder of I-5 with 4 lanes of distracted drivers talking and texting past at 75 MPH - NO THANKS!!!
My matching spare cost me well under half the cost of that spendy spare, too. $100 plus $25.00 shipping isn't exactly a bargain. _________________ '84 Vanagon GL 1.9 WBX
slo356 Samba Member
Joined: February 18, 2002 Posts: 365 Location: Central Calif Coast
Posted: Mon Mar 03, 2014 10:10 pm Post subject: |
I don't have any experience with Audi or VW spares but I tried a 2005 M-B temporary spare. Fits and is lightweight. If you use on Syncros must have decoupler to prevent damage. REMEMBER TEMPORARY SPARES ARE TEMPORARY and use at slow speeds only.
Plenty of clearance for Audi Big Brake kit. The photos are on '87 Syncro.
No center hole problem. No machining required.
Fits Audi Big Brake kit and stock Syncro springs.
Easily fits stock clamshell carrier.
MB Spare size 155/70r x 17" Match 225/60x16 tire.
_________________ '65 T1 Sedan
'87 T3 Syncro |
quickjetta2 Samba Member
Posted: Mon Mar 03, 2014 11:01 pm Post subject: Mercedes spare |
Many Mercedes have a 16 in full size spare thats fits easily over big brakes and has a big enough center bore already. A 205 55 16 is about the same diameter as a stock Vanagon 14 inch tire and fits perfectly in the clamshell. Often times if you find a wheel at a junkyard it already has a tire on it in that size cuz thats a super common size on a German car with 16 in wheels. |
Posted: Tue Mar 04, 2014 1:23 pm Post subject: Re: Mercedes spare |
quickjetta2 wrote: |
Stock 185R14 diameter (25.75") equates to 225-55/16 (25.74") and will not fit in the standard clamshell. _________________ '84 Vanagon GL 1.9 WBX
