kenshapiro2002 Samba Member
Joined: April 26, 2013 Posts: 1826 Location: Bawlmer Hon
Posted: Thu Feb 12, 2015 9:17 am Post subject: |
Thanks. Great work on the bus. _________________ Looking for a correct 1967 rear seat
Looking for '67 Engine / Block HO 183xxx - HO 194xxx |
mstra Samba Member
Joined: March 13, 2006 Posts: 32 Location: Wingdale NY
Posted: Sat Dec 03, 2022 6:21 am Post subject: Re: How to restore these rotten buffer supports on the RGBs |
This is an old post but if someone ends up here as I did the parts are now available at BBT and CIP1.
Knowing what to search was the hard part.
REAR SUPPENSION SUPPORT ON SWING AXLE TUBE
Who would have known?
https://www2.cip1.com/vwc-211-501-505/ |
Mile High Puma Samba Member
Joined: November 11, 2009 Posts: 212 Location: Salida, Colorado
Posted: Sat Dec 03, 2022 8:15 am Post subject: Re: How to restore these rotten buffer supports on the RGBs |
mstra, thanks for the update, good to know! _________________ 1965 Velvet Green DC |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4574 Location: St Charles, MO
Posted: Sun Dec 04, 2022 10:00 am Post subject: Re: How to restore these rotten buffer supports on the RGBs |
Hi "mstra",
Thanks for the update tip on where to locate the reproduction part! I should have know that Bob at BBT would have that part reproduced and provide it to his network of retailers. BBT Bob is awesome!
Thanks again, this will make this repair much easier on a '67 Bus transaxle I have stored away as a spare!
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1160 Location: Woodstock, NH
Posted: Sat Jul 15, 2023 4:50 pm Post subject: Re: How to restore these rotten buffer supports on the RGBs |
I've just run into this issue - on my '65. This thread is great - and the link to the readily available part is excellent.
I'm trying to figure out how important these parts are, and if I buy the parts - can they be welded on the bus - or do you need to remove the rear axle to do this?
It sounds like some earlier buses didn't even have them... _________________ -Kevin
Lincoln, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2211 Location: UK (South)
Posted: Sun Jul 16, 2023 2:16 am Post subject: Re: How to restore these rotten buffer supports on the RGBs |
kguarnotta wrote: |
It sounds like some earlier buses didn't even have them... |
They only have value if your bus was built with the brackets on the frame that the rubber buffers hit (or if someone else has welded the brackets on to the frame). Without those brackets they're pointless. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Posted: Sun Jul 16, 2023 6:39 am Post subject: Re: How to restore these rotten buffer supports on the RGBs |
My bus has the brackets. I was just reaplacing my shocks, and bumped the bumper with my arm...and it came off. When I looked at the spot where it is supposed to attach - it was totally rusted out, and the nub that the rubber piece attaches too was completely rusted off. Just like th pics earlier in this thread.
I was wondering if it is worth it or needed to have a new mount installed, and if so - can they be welded in place, or do you need to remove the beam. I'll see what my mechanic says - I am not a welder _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
