bluntlunchbox Samba Member
Joined: June 06, 2007 Posts: 330 Location: San Diego, CA
Posted: Tue Aug 23, 2011 10:32 am Post subject: ghia disc brakes on bug |
Hey guys, just curious about ghia discs on type 1. It seems like most conversion kits are based on the ghia set up. Is there any advantage to these kits or can I source all of this through a junk yard? Didn't seem like a lot of guys are going this route. |
skabonner Samba Member
Joined: May 12, 2009 Posts: 854 Location: La Habra, Ca
Posted: Tue Aug 23, 2011 10:50 am Post subject: |
I have frequent the yards here in so cal, and I rarely see a ghia. I've only seen a ghia once or twice. I think that is the biggest reason, but also the quality factor. You have no idea the condition these are in. Personally I don't want to trust my life, or my front apron, to a set of brakes that may be warped, or have bad calipers. I would just pony up for the kit. _________________
Douglas Adams wrote: |
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools. |
'68 Beetle "Sadie" (R.I.P.)
'67 Beetle "Ilsa"
'06 Gti "Heidi" |
Posted: Tue Aug 23, 2011 12:07 pm Post subject: |
Ok, thanks a lot. I'm gonna try the new discs at all 4 corners. Carcraft has a combo kit for brakes and rims for 5x130 Porsche lug pattern..keep ya posted. |
Posted: Tue Aug 23, 2011 1:36 pm Post subject: |
When you do the swap check the maaster cylinder. When the po of my car installed my rear discs he didn't remove the residule pressure valve causing them to stick. I ended up replacing the whole rear set up with drums, before I realized the problem. _________________
'67 Beetle "Ilsa"
'06 Gti "Heidi" |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Tue Aug 23, 2011 1:51 pm Post subject: |
FYI, the Ghia set up is for ball joint front ends. The king & link pin Ghias had drums.
So IF your car is a 66 or newer, and IF you can find a Ghia in the junk yard that still has the front brakes, and IF that Ghia is a disc brake car, you can simply unbolt the ball joints from the trailing arms and swap them right onto your car. _________________ Mother Nature is a Mean Evil Bitch! |
doc1976 Samba Member
Posted: Tue Aug 23, 2011 4:30 pm Post subject: |
the other reason most go for the aftermarket is because the disc conversion usually goes with lowering the front end. can't do that with factory ghia spindles. |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Tue Aug 23, 2011 6:49 pm Post subject: |
bluntlunchbox wrote: |
I put four corner discs on the 72 super I sold last month. Very impressive braking - make sure you are belted in before doing an emergency braking.
Make sure to pony up for the e-brakes on the rears. _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Wed Aug 24, 2011 1:58 am Post subject: |
skabonner wrote: |
Personally I don't want to trust my life, or my front apron, to a set of brakes that may be warped, or have bad calipers. I would just pony up for the kit. |
All you need are the spindles, and if you are really cheap the calipers.
New discs are cheap and should be replaced anyway.
Even buying new calipers it would still be cheaper than a kit and you have OEM quality spindles not poorly made aftermarket crap. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Dystinct Samba Member
Posted: Wed Aug 24, 2011 4:56 am Post subject: |
doc1976 wrote: |
Why is that?
I have ghia disc brakes that came with my car's spare parts. There was also a set of drop spindles that are set up for the dics. The car also has an adjustable beam on it.
I'm not sure if I can run both drop spindle and adjustable beam. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76936 Location: Sneaking up behind you
Posted: Wed Aug 24, 2011 5:06 am Post subject: |
doc1976 wrote: |
Really?
3" drop with AVIS adjusters and stock Ghia spindles.
I started with stock Ghia spindles than I bead blasted. I added rebuilt Ate calipers, Brembo rotors, German bearings and power painted backing plates.
Yes it was more expensive than buying a cheap kit, but I have all quality parts. [/img] _________________ Glenn
Member #1009
#BlueSquare |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Wed Aug 24, 2011 7:11 am Post subject: |
Glenn wrote: |
doc1976 wrote: |
Really?
Yes it was more expensive than buying a cheap kit, but I have all quality parts. [/img] |
good to see the red beetle. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
BWD Samba Mailman
Joined: August 23, 2002 Posts: 2154 Location: In bed.
Posted: Wed Aug 24, 2011 7:14 am Post subject: |
bill may wrote: |
Glenn wrote: |
doc1976 wrote: |
Really?
good to see the red beetle. |
Glenn, is that your car??? _________________ BWD
JHC
member #2850
1966 Beetle
_____________________________ |
Glenn Mr. 010
Posted: Wed Aug 24, 2011 8:57 am Post subject: |
BWD wrote: |
Glenn, is that your car??? |
Why yes it is. _________________ Glenn
Member #1009
#BlueSquare |
swinewerx Samba Member
Joined: March 29, 2011 Posts: 98 Location: lodi, calif.
Posted: Wed Aug 24, 2011 2:21 pm Post subject: |
My 62 has discs, since I had to change the front wheel bearings, and races, I was told that I have ghia discs, but front only, as the back ones are different calipers, compared to the front ones. apparently, I have a very mixturized beetle, it is a sixty two body, on a fifty something pan, dual port aftermarket motor, etc. With all my worries with this beetle at least the engine is always running great, for a go cart! Otherwise, I would not have gotten this beetle, if I would have known what to look for before buying!! I am very glad I know how to weld, and tinker!!! |
Posted: Wed Aug 24, 2011 9:31 pm Post subject: |
Well, I'm picking up a kit and it seems like most of these after market kits used the same calipers, and the rotors and pads were similar too. 5x130 pattern rotors and fake fuchs should be fun for a while. I'll use a "build thread" and post some pics of the install. Thanks again guys! |
Posted: Thu Aug 25, 2011 1:52 pm Post subject: |
I am not familiar with ghias, but did they ever have the big five star lug pattern? especially in disc type!!?? |
Posted: Thu Aug 25, 2011 2:13 pm Post subject: |
BWD wrote: |
bill may wrote: |
Glenn wrote: |
doc1976 wrote: |
Really?
I was referring to lowering by way of spindles with stock ghia spindles. that is where most people start. |
Glenn Mr. 010
Posted: Thu Aug 25, 2011 2:15 pm Post subject: |
doc1976 wrote: |
I was referring to lowering by way of spindles with stock ghia spindles. |
No such thing as "stock" lowered Ghia spindles... they are all aftermarket.
doc1976 wrote: |
Most... I disagree. Dropped spindles are a static 2.5" drop and they push the wheels out .250". Using an adjustable beam means you can set it anywhere from 0" to 3" drop and dial in so your tires fit. _________________ Glenn
Member #1009
#BlueSquare |
KILLERWATT Samba Member
Joined: November 18, 2003 Posts: 3298 Location: Vero Beach
Posted: Thu Aug 25, 2011 3:10 pm Post subject: |
FYI. The Latest Rage aftermarket Ghia disc to link pin spindle kit uses a special bearing specific to their kit. I only mention this because I almost lost a wheel on the highway. |
Glenn Mr. 010
Posted: Thu Aug 25, 2011 3:12 pm Post subject: |
The problem with aftermarket parts is if you keep the car for years, like i have, they might not be available when they need replacing. _________________ Glenn
Member #1009
#BlueSquare |
