bugbenginer Samba Member
Joined: December 26, 2012 Posts: 147 Location: boise, id
Posted: Thu Mar 28, 2019 9:30 pm Post subject: Re: Installing a Type 1(upright cooling)engine into a Type 4 72+ FAQ |
I would be interested in the mounts, I bought a bus that already had the covers in. And it runs amazing but didn’t have the support bracket or engine tin so I’m just doing that kind of stuff. Didn’t want to convert it back to a type 4. _________________ [url=http://www.vw-mplate.com/mplate2-43483.png]Click to view image[/URL] |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Thu Apr 11, 2019 2:07 am Post subject: Re: Installing a Type 1(upright cooling)engine into a Type 4 72+ FAQ |
Hypothetically speaking, could the T1 doghouse fan shroud be removed in situ with a late bay access hatch? All the late T1 buses I work on are Euro-spec sans hatch……
www.airschooled.com |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51145 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Apr 11, 2019 6:27 am Post subject: Re: Installing a Type 1(upright cooling)engine into a Type 4 72+ FAQ |
Intriguing hypothesis, you'd have to try shoving a shroud through a hatch, it may not be wide enough to let the shroud rise high enough to clear the oil cooler. Next time I'n near both of those parts I'll see if it fits. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Apr 11, 2019 8:08 pm Post subject: Re: Installing a Type 1(upright cooling)engine into a Type 4 72+ FAQ |
Would there be a huge difference in what carb is ran on a 1500 or 1600 engine with the mid conversion? Would it really matter that much weather it’s a 34 or a 31? _________________ [url=http://www.vw-mplate.com/mplate2-43483.png]Click to view image[/URL] |
Posted: Fri Apr 12, 2019 1:12 am Post subject: Re: Installing a Type 1(upright cooling)engine into a Type 4 72+ FAQ |
busdaddy wrote: |
Intriguing hypothesis, you'd have to try shoving a shroud through a hatch, it may not be wide enough to let the shroud rise high enough to clear the oil cooler. Next time I'n near both of those parts I'll see if it fits. |
Ha! I almost took a bath on a client when I told him I could assist with a project that required lifting the shroud. His "79 bus with a beetle engine" turned out to be a hyper low-milage Swiss Army bus with the original T1 engine and all the OG doodads but no hatch. Couldn't lift the shroud there, but one could theoretically get as far as the crankshaft with an ATV jack and Muir's Phase I tool kit without jacking up the car or taking the engine out from underneath the car… That W I D E rear tin sure frees things up to move about the compartment…
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Mon Jun 10, 2019 1:30 pm Post subject: Re: Installing a Type 1(upright cooling)engine into a Type 4 72+ FAQ |
A fairly large red wire with ring terminals on each end. The other end goes to your starter where it junctions to the battery positive. You could just go to the battery but it’s not as clean of an installation _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
babysnakes Samba Member
Posted: Mon Jun 10, 2019 5:17 pm Post subject: Re: Installing a Type 1(upright cooling)engine into a Type 4 72+ FAQ |
asiab3 wrote: |
Robbie |
I pulled the shroud from my '72 (1600 upright) to replace the alternator. I am running 34ICTs. It was a PITA but got it done. |
Posted: Mon Jun 10, 2019 8:24 pm Post subject: Re: Installing a Type 1(upright cooling)engine into a Type 4 72+ FAQ |
So, I know I should have a 7/71 accelerator cable, but I don’t it’s still the FI cable that was there and the previous owner ran it that way. Will the 70/71 bus cable work through the stock 75 tube all the way back to the carb and clip on the pedal assembly perfectly, or will I have to modify a new way to hook the cable up? _________________ [url=http://www.vw-mplate.com/mplate2-43483.png]Click to view image[/URL] |
Posted: Wed Jun 12, 2019 9:29 am Post subject: |
babysnakes wrote: |
Fresh 1600 with 002 ready for installation into a '72
Don't forget your T-4 foam seal.
It was cool seeing my mustache bar. |
Do these 2 tin pieces only replace the front and real tin pieces or are there more that isn’t needed anymore because of these 2 tin pieces? _________________ [url=http://www.vw-mplate.com/mplate2-43483.png]Click to view image[/URL] |
Posted: Wed Jun 12, 2019 12:00 pm Post subject: Re: Installing a Type 1(upright cooling)engine into a Type 4 72+ FAQ |
The front one replaces the beetle style one over the bellhousing, the rear one connects to your existing breast plate.
