Volks Wagen Samba Member
Joined: February 13, 2013 Posts: 2926 Location: Germany
Posted: Wed Jul 10, 2019 3:21 pm Post subject: Re: "Spot light for illuminating heater levers..." ? |
To avoid issues with unwanted bursts of reality while driving, joints should be pre-rolled for the journey.
FreeBug wrote: |
I'd never seen one of those, they were never used in Europe as far as I know....if you can't roll a doobie in the dark, you probably should't be rolling doobies. And if you can't roll one while driving, using your knees to aim the car, you're life expectancy just went up! |
_________________ 1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile. |
GratefulPhish Samba Member
Joined: July 20, 2020 Posts: 175 Location: Philadelphia
Posted: Mon Jul 20, 2020 7:09 pm Post subject: Re: "Spot light for illuminating heater levers..." ? |
The bulb on my “spot light” is burned out, any idea where to find one? |
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Mon Jul 20, 2020 7:26 pm Post subject: |
gt1953 wrote: |
The heater levers are stationary, unless you grab lever it stays in place. I adjust mine by feel anyway. That little light is or was agreat idea at the time but really worthless. |
it was more to for the DOT rules iirc.dam 2011 |
Posted: Mon Jul 20, 2020 7:41 pm Post subject: Re: "Spot light for illuminating heater levers..." ? |
GratefulPhish wrote: |
if i am not mistaken it should be the same as the fasten belt /ebrake red light on my 74 |
Jimbug57 Samba Member
Joined: October 08, 2002 Posts: 817 Location: Mid Michigan
Posted: Mon Jul 20, 2020 8:32 pm Post subject: Re: "Spot light for illuminating heater levers..." ? |
Sylvania 2721. Most FLAPS carry them. _________________ Repeat after me "I am smarter than metal!" |
Posted: Tue Jul 21, 2020 4:37 am Post subject: Re: "Spot light for illuminating heater levers..." ? |
Thanks, y’all |
creative native Samba Member
Posted: Sat Jul 25, 2020 9:30 am Post subject: Re: "Spot light for illuminating heater levers..." ? |
This light works in my Sun Bug, but I'd like to swap the bulb with an LED. Will one of you experienced men tell me how to replace this light? Do I just push it inside the dash and pull it from underneath to change the bulb? |
AlmostHeavenWV_VW Samba Member
Posted: Sat Jul 25, 2020 12:04 pm Post subject: Re: "Spot light for illuminating heater levers..." ? |
creative native wrote: |
IIRC, reach up behind, squeeze the two small "tabs" which lock it into the dash and push/pull out of dash towards the front seat.
FWIW, an led bulb will not do well with the stock style dimmer control.
If you wish to have brighter light from the little spot light, you can take it out and use a small drill bit to *carefully* widen the small aperture inside the front lens portion from the back side. I did this to mine. _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Posted: Sat Jul 25, 2020 12:17 pm Post subject: Re: "Spot light for illuminating heater levers..." ? |
AlmostHeavenWV_VW wrote: |
If you wish to have brighter light from the little spot light, you can take it out and use a small drill bit to *carefully* widen the small aperture inside the front lens portion from the back side. I did this to mine. |
Thanks for the info! I forgot that this light dims. I already ordered an LED for it. I guess I'll have to see how it does and make a decision. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Sat Jul 25, 2020 1:35 pm Post subject: Re: "Spot light for illuminating heater levers..." ? |
The VW bulb for the spotlight is N 17 7512. Or, Sylvania 2712.
It’s a wheatgrass bulb, and although I’ve never changed mine, Vamram has, and he said he simply pulled the light receptacle toward the back of the car to change the bulb.
Finding an improvement on the stock bulb is probably a waste of time, and having a brighter white light in your dash at night would no doubt be a distraction, anyway.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Posted: Sat Jul 25, 2020 1:49 pm Post subject: Re: "Spot light for illuminating heater levers..." ? |
I actually went with a red LED to add some ambiance lighting, like in the water cooled Beetles. |
buddy boy Samba Member
Joined: June 14, 2009 Posts: 235 Location: vancouver b.c. canada
Posted: Tue May 11, 2021 6:42 pm Post subject: Re: "Spot light for illuminating heater levers..." ? |
I'm thinking of changing mine out for an LED one , would anyone have the correct number for the led bulb? also is this the same bulb that would go into the hazard knob? thanks !! _________________ DVKK Member (Der Volksrennwagen Kafer Klub) |
Posted: Tue May 11, 2021 6:58 pm Post subject: Re: "Spot light for illuminating heater levers..." ? |
buddy boy wrote: |
I'm thinking of changing mine out for an LED one , would anyone have the correct number for the led bulb? also is this the same bulb that would go into the hazard knob? thanks !! |
I ordered an LED for my tiny spot light and the number is 2721. Mine blew while trying to get it installed and have been hesitant since. Please let me know if you get an LED successfully installed on yours. |
Posted: Tue May 11, 2021 7:53 pm Post subject: Re: "Spot light for illuminating heater levers..." ? |
they are reverse polarity , if they don't work you have to flip them . try installing again? _________________ DVKK Member (Der Volksrennwagen Kafer Klub) |
Gerb Samba Member
Joined: June 21, 2012 Posts: 79 Location: Southwest MI
Posted: Sun May 16, 2021 4:04 pm Post subject: Re: "Spot light for illuminating heater levers..." ? |
Here's how "well" my spot light works on my heater controls in my 1973 super beetle.
_________________ ~gerb (Todd G)
'73 Super Beetle Sport Bug
'72 Super Beetle Baja Champion SE
'64 Ruby Red Deluxe Beetle |
edjose17 Samba Member
Joined: November 04, 2019 Posts: 24 Location: Puerto Rico
