adriaan pienaar Samba Member
Joined: February 17, 2003 Posts: 692 Location: Sedgefield, South Africa
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 3198 Location: Downingtown, PA
Posted: Thu Sep 15, 2011 8:00 am Post subject: |
It's not hard Adriaan. Depending on how oxidized it is, start light and work to finer "grits". Any marine store will have the polishes and waxes on hand. For heavily oxidized finishes, you could start with automotive rubbing compound (use the stuff safe for clear coats), then follow that with polishing compound, then wax it. If you plan on using a buffing wheel, don't press - let the weight of the wheel do the work - and go at a slow speed to gauge your progress. |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Thu Sep 15, 2011 8:32 am Post subject: |
If really bad - you can use very fine wet-dry sand paper (use wet) of 1500 or higher grit. Use a rubber or styrofoam pad - not your fingers. The follow with rubbing/polishing compound and carabu wax. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
HeidelbergJohn4.0 Samba Member
Joined: March 01, 2004 Posts: 1199 Location: Havre de Grace, MD
Posted: Thu Sep 15, 2011 3:11 pm Post subject: |
I can't get to my dad's boat right now, but I'm pretty sure this was what we used. it's a two part cleaner/stripper than a sealant. There's a few guys around there that have been using it and swear by it. Mine boat isn't bad enough to use it and my buggy is painted.
http://www.vertglas.com/index.html _________________ 71 LWB Manx style dunebuggy
71 Beetle
71 Volksrod
Machette Speedster
2012 Passat TDI SE (sadly sitting in a buyback parking lot somewhere waiting for it's heart to be ripped out.) |
90runner Samba Member
Joined: July 24, 2006 Posts: 118 Location: Vancouver Island, British Columbia
Posted: Sat Sep 17, 2011 1:09 am Post subject: |
I recomend 3m products thats what we use when polishing boats and its made for gelcoat if its really bad we wet sand then use the polish compound with different grades of pads. Time and patience can get you great results but use the right product theres lots of so called miricle finishes/fixes and they are garbage. _________________ 74 Thing stock lots of rust figured someone needed to save it. |
Glamis Addict Samba Member
Joined: March 21, 2010 Posts: 99 Location: Riverside,Ca.
Posted: Sat Sep 17, 2011 12:56 pm Post subject: Re: Polishing/finishing fibreglass gell coat? |
adriaan pienaar wrote: |
Is there perhaps a thread with step-by-step instructions on polishing the gelcoat of a fibreglass bugy? |
here's something to check out.
http://www.youtube.com/watch?v=UvSumyoub1I&feature=related _________________ AKA RDP's Gelcoater |
weadjust Samba Member
Joined: September 08, 2010 Posts: 25 Location: Tupelo, MS
germanx Samba Member
Posted: Sun Sep 18, 2011 1:27 am Post subject: |
I use the polishing and finishing combo from 3M:
- 3M finesse-it
- 3M pink wax
I most often make customer paint jobs on rc models with 2-component clear coat. I sand the paint with 8000 grid (wet and last pass), and then I use the 3M products.
I do not know how 'tough' gel coat is in terms of hardness. But I often 'soften' the clear coat for the models to ensure the flexing of the body does not create cracks. Polishing of flexible clear coat did never cause any troubles.
Send me a PM or google 3M professional car paint polish for more info...
Here some samples of the results:
_________________ '73 Beach Buggy
'66 T1 Deluxe |
Posted: Sun Sep 18, 2011 9:11 am Post subject: |
germanx wrote: |
- 3M finesse-it
- 3M pink wax
Finesse it is good stuff too. _________________ AKA RDP's Gelcoater |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sun Sep 18, 2011 11:15 am Post subject: |
3M makes a variety of marine products with various degrees of grit. Just be careful that you dont get through the clear. I used the cleaners a couple too many times on our buggy and need to repaint it - but it was already starting to wear through on some spots. Just take your time and be careful. _________________ D-Dubya Manx clone - 63 Short pan,1914.
