stevey88 Samba Member
Joined: January 16, 2008 Posts: 1317 Location: Fremont, SF Bay Area
Posted: Thu Sep 22, 2011 12:00 pm Post subject: Can this block be reused ? |
I am getting ready for a engine rebuild. Upon cleaning up the block I plan to use, I found some corrosion on the mating surface of the water jacket. Here are a couple of photos after cleaning up with a Dremo grinding bit and with enhanced contrast so the pits can be seen better.
Can they still be used after filling them with JB Weld? Hate to scrap this case as the studs are corrosion free. _________________ Steve
87 Westfalia full camper 4 speed |
dubbified Samba Member
Joined: March 03, 2010 Posts: 1406 Location: Redmond, WA
Posted: Thu Sep 22, 2011 12:02 pm Post subject: |
JB= NO.
That is a bit of damage you have there.. the amount of damage makes me wonder if there are other areas on your block that are inconspicuous, or not visible which will be another issue later...
I would take it into machinist who has a track history with this specific block.. see if they can have it welded/filled with Aluminum, and surfaced.
May just get the machine work done at a shop, and buy new heads, pistons/liners, seals and do the assembly.
but, yes, that should be OK, as long as properly fixed.
Get in touch with Jerry from Northwest Connecting rod (Seattle, wa), they did this for my block. |
Posted: Thu Sep 22, 2011 7:34 pm Post subject: |
dubbified wrote: |
JB= NO.
May I ask how much it cost you to repair yours ?
I have another block ( 170K miles on this block ) that I can use. The corrosion on the surface is less but there are still pits after cleaning up. The head studs on this block has some rust though. _________________ Steve
Posted: Sun Sep 25, 2011 7:45 am Post subject: |
I was already in for a rebuild, he charged me 100 bux, I saw it when it came out.. it wasnt pretty..
I'm glad I had it rebuilt, it was about to buckle.. |