As for throttle cables I doubt either option will fit perfectly, try the 71 version, it's likely very close. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
germansupplyscott Samba Member
Posted: Tue Jul 07, 2020 5:36 pm Post subject: Re: Installing a Type 1(upright cooling)engine into a Type 4 72+ FAQ |
Not sure if this belongs here, or maybe in the 'Hall of Shame' thread, but this is a pretty 'interesting' upright engine in a late Bus. This seems to have been a running and driving engine in the vehicle - until it stopped running maybe. Not sure on the whole story behind it but I wish there were more photos.
_________________ SL |
Posted: Tue Jul 07, 2020 5:53 pm Post subject: Re: Installing a Type 1(upright cooling)engine into a Type 4 72+ FAQ |
I’d give that engine about 60 minutes of run time before it craps _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Tue Jul 07, 2020 6:07 pm Post subject: Re: Installing a Type 1(upright cooling)engine into a Type 4 72+ FAQ |
, well........., technically if you never stop moving.................., maybe a little like that bus in the movie Speed!
I'm posting it in the engine abortion thread if you haven't already _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Jul 07, 2020 7:20 pm Post subject: Re: Installing a Type 1(upright cooling)engine into a Type 4 72+ FAQ |
I didn't know there was such a thing but yes post, it's worthy of that. _________________ SL |
Posted: Tue Jul 07, 2020 9:32 pm Post subject: Re: Installing a Type 1(upright cooling)engine into a Type 4 72+ FAQ |
germansupplyscott wrote: |
I didn't know there was such a thing but yes post, it's worthy of that. |
Definitely, but upon closer inspection it's a type 4, not that it makes any difference in this case. here's the thread, as the title states "come see the horror" https://www.thesamba.com/vw/forum/viewtopic.php?p=9402166#9402166 _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
67sash Samba Member
Joined: December 14, 2012 Posts: 176 Location: Minnesota
Posted: Fri Jul 10, 2020 6:37 am Post subject: Re: Installing a Type 1(upright cooling)engine into a Type 4 72+ FAQ |
It is good to see this thread back moving.
An update on my 1776 type 1 in my 73 Hightop. We have just recently completed about 12,000 miles since the motor was installed. Still running NO mustache bar. The motor has been amazing and taken us on numerous adventures! The smokey mountains in just over a week. I am really happy I didn't overthink this transplant and use real-life examples to guide versus opinions. I am not against the mustache bar modification and fitting, I just spend my free time driving the bus and using it rather than it sitting. Baja guys have hung their motors.....forever it seems.
RalphWiggam Samba Member
Joined: February 02, 2018 Posts: 906 Location: SouthEast
Posted: Fri Jul 10, 2020 10:34 am Post subject: Re: Installing a Type 1(upright cooling)engine into a Type 4 72+ FAQ |
I think a lot more folks are going to be doing this conversion in 10-15 years with the way good type4 parts are going.
I personally dont really care too much what engine is in my bus as long as it makes decent power and can take me where I want to go. I dont really need to get 100K between rebuilds. 50-60k is just fine by me. |
RWK Samba Member
Posted: Fri Jul 10, 2020 4:13 pm Post subject: Re: Installing a Type 1(upright cooling)engine into a Type 4 72+ FAQ |
First time reading this, lol, I brought back the tins from Mexico,( on an airplane no less, goofy souvenir, got lots of strange looks!) in the late 80s, always figured on putting a T1 in a later bus, but the tins used the T1 rear breast plate as I recall it wasn't part of the conversion plate, Mexico didn't use the T4 engine, we rented them several times while there, there was always 6 or more of us and they were the best deal, we drove them to all the ruins. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Posted: Fri Jul 10, 2020 4:27 pm Post subject: Re: Installing a Type 1(upright cooling)engine into a Type 4 72+ FAQ |
67sash wrote: |
We have just recently completed about 12,000 miles since the motor was installed. Still running NO mustache bar. |
Thanks for the update, nothing beats real world testing. Good to know you can get away without it if you choose that route. Myself I'll still put one in just because VW thought it needed it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
