EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Wed Nov 11, 2015 12:10 pm Post subject: Re: Front door handles, recesses, and mechanisms |
I know I've read somewhere (yes, I searched but couldn't successfully locate it) info on items unique to a 1967 only remote door lock mechanism inside the door at the rear edge. I guess the unique 1967 "remote lock mechanism" has a removable bent piece of steel that some call a "brace", and there is a left side and right side version of this one-year brace. Does anyone remember that thread discussion, and in particular, does anyone have a nice clear photograph of these 1967 only "braces" and how they are installed to the remote lock assembly and inner door? Maybe even why they are even needed in the first place on a '67 door?
On my to-do list is a teardown of my Jan 1967 cab doors, and one of my tasks is to remove the remote door lock assemblies, a clean-up, re-lubrication and then re-assembly of the doors. I'm hoping my "braces" are in there, but if not, I'd love to see what I'll be dealing with if someone can help us out with any description and photos. The part manual I have does not show or mention the "braces" or whatever they are called, or provide part numbers for these oddities.
Thanks afor any info you can provide!
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
FritzCP Samba Member
Joined: October 23, 2005 Posts: 463 Location: Wisconsin
Posted: Wed Nov 11, 2015 1:34 pm Post subject: Re: Front door handles, recesses, and mechanisms |
Quote: |
and in particular, does anyone have a nice clear photograph of these 1967 only "braces" |
ask and you shall recieve
they attach to the button side handle screw. The oval hole side sandwichs between the Mech and the inner door skin and are held in place when you tighten down the inner skin mech screw.
_________________ Fritz Custom Products
Fritz 10 - Tin Screw Torquer
Fritz 124 - Crank Pulley Puller
Fritz 70 - 6306 Bearing Puller
Fritz 44 - Dizzy Puller |
Posted: Wed Nov 11, 2015 2:01 pm Post subject: Re: Front door handles, recesses, and mechanisms |
Absolutely incredible response, great info on a one-year only detail, and great photos too! Thanks "volksheime" for the response!
I recently bought a L & R pair of these "braces" because I haven't had my doors apart since 1984 and don't know if those "braces" are even in my Jan 1967 doors. Your info will help when the time comes to clean/lube/service those locks!
Thanks!
Posted: Wed Nov 11, 2015 2:10 pm Post subject: Re: Front door handles, recesses, and mechanisms |
your welcome! Note when installing them, you need to leave the mech screws a little loose until you get all the screws started, otherwise the handle alan head bolt wont want to pass through the brace, door hole, and handle hole. get, em all started, then snug 'em all down. job done! _________________ Fritz Custom Products
Malokin Martin Samba Member
Posted: Wed Nov 11, 2015 3:08 pm Post subject: Re: Front door handles, recesses, and mechanisms |
For the inner handle:
Quote: |
Early Buses, up to 16 Mar. 1960 VIN # 584674 used a chrome handle with a rib down the center as seen below. |
Does this include commercials? |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Wed Nov 11, 2015 7:28 pm Post subject: Re: Front door handles, recesses, and mechanisms |
jgriffin13 Samba Member
Joined: April 10, 2008 Posts: 11 Location: norwalk ct
Posted: Fri Nov 13, 2015 3:27 pm Post subject: Re: Front door handles, recesses, and mechanisms |
I believe the 67 mechanism was changed to prevent the door from opening when a bump allowed the u shape catch to come up and off the post . That happened to me in my 65 and without my friend grabbing the passenger grab bar he would have been out on the street in front of on coming traffic. As soon as I could I installed a 67 door mechanism as described by Everett. |
obus Samba Member
Joined: March 08, 2001 Posts: 11065 Location: just off Garden State Parkway Exit 81
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24736 Location: Olympia Wash Rinse & Repeat
Posted: Mon May 08, 2017 6:55 pm Post subject: Re: Front door handles, recesses, and mechanisms |
Here is an interesting one:
Fits both 221 837 206 and 211 837 206 A. Have not found in any of the parts manuals what the latter number fits.... _________________ In Stereo, Where Available! |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Mon May 08, 2017 7:05 pm Post subject: Re: Front door handles, recesses, and mechanisms |
EverettB wrote: |
Front interior door handles - Pointed toward 10-11 o'clock on passenger side, 1-2 o'clock on driver's side
Cargo door handles - straight up (12 o'clock) when closed
Examples:
for campers this is important since you can not lock the cargo doors from the inside on most buses. slip a zip tie over the handles at night. _________________ regards
Uli
Clara Samba Member
Posted: Mon May 08, 2017 9:30 pm Post subject: Re: Front door handles, recesses, and mechanisms |
mandraks wrote: |
EverettB wrote: |
Examples:
for campers this is important since you can not lock the cargo doors from the inside on most buses. slip a zip tie over the handles at night. |
North of the border they call them zap straps. |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2207 Location: UK (South)
Posted: Sun Dec 17, 2017 7:32 am Post subject: Re: Front door handles, recesses, and mechanisms |
Hi
I'm trying to find a locking handle to match the existing locking handle so I can have key locks on both sides. My October '56 single cab's locking handle is coded 113 837 502, made by B.U.M. Is that a beetle-style handle?
