Where does this thing bolt to?
llCRAIGll_
llCRAIGll_ is offline
PostPosted: Fri Jan 09, 2015 9:05 am    Post subject: Where does this thing bolt to? Reply with quote
I have a 73 super beetle convertible that I've been trying to get driving and I can't figure out where this steering arm thing bolts to. Any help will be greatly appreciated. (It's on the front passenger side)
beetlenut
beetlenut is offline
PostPosted: Fri Jan 09, 2015 11:34 am    Post subject: Re: Where does this thing bolt to? Reply with quote
llCRAIGll_ wrote:
In this photo, do you see the three bolts to the left of the strut? Three of the four bolt holes of the Pitman arm (that's the thing you are asking about) bolt up to the three bolts going through the body. So only three of the possible four bolt holes are used. That's probably what was throwing you off.
scrapyards are for quitters
Wetstuff wrote:
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again.
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104
Mr.Duncan
Mr.Duncan is offline
PostPosted: Fri Jan 09, 2015 12:42 pm    Post subject: Reply with quote
jesus.
Thats your idler arm.
its supposed to be bolted up for your steering.
That really needs to be fixed before you attempt to driver at all.
Ill go take photos tonight to show you.
(Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle
JasonBaker
JasonBaker is offline
PostPosted: Fri Jan 09, 2015 2:00 pm    Post subject: Reply with quote
Mr.Duncan wrote:
jesus.
YES, Listen to Mr. Duncan
Mr.Duncan
PostPosted: Fri Jan 09, 2015 2:02 pm    Post subject: Reply with quote
I get home around 7-8pm tonight.
Me and you have the same strut/tierod/steering setup.
Ill take photos, and post them here!
1966 Ghia (sold)
1966 Red Beetle
beetlenut
PostPosted: Fri Jan 09, 2015 2:54 pm    Post subject: Reply with quote
Mr.Duncan wrote:
jesus.
Yep, Idler arm. The Pitman is on the other side coming out of the steering box. OP just look on the other side how your steering box is bolted on. Same thing only on the other side for the Idler arm.
