Tiico and/or Kennedy flywheel weight ?
syncroserge
syncroserge is offline
PostPosted: Sun Oct 02, 2011 7:45 am    Post subject: Tiico and/or Kennedy flywheel weight ? Reply with quote
Putting together an AFN setup for a friend's syncro. He has the adaptor plate and flywheel but there are no markings of any kind on them.
Anybody know how much they weigh or have one they can put on a scale?
I will call Kennedy but what is the contact info for who now deals the Tiico?
merci les copains Smile
westyventures
westyventures is offline
PostPosted: Sun Oct 02, 2011 8:20 am    Post subject: Reply with quote
All Kennedy plates I've seen have a timing hole below the manifold side of the engine, and marks for TDC on the backside of the flywheel.
But - if I were building this, I would never use a Kennedy plate to build a Syncro TDI. Just not as strong as the proper bell housing setup - risk of pulled studs, flexing, cracking. I've seen it before.
syncroserge
PostPosted: Sun Oct 02, 2011 8:45 am    Post subject: Reply with quote
Agreed..not a big fan of the adaptor plate either. I've been pushing hard
for a "proper" Wink setup..
thanks for the Kennedy info.
rcook52459
rcook52459 is offline
PostPosted: Sun Oct 02, 2011 7:38 pm    Post subject: Reply with quote
these are the people for tiico conversions now. http://www.foreignautosupply.com/Tiico_Owners_Page.html
85 westy tiico conversion.auto trans triumph TR250 1980 Suzuki GS1000l
Vanagon Nut
Vanagon Nut is offline
PostPosted: Thu May 03, 2018 9:02 pm    Post subject: Reply with quote
Hi folks.
This is for a "Rabbit" Kennedy adaptor kit but is likely the same for all applicable Kennedy flywheels.
Is the #1 TDC mark on the Kennedy flywheel a countersunk hole? Or?
Thanks
Neil.
1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN
mathieux46
mathieux46 is offline
PostPosted: Tue Dec 08, 2020 9:10 pm    Post subject: Re: Tiico and/or Kennedy flywheel weight ? Reply with quote
Hi,
Kennedy confirmed me their flywheel weight for a 3600 VW inline kit weight is 17 lbs.
I'm now wondering how much this flywheel would improve smoothness on my TDI swap which currently have a light 12 lbs flywheel.
Thanks
Mathieu
danfromsyr
danfromsyr is offline
PostPosted: Tue Dec 08, 2020 9:35 pm    Post subject: Re: Tiico and/or Kennedy flywheel weight ? Reply with quote
ALOT
diesels are no place for a lightened flywheel
mathieux46
PostPosted: Wed Dec 09, 2020 10:01 am    Post subject: Re: Tiico and/or Kennedy flywheel weight ? Reply with quote
Danfromsyr,
Thanks!!
Seeking the heaviest flywheel I can use with an adaptor plate. Up to now it seems to be 17 lbs, which is still much lighter than a VW diesel SMF ( 22 lbs).
Would you know any other options?
Thanks
Mat
