rustbus Samba Member
Posted: Tue Sep 13, 2011 7:09 pm Post subject: are westfalia seat bracket stud plates available? |
Guys,
I need a pair of these bad boys. are any vendors remaking them?
are used ones viable? looks like something that would rust away by now...
_________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
Desertbusman Samba Member
Posted: Tue Sep 13, 2011 7:17 pm Post subject: |
They do rust away real quick. Doubt your're going to find any new parts for an old Westy bed. Just make your own. Doesn't need to be welded. Drill a couple holes in a small plate. This might be one of the few locations I'd recommend silicone sealant. Clean the underside real clean and then use a lot of sealant on both sides of your new plate. But use some good rust resistant primer on everything first. _________________ 71 Superbug
71 Westy |
busdaddy Samba Member
Posted: Tue Sep 13, 2011 7:28 pm Post subject: |
^X2^
It's rare that I get those out in one piece lately, it's just a piece of ~16GA with a couple of bolts welded in and a strip of weatherstripping, a couple of fender washers would slow the production line a bit but do the same thing. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Tue Sep 13, 2011 7:46 pm Post subject: |
RTV is acidic. I would recommend an autobody caulk from an autobody store. Do you want to see what RTV did to our roof where the acid ate the steel and water wicking under it did the rest? I found it when I scrapped the RTV off.
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Tue Sep 13, 2011 7:57 pm Post subject: |
Gotta agree with SG, there's really no place I can imagine a use for a silicone based caulk/sealant on a vehicle.
Auto seam sealer (NAPA even sells it) or urethane gutter caulk from Home depot (very similar to late model windshield adhesive) would be my choices. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Sep 13, 2011 10:01 pm Post subject: |
aw slick thanks guys
i think i might go stainless when i make them...theres no risk of dissimilar metals action there is there? i'll look that up first.
can't weld it (SS) so easy then though....to lock the bolts to the plate that is....right? _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
Posted: Tue Sep 13, 2011 10:12 pm Post subject: |
No need to weld it since it pretty much already takes a second person to get it all bolted up.
Good catch and call on the silicone. Actually I think I used 3M Autobody Sealant on mine. _________________ 71 Superbug
71 Westy |
vw76westy Samba Member
Posted: Wed Sep 14, 2011 12:28 am Post subject: |
when i restored the inside of my bus
i lost that piece & it took a long time before i found a replacement
& since then i have hored everyone i have came accross
a total of 2 _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
quote from bay window bus buyers guide........
The Type 4 engine is considered by many to be VW's finest air-cooled motor, |
TopBud Samba Member
Joined: February 28, 2004 Posts: 1111 Location: Flagstaff AZ
Posted: Sun Sep 18, 2011 7:44 am Post subject: |
I misplaced mine when I took my seat apart, now I am looking around for them, this thread helped me find the size. seems like an easy home made fix.
Just have to get the bolt size _________________ 86 bostig SYNCRO
66 convertible Karmann Ghia |
