25 & 36 hp fuel pump
70deluxebus
70deluxebus is offline
PostPosted: Mon Sep 26, 2011 1:37 pm    Post subject: 25 & 36 hp fuel pump Reply with quote
Does anyone know the difference and how to tell them apart? Thanks
36hplandspeedracer
36hplandspeedracer is offline
PostPosted: Mon Sep 26, 2011 2:52 pm    Post subject: Reply with quote
Lindy, contact Ed Fall at Vintage Werks for the specific details. He is the premier rebuilder of these components and can supply you with specific details for indentification.
[email protected]
I hope this is helpful..................
Burly
henry roberts
henry roberts is offline
PostPosted: Mon Sep 26, 2011 4:30 pm    Post subject: Reply with quote
here is a rough run down, the emphasis being on rough.
split etc till 1953? flat top. towards the end of this style they changed from an 8mm fuel line to a 6mm fuel line, there were probably heaps of other changes.
till mid 1955 wave top with drain screw on the side:
a few months? only mid/late 55, wave top with the boss for the drain screw but not tapped/fitted with the screw.
sorry can't find a pic atm.
56 wave top with no screw: edit, this may not be an actual production model.
circa 57, ribbed top with short outlet:
changed in 58? to ribbed top with tall outlet:
the last style
some useful threads:
54/5 engine thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=179439
58/9 thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=401420
PostPosted: Mon Sep 26, 2011 8:29 pm    Post subject: Reply with quote
Nice breakdown.
Some more info:
53s are 6mm because they have the carburetor with the accelerator pump.
I've never heard that, I think that might just be a mismatched top and bottom.
For example, the bottom wore out so it was replaced while the original top was retained.
henry roberts
PostPosted: Mon Sep 26, 2011 10:10 pm    Post subject: Reply with quote
i could be wrong, it's been known to happen Smile
70deluxebus
PostPosted: Tue Sep 27, 2011 6:44 am    Post subject: Thanks guys. Reply with quote
Appreciate the help.
WVWZ
WVWZ is offline
PostPosted: Thu Mar 17, 2016 3:46 pm    Post subject: Re: 25 & 36 hp fuel pump Reply with quote
Nice write up, I've been looking up and down thesamba and can't find a thread on how to rebuild a 36hp fuel pump. Can anyone here direct me to the proper thread? Thank you.
looking for a 55 euro!
PostPosted: Thu Mar 17, 2016 5:39 pm    Post subject: Re: 25 & 36 hp fuel pump Reply with quote
I don't know if there is one but I found these 2 threads:
http://www.thesamba.com/vw/forum/viewtopic.php?t=86375
http://www.thesamba.com/vw/forum/viewtopic.php?t=465328
oldbusboy Premium Member
oldbusboy is offline
PostPosted: Thu May 18, 2017 10:03 pm    Post subject: Re: 25 & 36 hp fuel pump Reply with quote
If I currently have stock 6mm fuel pump and want to run a Mann fuel filter that is 8mm how can I make the input line into the pump 8mm so I can use the filter?
Trevor
1958 Kombi
Looking for pressed rear bumper. Rear hatch, rear seats.
Mr. OGPaint
Mr. OGPaint is offline
PostPosted: Fri May 19, 2017 1:48 pm    Post subject: Re: 25 & 36 hp fuel pump Reply with quote
Perhaps a brass adapter bushing similar to the ones VW offered for retrofitting 6mm components on cars with 8mm fuel systems....same concept but in reverse.
https://instagram.com/mr_ogpaint
Patrick Hall
Peter_Plade
Peter_Plade is offline
PostPosted: Sat May 20, 2017 12:57 pm    Post subject: Re: 25 & 36 hp fuel pump Reply with quote
Trevor
If you comes up with a solution please post it here as I'm planning the to the same thing.
Original 1954 3 fold oval
http://vw-bluehats.blogspot.com/
Suboval
Suboval is offline
PostPosted: Mon May 22, 2017 12:09 pm    Post subject: Re: 25 & 36 hp fuel pump Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=478666&highlight=fuel+pump+adapter
It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history.
