Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Wed May 05, 2021 10:55 am Post subject: Re: Rear Shifter Coupler |
CheapBusForSale wrote: |
Thanks Split 66 I got the front connection apart which wasn't easy as it was pretty crusty but I got the rear coupling off and it's ready to put back together just as soon as I get a new screw for iit that somehow stripped coming out. |
Add a little used grease, or new grease, or anti-seize to the bolt and inside the coupler openings so it does not rust onto the shift rods again. _________________ In Stereo, Where Available! |
jeffavatech Samba Member
Joined: March 01, 2009 Posts: 141 Location: Titusville, Florida
Posted: Wed Aug 25, 2021 12:07 pm Post subject: Re: Rear Shifter Coupler |
Looks like a good copy of the early version of coupler used from at least 1950-65 or 66. As to its quality..... _________________ In Stereo, Where Available! |
Split 66' Samba Member
Joined: October 07, 2010 Posts: 1255 Location: Bay Area, California
Posted: Wed Aug 25, 2021 12:10 pm Post subject: Re: Rear Shifter Coupler |
That is tempting, that's my favorite design. It does seem pretty expensive, before shipping to the US. If it lasted 45 years like my stock one, I'd pay that price.
Are you going to get one? _________________ "OG = Original German" -- TheSamba.com dictionary |
Posted: Wed Aug 25, 2021 12:21 pm Post subject: Re: Rear Shifter Coupler |
I ordered 2, These are the correct couplers for 64 to 67 buses. Problem is.....they are in Germany....so, with exchange rate and shipping they will not be a cheap replacement....the noise will go away. These are brand new units. |
Posted: Thu Aug 26, 2021 2:30 pm Post subject: Re: Rear Shifter Coupler |
Definitely interested to hear the details about these when they arrive. Some pics would be great too. _________________ "OG = Original German" -- TheSamba.com dictionary |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 359 Location: Mississippi
Posted: Thu Aug 26, 2021 8:34 pm Post subject: Re: Rear Shifter Coupler |
That's the same coupler that was in my 66 standard microbus back in about 1989. When it came apart, I drilled 3 equally spaced holes (120 degrees apart) through both pieces and used some 6-32 allen bolts and nylon lock nuts with washers to put it back together. I think I kept it somewhere but recently bought a new one from WW that is the typical one you get nowadays. |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2206 Location: UK (South)
Posted: Fri Aug 27, 2021 12:54 am Post subject: Re: Rear Shifter Coupler |
BonTonRoulet wrote: |
When it came apart... |
That's the weakness with those couplers. If the bond between the rubber and metal parts isn't good, or gets contaminated (oil and rubber don't play well), the two halves separate.
My truck came with one that a previous owner had repaired by removing the rubber and welding the two metal halves together.
I bought a new one a few years back, thinking the rubber might help with the gear change (VW put it there for a reason, right?) but it separated before I even got out of the garage. I put the welded one back in. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Posted: Fri Aug 27, 2021 8:11 am Post subject: Re: Rear Shifter Coupler |
Hi, Here's the thing...that coupler is to reduce noise in the cab only...those welded ones work great, but...now you notice it's a lot louder inside....the trick is to replace the shift rod bushings at the front mount and mid point of the shafts (Depending on your year bus). Then replace the coupler, of course make sure it's in neutral first...learning point here..don't ask how I know this...lol. Now you tweek the shift plate to make sure it goes into the gears, don't forget to check reverse. Tighten the shift plate down. Go for a drive and you'll notice the difference in noise. Hope someone finds this helpful. |
HMVWNAB Samba Member
Joined: September 23, 2006 Posts: 1084 Location: Sunshine State
Posted: Thu Jun 16, 2022 5:15 pm Post subject: Re: Rear Shifter Coupler |
Do you put grease in those coupler boots? _________________ What are the last 2 words of the National Anthem?
PLAY BALL! |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Thu Jun 16, 2022 6:38 pm Post subject: Re: Rear Shifter Coupler |
HMVWNAB wrote: |
Do you put grease in those coupler boots? |
I never do. Their purpose is to keep the sealed up area clean and dry. Grease would rot the rubber and attract gunge.
Others may disagree. |
Stocknazi Samba Member
Posted: Fri Jun 17, 2022 9:06 am Post subject: Re: Rear Shifter Coupler |
Silicone grease ONLY for rubber. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
