Do I have a dished or flat cam?
scratchs68
scratchs68 is offline
PostPosted: Fri Sep 23, 2011 4:41 pm    Post subject: Do I have a dished or flat cam? Reply with quote
Im looking to replace my oil pump on my 1500cc engine. Im not sure what to look for to tell what type of cam I have. What should I look for?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Sep 23, 2011 4:42 pm    Post subject: Reply with quote
It should have a flat cam, but to be sure, remove the oil pump and look inside.
Dished left, flat right
Glenn
Member #1009
#BlueSquare
scratchs68
PostPosted: Fri Sep 23, 2011 4:58 pm    Post subject: Reply with quote
THANKS GLEN. I never got a chance to talk to you at flanders. I'm the guy that was parked next too you with the green 68. Laughing
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Fri Sep 23, 2011 5:03 pm    Post subject: Reply with quote
If your engine is original 1500 you might use a type 3 oil pump which is slightly larger in capacity.
scratchs68
PostPosted: Mon Sep 26, 2011 5:51 pm    Post subject: Reply with quote
Since I don't know much about the inside of my engine. What would the diff mean between the two cams. Is one better then another?
Mr. 010
Glenn is offline
PostPosted: Mon Sep 26, 2011 5:57 pm    Post subject: Reply with quote
Not sure why they changed bit all performance cams are flat. It just makes it easier since vendors only need to carry one oil pump.
Glenn
Member #1009
#BlueSquare
torsionbar
torsionbar is offline
PostPosted: Mon Sep 26, 2011 6:24 pm    Post subject: Reply with quote
nothing is different in the cam profile. they perform exactly the same because they are the same. the only difference is in the cam gear attachment, 3 vs 4 bolts and dished or flat cam end.
Max Welton wrote:
[air cooled vw's] are no longer suitable for the general public. The owner has to be be able to maintain the car. And that is after fixing all the deferred maintenance items and ill-conceived modifications. If you can't do those things you are pretty much screwed.
gevmage
gevmage is offline
PostPosted: Mon Sep 26, 2011 6:39 pm    Post subject: Re: Do I have a dished or flat cam? Reply with quote
And before putting in the pump, be sure that you've blueprinted it. Sand the gears to the same depth, the body to match, and the cover plate should be shiny enough to shave in. And make sure the shaft has the proper amount of engagement.
I bought my new oil pump from Gene Berg; it was very nice and had, had pretty good fit (though I did do a bit of sanding) and good installation instructions.
Craig Steffen
Craig Steffen
Getting my 1972 Super back on the road
Chronicling it on YT
(channel name "figuring stuff out dot net")
Physicist, pilot, computer person
craigsteffen.net
vw_hank
vw_hank is offline
PostPosted: Tue Sep 27, 2011 1:19 am    Post subject: Reply with quote
71 and newer 1600s got the dished cam, the dish was to make room for A bigger oil pump/with A bigger drive gear. performance cams as posted are all flat and require A special pump that sticks out further.
1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods!
