roberth3850 Samba Member
Joined: August 13, 2010 Posts: 54 Location: Salt Lake City Ut.
Posted: Tue Sep 13, 2011 1:02 pm Post subject: |
I just bought a Subaru engine and transmission. I separated the two and the inside of the bell housing was covered with what seemed like a quarter of an inch of the stickiest black powder (note to self, look hard at the clutch). Tried scraping all the little nooks and crannies with no progress. Inspiration struck when I saw the pressure washer sitting the garage. Glad I was wearing old clothes and had my glasses on. That crap went everywhere, mostly on me and refuses to come off. I have been hesitant to pressure wash the WBX, he is old and tired and I simply do not trust the wiring. It seems like borrowing trouble. Spray on what ever and gently rinse off.
Robert
'86 Westy _________________ Accelerate.....naah
I gain speed gracefully |
psych-illogical Samba Member
Posted: Tue Sep 13, 2011 1:29 pm Post subject: |
I like a clean engine. Easier to work on. Easier to detect little leaks or other issues. I don't use a pressure washer or steam just cuz I've heard too many horror stories about damaging delicate electronic $h!t. I like the garden hose hooked up to the water heater along with one of the multi-function garden spray heads set to a gentlle spray. I don't have any oil leaks so it's mostly just dust and a little dirt, or sometimes mud from forest roads. It comes off of there easily. _________________ 83 1/2 Westy waterboxer
'57 Beetle-sold
Coupla '81 BMW motorcycles (R80G/S; R100RS)
'96 BMW R1100GS |
stumpy Samba Member
Joined: April 04, 2007 Posts: 181 Location: york, pa.
Posted: Tue Sep 13, 2011 2:18 pm Post subject: Clean Engine |
Confushes say Clean engine ---"Good"! Dirty engine ---"Bad"! Grease make Fire burn "Hotter" |
Odd_Dutch Samba Member
Joined: March 20, 2011 Posts: 82 Location: The Hague, Netherlands
Posted: Tue Sep 13, 2011 2:19 pm Post subject: |
Mine is aircooled and with all the tin and rubbers in place it probably looks like a small pool when cleaning it with a hose.
But I dont have to worry about it for now, I took the engine and tranny out and cleaned/painted everything. It looks almoast new now |
JPrato Samba Member
Joined: December 15, 2006 Posts: 791 Location: Livonia, NY
Posted: Tue Sep 13, 2011 5:13 pm Post subject: |
I like a clean engine. It just sets the mood to keep everything in tip top shape. It makes it easy to spot problems or leaks and fix them before they get major.
On a warm engine I will spray degreaser with a squirt bottle. Let it sit for awhile then hose it off. I try not spray directly at electrical connections. After rinsing I start it up and take if for a 1/2 hr. drive at highway speeds to dry it out well. Afterwards I might take a rag and wipe down the painted surfaces too.
_________________ Joe
87 Syncro Tin Top project
84 Westy, 2.5L Subaru power
06 Subaru 2.5 turbo in waiting
46 Cessna 140 |
photogdave Samba Member
Joined: April 05, 2004 Posts: 3053 Location: Vancouver Island, B.C.
Wolpi Samba Member
Joined: December 25, 2009 Posts: 38 Location: Lacey, WA
Posted: Tue Sep 13, 2011 8:13 pm Post subject: |
Great timing on this post! I'm just now starting a multi-step process of cleaning out all the caustic Burning Man Playa dust from my engine bay.
Step 1: Shop Vacuum and dry brush out the big and easily reached chunks of dirt.
Step 2: Turn Shop Vac to blower mode, blow out more dust.
Step 3: High pressure compressed air blow, focusing on hard to reach areas and electrical connections.
Tomorrow: Step 4-??: Begin rinsing down engine bay with low pressure hot water. Multiple passes with soap, water, brushes and rags. I'm contemplating a pre-wash spraydown with a diluted Vinegar solution- helps to neutralize the high PH Playa dust.
I want to clear out as much dry Playa dust as possible before I get anything wet. Playa dust turns into lakebed clay/cement nearly instantly once moistened. Tenacious stuff!
I'll likely wind up detailing, regreasing (Dielectric) and replacing (if needed) every electrical connector.
My Van has been to more Burning Man's than I have. Seems to handle it well- as long as I give her some TLC and attention afterwards.
Joel _________________ '81 Westy Vanagorsche "The Wolpertinger" |
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Tue Sep 13, 2011 8:28 pm Post subject: |
I am in the "keep it clean" camp on my vehicles. I learned a long time ago its easier and more fun to work on a clean motor than a dirty one. With electronics I'm reasonably careful to avoid blasting the crap out of the connectors. I haven't gotten my Vanagon as clean as I want it yet but I will. _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Wed Sep 14, 2011 6:17 am Post subject: |
photogdave wrote: |
Good tips - thanks!
Now I'm off to the junk yard to scrounge some hooter-clamps! |
I may have a few extra hooter clamps photodave. What size are you looking for........ |
S+L Samba Member
Joined: June 24, 2018 Posts: 3 Location: Owensboro, Kentucky
Posted: Thu Aug 03, 2023 6:39 pm Post subject: Re: Do You Clean Your Engine? |
What about Purple Power? Is there any known issue with using it on a Waterboxer? |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Thu Aug 03, 2023 9:38 pm Post subject: Re: Do You Clean Your Engine? |
My main concern with Purple Power (and Simple Green for that matter) would be not to let it sit very long on painted surfaces.
12 years later (since original thread) and still pretty clean...
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Fri Aug 04, 2023 10:48 am Post subject: Re: Do You Clean Your Engine? |
I've been using this product for years with no side effects. Hot Shot Degreaser. Spray it on hose it off. Slight brushing on heavy soiled or built up grease. Use it on almost everything, even upholstery spot cleaning.
https://psdetailproducts.com/products/hot-shot-high-power-deg-cleaners-hd-cleaners _________________ 89 Westy 2.1 Auto |
