Propane Leak inside
mwsnow
mwsnow is offline
PostPosted: Tue Sep 27, 2011 4:27 pm    Post subject: Reply with quote
vela123321 wrote:
There are several fittings around the tank. If any of them are leaking, the smell could easily make it up to the inside of the van. I just had this happen...
Propane is heavier than air, and falls to the ground instead of rising into the body. I would be suspicious of in internal leak.
vela123321
vela123321 is offline
PostPosted: Tue Sep 27, 2011 4:15 pm    Post subject: Reply with quote
SWbySWesty wrote:
Should I really worry about outside on tank itself? That would make it smell around the van but not inside of it. At least that's what I'd assume. Sigh...just wish I had TIME! No daylight to use until Thursday.
________________________
1987 Westfalia Vanagon 2.1 automatic
2014 VW TDi Jetta Sportwagen (Dieselgate)
2016 BMW 328i
1967 Bug... given to a friend
others not VW... Toyota, Audi, Volvo, Datsun, International Harvester
SWbySWesty
SWbySWesty is offline
PostPosted: Tue Sep 27, 2011 3:06 pm    Post subject: Reply with quote
1986 Westy - Billie Jean
A Westy with a Jeep heart (Pura Vida)
www.theadventurebrigade.blogspot.com - Latest update: Johnson Valley - Nov 22, 2011
jackbombay
jackbombay is offline
PostPosted: Tue Sep 27, 2011 2:56 pm    Post subject: Reply with quote
SWbySWesty wrote:
So I should take apart the top of the stove to spray? Sorry for the ignorance. I'm also at work and not looking at it right now.
Start with the easily accessible connections first.
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies Smile
Samba ad here.
DIY artificial rain gutters (ARGs)
SWbySWesty
PostPosted: Tue Sep 27, 2011 2:42 pm    Post subject: Reply with quote
pioneer1
pioneer1 is offline
PostPosted: Tue Sep 27, 2011 2:39 pm    Post subject: leak Reply with quote
If you are sure it's propane and not a dead critter in the cupboard...turn on the gas and test all fittings with a spray solution of soapy water-no smoking.
"Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project
r39o
Samba Polizei
r39o is offline
PostPosted: Tue Sep 27, 2011 2:39 pm    Post subject: Reply with quote
I had the same thing. It WAS the valve.
You need to start with the spray soapy water on connections and the valve, etc, to find bubbles.
SWbySWesty
PostPosted: Tue Sep 27, 2011 2:37 pm    Post subject: Propane Leak inside Reply with quote
After having the van sit for a while, I will open the door and get a wiff of propane inside the van. Shocked
Where do I start trouble shooting? I turned the main valve off whenever driving or not in use, I figured it was leaking out with less pressure, but wouldn't the line empty and stop delivering gas? Either position gives a smell.
