Kirk Samba Member
Joined: December 05, 2003 Posts: 5487 Location: North Texas
Posted: Thu Sep 15, 2011 10:02 am Post subject: Need fridge pics/info. |
My winter project is to restore(?) my fridge. (and probably my propane tank. Dan's propane tank resto thread has got me into it. ) As far as the fridge goes, I have the power control (sorry about the crappy pic, its all I got at work):
But when you open the cabinet, there is just an empty hole. No fridge, no nothing. I searched the gallery, loooked at 8 pages of "fridge" pictues, and searched here, but didnt get what I needed. Basically, is there a cut out or something showing the fridge parts so I can see what I'm missing? And possibly see where it hooks up, etc?
I'm pretty fridge stupid since I don't have one. Any info you got helps. _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
drober23 Samba Member
Joined: April 01, 2009 Posts: 787 Location: Detroit, MI
Posted: Thu Sep 15, 2011 10:50 am Post subject: |
Let's assume this is the '77 Westy in your sig.
The fridge should be to the left of the fold-out bed. Non-deluxe models would have a simple ice chest there.
Here are some pictures from the classifieds: http://www.thesamba.com/vw/classifieds/detail.php?id=1156960
Not much to look at really though. If I recall correctly, the metal grate on the top tips you off that it is the fridge version and not the ice box version. The sticker on the inside probably tells you too, but I can't read it, heh. _________________ DJ
'75 Westfalia, '79 Deluxe, and some others...
(more busses than sense)
In a time of chimpanzees I was a monkey |
Westfabulous Samba Member
Joined: January 07, 2007 Posts: 4207 Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Posted: Thu Sep 15, 2011 11:01 am Post subject: |
Kirk, if nothing gets posted, I'll go down to the garage and shoot you a bunch of photos, even if that means that I have to walk past my shattered windshield, and suffer the raw emotion that goes with it. Give me a couple hours. _________________ *****************
"I will gladly pay you Tuesday for a hamburger today." |
Kirk Samba Member
Posted: Thu Sep 15, 2011 12:02 pm Post subject: |
It is the deluxe model, and the '77 in my signature. It should have the fridge in it. I've been watching the classifieds, just wanted a little more info.
Dan, thanks for the offer. _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
Posted: Thu Sep 15, 2011 1:09 pm Post subject: |
Here ya go Kirk. Some pics from my Westy:
The big perspective:
The fridge furniture. Yes, I know the grill needs painting, but I love the original patina, so I left it:
The fridge panel:
The fridge:
The refrigeration system:
A little something to inspire your next project:
Hope this helps. In my opinion, you can buy a used set-up pretty affordably. Before you install it, you want to turn it upside down, plug it in, and wake it up for several days. This is a perfect opportunity to do that. Do a search and read some fridge threads on this. Good luck! _________________ *****************
pittwagen Samba Member
Joined: November 08, 2005 Posts: 766 Location: North of the 49th parallel
Posted: Thu Sep 15, 2011 3:31 pm Post subject: |
Trying to find a cooling unit that actually works, and works well might be a challenge.
So are you into finding a running exact replacement or have you considered a more modern compressor driven cooling unit that would fit in the same location but operate much more efficiently (1/2 to 1/3 of the amp. draw) than the original. You would still need the ice box or fridge compartment but everything beyond that is new.
Here is a link:
http://www.novakool.com/products/conversion_units.htm
I'm sure there are many more companies out there. Something to consider. |
Kirk Samba Member
Posted: Fri Sep 16, 2011 8:11 am Post subject: |
Thanks Dan! With your permission I may use those pics in a "WTB" ad. Wiring pretty self explanatory?
I havent thought about a newer/more efficent unit, no, but honestly, I'm not opposed to the thought. I'll take a look at your link. I figured I could just have the older unit rebuilt somehow, but I haven't gotten much further than that. _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
Posted: Fri Sep 16, 2011 9:14 am Post subject: |
Yes, use the pics. I'd just get a stock fridge and put it in to make it original, unless you are dependent on having something highly functional. Mine suffices, and it is fairly lame, but it is good enough for my needs. Keep us posted Cap'n (Kirk) _________________ *****************
Posted: Fri Sep 16, 2011 9:24 am Post subject: |
Did you see the 12 v fridge as part of the package? Maybe the fridge could be a separate deal. Ask for plenty of pics, of the cabinet and particularly the cooling unit to see how rusty it is.
http://www.thesamba.com/vw/classifieds/detail.php?id=1156553
The fridge should be capable of cooling at least 40deg. below ambient temp. My fridge unit, from a 74 P27, hadn't run for years and after some carefull tapping on the coils, I was able to wake up the mixture inside. I am able to make ice in the little trays as well. If not set on full cold, it does not run constantly either but does draw at least 5 amps when running. The unit has to be really level to function though. More so than in other Dometic units I have, or have had. About as good as it can get with a 37 year old unit.
