morymob Samba Member
Posted: Sat Sep 03, 2011 12:24 pm Post subject: Oil with titanium additive |
Posted my q in a couple other(oils) locations but no response. Anyone know anything about the titanium additive now in a couple oils?? Is it to replace the zink?? I'm at the crossroads of oil brands to use with our flat tapped engines.Not much said on the bottle. |
Petervw Samba Member
Joined: July 04, 2005 Posts: 1020 Location: Sarnia Ont. Canada
Posted: Sat Sep 03, 2011 12:41 pm Post subject: Re: Oil with titanium additive |
morymob wrote: |
.. oil discussion is like a religion and you may have trouble believing this... if you are driving a Stock vehicle, all oils are backward compatible, no matter what changes they come up with..stay within the recommended oil weight for dino or use the lastest greatest diesel oils(more zinc)...mobil1 recommends 0/40 syn for the vanagon... |
Posted: Sat Sep 03, 2011 12:53 pm Post subject: |
I been using the latest greatest oil, Rotella, but zink has been removed to such a low level it may no longer help any. |
fsf1o1 Samba Member
Joined: February 12, 2011 Posts: 186 Location: Florida
Posted: Sat Sep 03, 2011 1:05 pm Post subject: |
Hmm |
Californio Samba Member
Posted: Sat Sep 03, 2011 3:22 pm Post subject: |
Not to change the subject but I am finding fewer and fewer heavy weight oils at the usual places. No Mobil 1 15-40 at Walmart, for example. |
Posted: Sat Sep 03, 2011 3:51 pm Post subject: |
Californio wrote: |
I can get 5w40 Mobile 1 Turbo Diesel at many of my local FLAPS. The ZDDP is okay the last time I checked. Oils with first numbers of 15W or higher and second numbers of 40 or higher don't have to meet the GF-4, GF-5 low ZDDP requirements.
Petervw wrote: |
all oils are backward compatible |
SM, SN oils are not backwardly compatible, that is why you see bottles of 5w20 or 10w30 that only say SM or SN, they don't meet the specs for earlier oils. They may pass the newer wear tests, but aren't being tested according to some of the older test.
Don't have a clue on titanium additives, that's a new one for me. |
GMByers Samba Member
Joined: December 07, 2008 Posts: 642 Location: Retired in NW PA
r.e.wing_fc3s Samba Member
Joined: April 16, 2010 Posts: 591 Location: Vanagon Capitol USA: Bellingham, WA
Posted: Sat Sep 03, 2011 5:17 pm Post subject: |
kendall gt1 30w has enough zddp for flat tappets according to manufacturer. its been good to me . |
goffoz Samba Member
Posted: Sat Sep 03, 2011 5:48 pm Post subject: Re: Oil with titanium additive |
morymob wrote: |
The ?? I would ask is what kind of titanium?
In my world titanium has 2 functions...electronically deposited,
.... its a extremely hard, wear resistant surface. approx 600VPS
As an oxide in suspension its a very fine aggressive abrasive,
I use it for putting a really fine edge on hardened steel, or polishing saphire.
Its like the "Titanium " credit cards...I just don't get it |
Posted: Sun Sep 04, 2011 5:06 am Post subject: |
Castrol synthetic is the one i'm looking at as an example, their top grade, has the titanium(new) additive. As to how it's added,?, curious as anyone what it's purpose is, all that is on bottle it to do with film strength and as i'm keeping Castrol synthetic in my westy ,po used it, so still a question if this an improvement. If u keep the oil film from breaking down then the no-zink won't be a problem |
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Sun Sep 04, 2011 10:47 am Post subject: |
morymob wrote: |
The new Rotella engine oils are still very good for our flat tappet Vanagon engines. Who knows what level of titanium is good. Could just be a marketing hype..
The new Rotella..CJ4..still has a very high 1100/1200 see the link to Bob is the Oil Guy and a virgin oil analysis on the 5w40 1264ppm zinc with a nice slug of boron and moly too.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2330040#Post2330040
A sample of Rotella CJ4 15w40..1078ppm zinc..still very robust oil.
http://www.bobistheoilguy.com/forums/ubbthreads.ph...ost2354338
Most PCMO oils have 600/800ppm of zinc. Anything north of 1000 is fine for the VW older engines.
Unless you have a very highly loaded valve train..with racing valve springs..Rotella will work just fine. |
Posted: Tue Sep 06, 2011 4:45 am Post subject: |
Thanks for the info, will keep it in the slo lane with my left blinker on............. |
