Basketcase Samba Member
Posted: Wed Sep 07, 2011 2:25 pm Post subject: motor swap |
our '72 Ghia developed a nock. so we're gonna swap a '74 motor. the Ghia motor has the generator and the '74 has an altornater. would it be better to keep the altornater that's with the '74 motor? what would be needed to do to change over to the altornater?
Thanks for the help!
Dave |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Wed Sep 07, 2011 2:30 pm Post subject: |
Is the alternator a AL78 (external regulator) or a LA82 (internal regulator).
Either way you can't use the generator's regulator. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Sep 07, 2011 2:40 pm Post subject: |
not sure on the regulater the swap motor s at my Uncle's place. how would we tell the difference?
Thanks! |
Glenn Mr. 010
Posted: Wed Sep 07, 2011 2:41 pm Post subject: |
A AL78 alternator has a plug with 3 wires and a bolt terminal. A AL82 has a single wire and a bolt terminal. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Sep 07, 2011 2:52 pm Post subject: |
so would it be better to keep the generator or swap to the altornater and i assume the number of regulater wires means the hooup would be different?
thanks! |
Glenn Mr. 010
Posted: Wed Sep 07, 2011 2:53 pm Post subject: |
Generator is 30 amps and alternator is 55 amps.
Either will work. _________________ Glenn
Member #1009
#BlueSquare |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Thu Sep 08, 2011 7:46 am Post subject: |
I would go with the alternator as its already with the motor and its easy and cheap enough to address the voltage regulator issue. _________________ Ghia Owner Emeritus |
Ghiaddict Samba Member
Joined: November 20, 2002 Posts: 2632 Location: Now in Honea Path, SC
Posted: Thu Sep 08, 2011 8:03 am Post subject: |
Another vote for the alternator here.
If you need to make a change to the wire harness,
it's an easy job for an internally regulated alternator.
That information is available @ many sites on the interweb.
If that '74 alternator is an original, it would've had it's own
external "solid state" regulator. That conversion to your '72
will be a little more involved. _________________ ****************************
Karmann Ghia & Beetle parts available.
Convertible tops installed. |
MinamiKotaro Samba Member
Joined: July 18, 2008 Posts: 1039 Location: Somewhere in TN
Posted: Thu Sep 08, 2011 9:20 am Post subject: |
Stick with the alternator. Upgrading to an alternator is a no-brainer. _________________ 1967 VW Beetle
2276cc
MegaSquirt-extra v3.57
Check out my ongoing story. |
Posted: Thu Sep 08, 2011 11:41 am Post subject: |
this is the first car i've had with a generater and all seems fine so why would the altornater be better? not going to have any big electrical users added on.
thanks for the info! |
ovghiaguy Samba Member
Joined: November 07, 2009 Posts: 848 Location: Orangevale Ca.
Posted: Thu Sep 08, 2011 2:12 pm Post subject: motor swap |
Basketcase wrote: |
alternaters can develope higher amps at idle than a generater |
Posted: Mon Oct 10, 2011 6:38 pm Post subject: |
we got the motor swapped this weekend. gonna use tew altornater. lt has the 3 wire and bolt terminal which ls the externinal regulater l do belive. l found the wiring upgrade but lt is for the internial type. l can't find the one for my type on the search. help and thanks!
and do l just get any regulater for a '74? |
Glenn Mr. 010
Posted: Mon Oct 10, 2011 6:40 pm Post subject: |
You need a regulator for a 74 AL78 alternator.
Member #1009
#BlueSquare |
Posted: Mon Oct 10, 2011 6:48 pm Post subject: |
Thanks Glenn! |