As well the plastic cabinet housing should be crack free. Minor cracks can be repaired and there are several good paints to recoat the interior surface.
I don't know about recharging the unit. I believe similar heating units can be purchased. FYI. |
Posted: Fri Sep 16, 2011 9:35 am Post subject: |
Pittwagen, that is amazing that you can make ice! I get down to about 55-58* and that's about as good as it gets. As you can see, my fridge is like new; it had no rust nor leaks, and there is nothing about it that would preclude it from cooling better. Can you give me some ideas on where and how you tapped the coils to kick it into gear. I've done some tapping, but no real success. _________________ *****************
Posted: Fri Sep 16, 2011 9:52 am Post subject: |
First the fridge was out of the van so I had very easy access to the rear of the unit. As well I think my unit may have a little better air flow over the cooling unit than yours (both sides upper and lower and upper rear). And it needs to be really level to function well, much more so than the Dometic unit in my Dodge.
Here's a pic of the coils from a 74/75 unit, courtesy of BD. I just gently tapped on all of them with a scredriver plastic handle on several occasions. Didn't have to resort to the inverted/upside down trick.
Posted: Fri Sep 16, 2011 10:08 am Post subject: |
Hmmm, conceptually my unit is similar; from an engineering perspective it seems quite different. I need to find some pics of my style unit out of the bus to get a better idea of the coil network. Thanks. Kirk, sorry about the mini hijack. _________________ *****************
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Sep 16, 2011 10:58 am Post subject: |
Same as the early model, just quished down and spread out.
Your fridge should make ice, time to pull it out and kick it around the driveway a little
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Sep 16, 2011 11:16 am Post subject: |
Excellent; very nice BD. Thanks for that! I should get Kirk to start more threads for me. _________________ *****************
Kirk Samba Member
Posted: Fri Sep 16, 2011 11:46 am Post subject: |
Hijack?! Hell, I'm learning! Got a line on a complete fridge locally, going to look at it tomorrow.
Edit: Texted pics. Whatcha think? $40 or trade for my two spare heat exchangers. Odd, there isnt any power control on the wall.
Bear
Coble
Super
Oppenheim |
1977_L63H_P27 Samba Member
Joined: January 17, 2006 Posts: 2345 Location: Bristol, Tennessee
Posted: Fri Sep 16, 2011 5:20 pm Post subject: |
Looks good. I'd give him the $40. Have you looked in the classifieds at the going prices on heat exchangers?? Peace! _________________
busdaddy wrote: |
...and try a few chubby ones until you find one you like.
1977 Westfalia P27
you can't spell Volkswagen without SWAG
M-code Plate
Full Moon Bus Club |
Posted: Fri Sep 16, 2011 6:29 pm Post subject: |
Kirk wrote: |
Edit: Texted pics. Whatcha think? $40 or trade for my two spare heat exchangers. Odd, there isnt any power control on the wall. |
Pay the man; trade him nothing. Good score. Revive the fridge before you install it. _________________ *****************
Posted: Fri Sep 16, 2011 6:40 pm Post subject: |
Kirk wrote: |
Odd, there isn't any power control on the wall. |
Just like our Canadian Deluxe campers, betcha the bus has no stove either. We weren't allowed to play with matches for some reason, but we got a BA-6 as standard equipment _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Kirk Samba Member
Posted: Sat Sep 17, 2011 7:08 am Post subject: |
Westfabulous wrote: |
Kirk wrote: |
Pay the man; trade him nothing. Good score. Revive the fridge before you install it. |
Yeah, I think paying the man is the wise move.
I'll post more pics when I pick it up, thoughts on revival? Like what I need to be looking at/for? General cleaning is first. _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
Posted: Sat Sep 17, 2011 7:29 am Post subject: |
Search fridge Kirk, and read up on some of the posts. As I recall, turning the fridge completely upside down, plugging it in for a week, and leaving it on a flat surface is the ultimate wake up procedure. There is lots of info to be searched. _________________ *****************
