Brickwerks Samba Member
Joined: April 11, 2010 Posts: 214 Location: West Yorkshire - UK
Posted: Sat Feb 11, 2012 1:59 pm Post subject: |
Looks like a JesseLai tank. _________________
whynotvw wrote: |
I see you wanna start some shit. whats your fuckin probelm? your selling your measly shitty products. bloody brit |
BoxsterGT Samba Member
Posted: Tue Feb 14, 2012 11:51 am Post subject: |
akvan-
Nice to hear the job is complete. Good to learn about the other grommets, just can't get away from them I guess.
Sorry, I never thought to say to use clamps, but they are necessary. Would you advise on longer hoses so theres less chance of binding? Do you remember what length you used?
Very happy it worked out. I certainly hope this is as permanent a "Fuel Tank Vent Fix" as possible.
Brickwerks-
Thank you for the lead. I have contacted them.
Len
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
warezdog Samba Member
Joined: November 24, 2016 Posts: 25 Location: Southwest Florida
Posted: Tue Jan 17, 2017 7:02 pm Post subject: Re: Permanent Fix for Vanagon Fuel Tank Vents |
Hate to be the one to beat a dead thread back to life but redoing a 82 westy for my daughter and the tank is shot so I'd like to do this mod when I buy a new tank.
Soooooo are these still available? |
mad.macs Samba Member
Joined: August 17, 2007 Posts: 230 Location: Woolwich Maine
Posted: Wed May 10, 2017 6:34 pm Post subject: Re: Permanent Fix for Vanagon Fuel Tank Vents |
I made my own set of tank vents today I think i got away with around $12 in brass for each fitting, but the best part is it uses standard fuel line now. I have 3 vans to do this to, so I was looking for a chapter way out than the $70-90 for a premade kit that still uses hard to find hoses.
[/img] _________________ '84 Rivi Vanagon Auto Trans, Stock WBX |
Posted: Wed May 10, 2017 6:44 pm Post subject: Re: Permanent Fix for Vanagon Fuel Tank Vents |
mad.macs wrote: |
[/img] |
NICE!!
Details PLEASE PURDY PURDY PLEASE!! Part numbers, source, links, ANYTHING!!
OH and thank-you! |
Posted: Wed May 10, 2017 7:05 pm Post subject: Re: Permanent Fix for Vanagon Fuel Tank Vents |
The main body is made from 1" Naval Brass rod, turned on my WWII vintage lathe. I used standard 1/4 in and 3/8 hose barbs from the hardware store and turned the threads off. I don't have a 3/8 pipe tap.. I hand drilled the holes for the fitting, and Soldered them into the holes.
The large fitting I out in at 30° and the 1/4 inch is at 45°.
They took an Hour and a half to make I think. _________________ '84 Rivi Vanagon Auto Trans, Stock WBX |
Posted: Wed May 10, 2017 7:56 pm Post subject: Re: Permanent Fix for Vanagon Fuel Tank Vents |
Well I don't have metal lathe so that shoots that idea but boy do those look great! |
Posted: Thu May 11, 2017 5:53 am Post subject: Re: Permanent Fix for Vanagon Fuel Tank Vents |
True, it does not address all of the issues, my grommets were OK, one of the Tees was cracked, and the crossover tube was partially rotted. Seeing that kits were $70-$90 and still used Nylon Tees, and expensive hose, I just wanted to get the cost down for future repairs. Since I don't need expensive hoses, and these Tees will last theoretically forever, I'm still going to call it a win.
Maybe someday I'll fab up an 18 Gal, no saddle tank, with just one vent. _________________ '84 Rivi Vanagon Auto Trans, Stock WBX |
Posted: Thu May 11, 2017 6:20 pm Post subject: Re: Permanent Fix for Vanagon Fuel Tank Vents |
djkeev wrote: |
They are beautiful (makes me miss having a metal lathe) but they don't solve the base problem of the rubber grommets decaying and leaking.
Dave |
Ya lack of lathe kills it for me but I love the look.
Going with your method, seems to be a proven solution and since I'm going new tank and fittings for my daughters van I want to do it only once and not worry about it. |
