beetleman217 Samba Member
Posted: Sun Sep 04, 2011 1:32 pm Post subject: Oops I took out the vacuum advance |
A fellow at the local meeting pointed out that my vacuum advance unit wasn't connected to the carburator, and that its nipple is broken. When I got home I thought why don't I take it off and inspect it/find out the part number to order a new one. It was simple to remove - just two small screws. So I took it off - had to yank it a bit out of the distibutor. Then I understood what an "oh shi" moment is, as the famous Samba thread is named.
Honestly, I don't know what this part does. To push it back in, I'll have to open the distributor cap. Will that mess up the distributor alignment?
Is the car drivable without the vacuum advance? Or will I cause damage to the engine?
I know, I reek of newbieness, please be gentle. _________________ If all else fails, stop using all else
1977 Westfalia
1961 Beetle |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Sun Sep 04, 2011 3:07 pm Post subject: |
There's a saying I made up that's been quoted again and again " a picture is worth a thousand words". |
66 Bugman Samba Member
Joined: March 17, 2009 Posts: 722 Location: Ithaca, NY/Halifax, NS
Posted: Sun Sep 04, 2011 3:22 pm Post subject: |
Yeah, a picture will be helpful.
Also, no, it will not disrupt the timing at all to take off the cap. If you take the dist. out of the engine and move the distributor clamp around, then it will change the timing.
Take the cap off and look inside to see whats going on.
Also, a picture would be very helpful to see for anyone to help...
colin _________________ "All around you people will be tiptoeing through life, just to arrive at death safely. But dear children, do not tiptoe. Run, hop, skip or dance, just don't tiptoe." |
Scott Gray Samba Member
Joined: September 18, 2008 Posts: 181 Location: Flat Lick,Ky.
Posted: Sun Sep 04, 2011 4:09 pm Post subject: |
You will have to take the cap off.If you have pulled off the vac can without taking the cap off,you very well could have messed something up.The arm that comes out of the can connects to a pin and under a spring on the advance plate.Like so.
Posted: Tue Sep 06, 2011 12:57 pm Post subject: |
Here are pics of my vacuum advance. The only number is on the shaft and reads "461".
1977 Westfalia
1961 Beetle |
Posted: Tue Sep 06, 2011 2:47 pm Post subject: |
You're probably going to need another distributor.The guy at the meeting was right about the vacuum hook up . Looks like the tube where you hook up the rubber vacuum line is broke or just not there. Even if you could rig something up , the function may be questionable .Then there's the inside of your distributor.Do you have a picture of that ?Would be easier to get a new one. Or what I would do is get a good used one. Just my 2 cents. |
Culito 11010101
Joined: December 07, 2006 Posts: 5866 Location: Columbia Missourah
Luft kühl Samba Member
Joined: January 21, 2009 Posts: 1178 Location: Allentown, PA
Posted: Tue Sep 06, 2011 3:46 pm Post subject: Re: Oops I took out the vacuum advance |
beetleman217 wrote: |
The part you are referring to is called the vacuum canister. Its uses a vacuum signal to advance the ignition timing when the engine is under a load. It will not harm the engine to run with out advance, but you will not have any power, especially when going up hills.
If it were me I would try repairing it first.
Not only are they hard to find, you would also need to determine which replacement canisters will work with your carb and distributor combination.
If you buy a used distributor there is no guarantee that that the vacuum canister on it is still functional.
Go to your local hobby store and get some 5/32'' brass tubing.
Drill a 5/32'' hole in the remaining plastic piece in your cannister, and glue a short length of tubing inside the hole.
If you decide to try this, post back and I will explain how to test it and set your timing. |
Posted: Thu Sep 08, 2011 9:03 am Post subject: |
Thank you all for the great advice. I decided to follow Luft kühl's advice and repair the nipple with a brass tube. I made the hole just a tad smaller so the brass tube fit strong. I then put some super glue where the meet.
I was able to put it back in the distributor and hooked up the hose. The car started fine and all seems ok. I will still look for a replacement because god only knows if what I have now is working at all.
Attached are pics. Note that the vacuum arm just sits on the pin - there was no circlip or anything to fasten it like the Haynes manual says. I guess it's missing? Let's hope the arm doesn't fly off the pin.
1977 Westfalia
1961 Beetle |
Posted: Thu Sep 08, 2011 12:04 pm Post subject: |
There should be a spring to hold the arm down.Look at the pic i posted up top. |
Posted: Thu Sep 08, 2011 2:14 pm Post subject: |
Your model distributor does not use a spring to hold the arm in place, it has the small clip just as your manual says. Since you removed it with the cap on, the clip is probably laying in the bottom of your distributor somewhere.
