what size is the axle nut?
sanderbing
sanderbing is offline
PostPosted: Fri Sep 30, 2011 10:05 am    Post subject: what size is the axle nut? Reply with quote
I've read about every thread on removing the rear brake drums but mine aren't budging - so I need to take it off via a hub puller but must first remove the axle nut. Any idea what size that is?
Wildthings
Wildthings is offline
PostPosted: Fri Sep 30, 2011 10:25 am    Post subject: Reply with quote
I think it is a 46mm, but I use a fractional socket that fits okay. You can buy a cheapy slug wrench to fit it from many VW parts places.
If your vehicle drives, you can take it in to a truck shop and have them loosen it as well.
shiningstar76
Samba Brewer
shiningstar76 is offline
PostPosted: Fri Sep 30, 2011 11:12 am    Post subject: Reply with quote
A little advice on putting that back on. It's 240 ft lb torque. And it has to be on there that tight. I'd consider putting it on as tight as you can and having a shop torque it to spec.
KK4NTP
92 Loyale
72 Westy CB 1700 Weber
94 Legacy Wagon EJ22 334,000 miles
02 Outback H6 225,000 miles
75 C30 3+3 long bed dually- aka The Prius
LIVE FREE OR DIE
Wildthings
PostPosted: Fri Sep 30, 2011 11:52 am    Post subject: Reply with quote
The torque is a minimum of 240 ft*lbs, and then continue tightening until the cotter pin holes line up. On the Vanagon they went to 360+ ft*lbs using essentially the same parts and techniques, so that is what I do on the my Bays.
sanderbing
PostPosted: Fri Sep 30, 2011 12:05 pm    Post subject: Reply with quote
got it - the 1 13/16 was available and the same as the 46 mm. Unfortunately, I can't get it off. I'm using a level and pulling so hard it lifts up that corner of the bus. And the bus isnt registered so I cant drive to a shop. I'll try hitting it with some oil a few days and hope that works its way through.
Wildthings
PostPosted: Fri Sep 30, 2011 12:19 pm    Post subject: Reply with quote
Go ahead and order yourself up one of the slug wrenches or buy one local if you can. They are only about $8 plus shipping if needed.
http://busdepot.com/details.jsp?partnumber=5747
Desertbusman
Desertbusman is offline
PostPosted: Fri Sep 30, 2011 12:30 pm    Post subject: Reply with quote
Yes, the "Whacker Tool" is super handy. Use your breaker arm for the force and a sledge on the lug portion to break the nut loose.
http://www.airheadparts.com/vintage-vw-parts/vanagon-tools/46mm-rear-axle-nut-removal-tool
The 36mm version is for gland nuts and fan nuts on early Bays and axle nuts on bugs.
SGKent wrote:
There is no question in my mind from my experiences engine machining, building, racing, and with other engine builders that no one here can build a bus engine which is more reliable than I can.
Evil or Very Mad Evil or Very Mad Rolling Eyes Laughing Razz Laughing Shame on you Laughing Laughing Rolling Eyes Laughing Laughing SICKO B.S. Evil or Very Mad Evil or Very Mad Laughing Shocked Shocked Laughing Twisted Evil d'oh! Liar Liar Liar
71 Superbug
71 Westy
BumbleBus
BumbleBus is offline
PostPosted: Fri Sep 30, 2011 12:32 pm    Post subject: Reply with quote
sanderbing wrote:
I can't get it off.
This worked for me. WHACK, WHACK! Off she came eventually. Put back on @ 253ftlbs from standing on a cheater bar about 13 1/2 inches out (I'm about 225-230lbs) + a little more to line up the cotter and I added a tiny bit of anti-seize to the threads. Snug as a bug since and easy to get back off. Good luck!
'72 L11H Campmobile in various stages of disrepair. Just bumbling along...
sanderbing
PostPosted: Fri Sep 30, 2011 1:07 pm    Post subject: Reply with quote
didn't that pry bar on the lug bolts mess up the threads?
and im not exactly sure how that tool works
aeromech
aeromech is offline
PostPosted: Fri Sep 30, 2011 1:37 pm    Post subject: Reply with quote
My Ingersol Rand 1/2" drive impact gun usually does the trick with about 140 psi from my big ass compressor.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Wildthings
PostPosted: Fri Sep 30, 2011 1:46 pm    Post subject: Reply with quote
You can put the lug nuts on if you are worried about damaging the threads.
The tool works by whacking it with a small (3-8 lb) sledge hammer. You can also add extra force by putting a breaker bar through the square hole and having someone stand on it while you whack.
kreemoweet
kreemoweet is offline
PostPosted: Fri Sep 30, 2011 1:52 pm    Post subject: Reply with quote
That tool works by slamming on the heavy outer part with a BFH. Yes, it
works well for the purpose, but you need to realize that you are also
slamming on (1) the axle shaft splines, (2) the wheel bearings, (3) both
constant velocity joints, (4) the differential gears, and (5) so on into
the transmission. Most guys like to pretend they're not doing any damage
to those vital parts, but those of us who have some appreciation for the
laws of physics have a different opinion. Personally, I wouldn't use anything
except a 3/4" drive socket and a cheater bar as long as it takes.
'67 bug: seized by the authorities
aeromech
aeromech is offline
PostPosted: Fri Sep 30, 2011 1:57 pm    Post subject: Reply with quote
I have used the whacker in the past many times. The part that scares me is swinging the hammer and possibly hitting the bus with it. It's never happened but I'm always concerned about it. An impact gun is an amazing tool and every mechanic should have one.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
sanderbing
PostPosted: Fri Sep 30, 2011 2:56 pm    Post subject: Reply with quote
i do have an impact gun but not sure if its a 3/4 drive as needed for the 1 13/16 socket, nor do i know if the socket will take the stress from the impact gun as its not an impact socket - I might be in for an adventure. plan B would be the whacker tool I guess
aeromech
aeromech is offline
PostPosted: Fri Sep 30, 2011 3:05 pm    Post subject: Reply with quote
I use an adapter for the 3/4 drive sockets.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
VDubTech
VDubTech is offline
First things first....what year Bus are we talking about here? If it's 72-79 you don't have to remove the hub nut to take off the drum.
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
BumbleBus
PostPosted: Fri Sep 30, 2011 4:14 pm    Post subject: Reply with quote
Not enough to make any difference. The nuts spin right on still easy peasy.
BumbleBus
PostPosted: Fri Sep 30, 2011 4:19 pm    Post subject: Reply with quote
Stood (and jumped on it a few times even) at the very end of a 6 foot cheater with zero results with mine. That whacker tool is the only thing that worked for me. I think some PO mechanic had air-gunned that thing on waaaaayyyy too tight and sitting in a open field for years didn't help matters either. It's all circumstantial. Wish I had a big ass impact wrench myself, but couldn't justify the cost for a 1 time use thing.
Randy in Maine
Randy in Maine is offline
PostPosted: Fri Sep 30, 2011 4:21 pm    Post subject: Reply with quote
The question to be asked.
I have a dollar that says it is a 1978.
sanderbing
PostPosted: Fri Sep 30, 2011 4:40 pm    Post subject: Reply with quote
yes, its a 78. and I did get the drums off but still need to get the hubs off to replace the backer plates. Plus i have the hardware kit and it will be much easier without the hub