The complete mechanism for a beetle handle looks different (different base and 'finger'). If I bought a beetle ice pick locking handle could I swap the handle on to the non-locking base and the finger actuator (the bit that engages with the mechanism)?
Pictures of the existing locking handle...
Thanks
Andy _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Posted: Sun Dec 17, 2017 9:27 am Post subject: Re: Front door handles, recesses, and mechanisms |
From the first post on this thread, I believe you want to use the 55-61 driver's side handle listed there:
211 837 205 B
for both sides.
I think 211 837 205 A is the same too, if you come across one of those.
The handle you have is a Beetle handle although I'm not sure what is different since I'm assuming it currently works.
It's possible it's actually a mixture of parts (base/hook/etc) so that while it has a Beetle part # on the pull out piece, other parts have been mixed and matched so that it works in a Bus. _________________ How to Post Photos
Posted: Sun Dec 17, 2017 10:14 am Post subject: Re: Front door handles, recesses, and mechanisms |
EverettB wrote: |
211 837 205 B
for both sides.
It's possible it's actually a mixture of parts (base/hook/etc) so that while it has a Beetle part # on the pull out piece, other parts have been mixed and matched so that it works in a Bus. |
Thanks Everett. Yes it works, although I find that I have to turn the key half a turn to unlock. I have to pull the handle to open the door, then turn the key the rest of the way, otherwise I can't lock it when I close the door. Maybe that's because it's the wrong handle.
I'd assumed it was correct, and another example of interchangeable parts between beetles and buses. _________________ Andy
Posted: Sun Dec 17, 2017 10:30 am Post subject: Re: Front door handles, recesses, and mechanisms |
Who.Me? wrote: |
I'd assumed it was correct, and another example of interchangeable parts between beetles and buses. |
You can skip the assuming by accessing the VW dealer parts manuals here:
http://www.oacdp.org/
Lots of great exploded diagrams, with proper name/part number, and even lists from chassi number to what chassi number most parts were used. _________________ In Stereo, Where Available! |
Posted: Sun Dec 17, 2017 2:13 pm Post subject: Re: Front door handles, recesses, and mechanisms |
Eric&Barb wrote: |
Who.Me? wrote: |
Lots of great exploded diagrams, with proper name/part number, and even lists from chassi number to what chassi number most parts were used. |
I had a look through OACDP and Easy e's '58 parts list. Wasn't sure if there was an omission.
When I got the truck it had one key that only worked the ignition. The ignition has been replaced and the key profile is wrong for the age of the truck, so that key definitely isn't the original.
My handle's base is coded, so I had a key made for that code. It works in the door, so I know that the the barrel matches the code on the base. The same key works the treasure chest lock. I thought that was unlikely to be a coincidence and figured that the cab handle must be original.
Given the number of repro parts used on the truck over the years, it seemed strange that, if the handle had broken, someone would go to the trouble of sourcing an original VW handle (albeit a beetle one) and putting it on the original base and re-using the old barrel or re-coding the beetle one to match the base? _________________ Andy
Posted: Sun Dec 17, 2017 2:51 pm Post subject: Re: Front door handles, recesses, and mechanisms |
One of the cheap sleazy ways to recode a lock is to simply file down the brass wafers with key in the tumbler.
You would need to find the key code on the tool bay door latches to see if they match the driver door code. _________________ In Stereo, Where Available! |
