syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Fri May 10, 2013 11:02 pm Post subject: |
FrankenSubySyncro wrote: |
Is anyone using the stock 86+ vanagon sender for the dash? |
I am on both of my conversions, EJ22('94)and EJ22('92)/EJ25('99) hybrid. My guage reads under the LED just like my stock van. I got my sender from VC.
Burley's reversed manifold has a plate welded into it that is threaded for the stock VW sender. |
elic_vw Samba Member
Posted: Mon Aug 13, 2018 3:48 pm Post subject: Re: Subaru conversion temperature gauge reading |
Anybody have any tips as to where to wire in a resistor for my temp gauge? 84 westy with stock vw tank sensor and stock subaru tempurature gauge. |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1489 Location: Victoria,B.C.Canada
Posted: Mon Aug 13, 2018 6:41 pm Post subject: Re: Subaru conversion temperature gauge reading |
Anywhere in the wire going to the temp gauge.At the junction between the Subaru harness and the VW wire to the gauge or before the 14pin connector to the foil would be easiest I think. For some insane reason I found the wire behind the fuse box and wired it in there. |
vik Samba Member
Joined: January 13, 2005 Posts: 204 Location: back in Czech
Posted: Thu Sep 23, 2021 12:16 pm Post subject: Re: Subaru conversion temperature gauge reading |
Hi,
Can you give me a hand here. I would like to add a VW sender to the coolant manifold and get rid of the resistor.
But what sender to get? It has to be obviously the srew type (M10x1?)
049 919 501 seems to be possible.
Or any recomendation?
Thank you
Viktor _________________ T3 Syncro camper in progress |
hardway Samba Member
Joined: January 03, 2012 Posts: 416 Location: Fidalgo Island
Posted: Thu Sep 23, 2021 1:07 pm Post subject: Re: Subaru conversion temperature gauge reading |
049 919 501 is the stock coolant temperature sender for a Syncro Vanagon. 10x1.0 that screws into the alloy thermostat housing. Obviously compatible with the T3 coolant temp gauge. |
vik Samba Member
Posted: Fri Sep 24, 2021 4:29 am Post subject: Re: Subaru conversion temperature gauge reading |
Thank you. Will give it a try
Why with the subaru sender you need to make the gauge resister mod? I read it somewhere in the past, but now - no chance. _________________ T3 Syncro camper in progress |
Posted: Fri Sep 24, 2021 3:56 pm Post subject: Re: Subaru conversion temperature gauge reading |
vik wrote: |
Why with the subaru sender you need to make the gauge resister mod? I read it somewhere in the past, but now - no chance. |
It reads too high without the resistor. 23-30hm resistor makes it read around the LED light at operating temp.
This is the sender I got from Smallcar to use with the VW gauge but I never istalled it and use the Subaru sender with resistor and an aftermarket VDO gauge with sender inline as well.
vik Samba Member
Posted: Fri Sep 24, 2021 11:55 pm Post subject: Re: Subaru conversion temperature gauge reading |
I expressed my question not the correct way.
I know, that the gauge reads hot when using the Subaru sender unless the resistor is used.
But I wondered why? Subaru sender resistance, voltages?
thx _________________ T3 Syncro camper in progress |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sat Sep 25, 2021 8:08 am Post subject: Re: Subaru conversion temperature gauge reading |
vik wrote: |
thx |
Yes, Subaru sender resistance is different.
Super simple to install the VW sender and be confident of the readings on the gauge: they are very important! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