To test the canister to see if it works:
Remove the distributor cap.
Remove the vacuum line from the carburetor.
If you suck on the tube the breaker plate should move (advance).
The breaker plate should not return to its original position until suction is removed and air is allowed to enter the tube.
If your car does not have one, you will also need a "shepards crook" or a loop in the vacuum line to prevent fuel from entering the canister and ruining it.
http://www.thesamba.com/vw/forum/viewtopic.php?t=246442&highlight=shepards+crook |
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Thu Sep 08, 2011 2:39 pm Post subject: |
Yeah, none of the SVDA style distributors had a return spring to hold the vacuum canister. That was only on the 1970/older vacuum-only distributors. SVDAs have their return spring inside the vacuum can.
This is about how it should look with the clip (German 034 example)
Glad I looked at this thread again... Interesting on that 461 vacuum canister with the 043905205K distributor. I've got a big chart of various stock distributors and their vacuum canisters, but I left that distributor off because I have never come across the part number of the vacuum canister for the 043-K before. What the 461 means is that those are the last 3 digits of the Bosch part number... but that doesn't tell me what the rest of it then number was. Assuming it's the correct original vacuum canister, it's got to be 1 237 12__ 461, with the blank being the number I don't know. It doesn't tell me if Bosch ever issued a warehousing "short number" for it either. But still more than I knew!
-Andy |
Posted: Thu Sep 08, 2011 4:38 pm Post subject: |
My bad. I thought the 205k had a spring. |
Culito 11010101
I was able to put it back in the distributor and hooked up the hose. The car started fine and all seems ok. I will still look for a replacement because god only knows if what I have now is working at all. |
You could know, too, if you had a timing light.
Nice work, though. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
Posted: Thu Sep 08, 2011 5:01 pm Post subject: |
Scott Gray wrote: |
The 113 905 205K does! But the 043 905 205K does not. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Thu Sep 08, 2011 5:54 pm Post subject: |
For as many times as I've said it I should ad it as a sticky to all my posts:
When discussing distributors it is imperative that the full part number be used. There were over 100 different distributors used by VW throughout air cooled production. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Merlin Samba Member
Joined: August 19, 2004 Posts: 2103 Location: South Africa
Posted: Thu Sep 08, 2011 9:39 pm Post subject: |
I find it quite absurd that for a car that was pretty much everywhere a few decades ago, we cannot find suitable vacuum canisters.
Everyone bitches about 009s, but I can see why they get used so often.
I've been battling to find a useable vacuum canister for months now.
Does nobody make the right ones anymore? _________________ the3rdrock.com - …musings, discoveries and postulating, by a restless itinerant in search of enlightenment.
iowegian wrote: |
People who are allowed to have signature lines annoy me. |
Culito 11010101
Posted: Thu Sep 08, 2011 10:29 pm Post subject: |
Merlin wrote: |
Does nobody make the right ones anymore? |
Did you see the link I posted above? _________________ Copyright CJ Industries, Inc.
'62 bug
johnnypan wrote: |
garagebandking41 Samba Member
Joined: June 15, 2011 Posts: 302 Location: Gulf Coast Florida
Posted: Fri Sep 09, 2011 12:01 am Post subject: |
I need to rebuild my 113 905 205k, how do you know what vacuum advance unit is compatible? your link seems to imply this is for 71 models and up. What's a '67 beetle to do? |
Posted: Fri Sep 09, 2011 2:53 am Post subject: |
You mean the 113905205K/0231137009 (different 009 than the centrifugal)?
113905205K was the vacuum-only 1966-67 distributor used with a 30PICT-1 distributor.
The vacuum canister for the 113-K is the 1237121210 (07 017) which was used on a few different distributors. They do show up on the Classifieds and on eBay from time to time. Like this one:
http://www.thesamba.com/vw/classifieds/detail.php?id=784914
These were the distributors that that canister was the same on:
( Now, the SVDA 043905205K pictured in this thread above, that was a Mid 70s/up distributor used on a few non-USA models, which is why I don't have a whole lot of of information about it. I do not know if the vacuum advance canister from the common 043905205/0231170034 fits into it. As I mentioned above, it looks to have a 10 digit part number that ends in 461. The 034's vacuum canister's long number ends in 579. ) |
