Jon_slider Samba Member
Posted: Tue Oct 23, 2012 1:36 pm Post subject: |
> I hate rattling.
good point
The Burley latch ramp is definitely less rattle prone than the Gary Lee latch. The Burley ramp basically puts a bind on the hinges to stop any play.
The RMW latch has an adjustable stop, so it is better than the Gary Lee in terms of being able to stop it from rattling.
To me, the Heim joints of the Gary Lee and the RMW, are more elegant and more refined than the fat poly bushings on the Burley rack.
I agree all 3 options are effective for their intended purposes.
The Gary Lee being the most expensive by far, it uses Heim joints.
The Burley is next most expensive, no Heim joints. (originally the Burley was built to be the lowest cost, below $400, since raised to 675)
The RMW is the lowest cost of the 3, (and imo the best because of the adjustable latch rattle stop, and the ability to lock the open carrier in place in line with the vehicle) _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Tue Oct 23, 2012 2:20 pm Post subject: |
Jon_slider wrote: |
elegance is in the eye of the beholder...
RMW's
Burley's
Regardless if a heim joint is used.. the elegance of the hinge is in the clean lines...
Burley's got a damn nice looking hinge assembly there.
The weak point in the design (functionally and structurally) is the pin for holding it open. He has talked about using a different approach.. but mine was one of the protos.. so I don't know how he's doing it these days. _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
westyventures Samba Member
Joined: December 29, 2004 Posts: 2306 Location: Oregon Outback
Posted: Wed Oct 24, 2012 7:26 am Post subject: |
Some of these designs are pleasing to the eye - but none met my personal needs: a stronger bumper than anything on the market, on which the tire swings are mounted securely, no additional holes drilled into the body. But a step further: tire swings that pivot away without the need to clear anything that might be mounted to the hitch. This is the prototype I made to test on my personal Syncro.
(some of you might notice a mistake the welder made - no time to fix it now, will deal with it later) |
kuleinc Samba Member
Joined: August 10, 2007 Posts: 1604 Location: East Bay Area, California
Posted: Wed Oct 24, 2012 8:04 am Post subject: |
westyventures wrote: |
Nice addition to the product choices out there!
Whats your target price for the assembly?
Quote: |
some of you might notice a mistake the welder made - no time to fix it now, will deal with it later |
I don't know if its what you are referring to.. but the post for the tire mount partially obscures the tailights.
FWIW, my burley rack clears my hitch mount accessories, including a trailer.
The only potential problem is if I use a hitch mounted box.. but that would have to be on a tilt down anyway.. to access rear hatch. _________________ -89 GL Westy, SVX.. finally.
danfromsyr wrote: |
Posted: Wed Oct 24, 2012 8:16 am Post subject: |
j_dirge wrote: |
The only potential problem is if I use a hitch mounted box.. but that would have to be on a tilt down anyway.. to access rear hatch. |
I have no plans to reproduce these, just posted to show a 'different' way. Yes, he welded all the tabs for mounting the swings an inch too far to the ends of the bumper, partially obscuring the brake lights. No time to correct it now, will do so when the van is apart for paint next year. I use a hitch-mount bike rack - perhaps some other swings would clear but they all bolt through the van body (except one flimsy option I won't mention). |
Brungeman Samba Member
Joined: July 25, 2010 Posts: 187 Location: Pittsburgh
Posted: Wed Oct 24, 2012 10:17 am Post subject: |
Karl, that is really a nice design. I would just put in a 3rd brake light and be done with it. OR, do a 3rd and fourth brake light... Put one up top, and then if you have your van wired for trailer towing, put lights on your hitch rack like its a trailer and plug them into your harness. You can never be too safe with brake lights.
but again, that is a very nice bumper and swing away tire carrier. do you carry 2 spares? _________________ 87 multivan
84 transporter for sale
86 scirocco RIP
71 Baywindow RIP
1972 Super RIP
1969 Bug RIP
1974 Super RIP |
Posted: Wed Oct 24, 2012 12:23 pm Post subject: |
Brungeman wrote: |
but again, that is a very nice bumper and swing away tire carrier. do you carry 2 spares? |
Actually, I've already installed a third brake light from a Jetta IV mounted under the rear cabinet. Turned out very nice and bright. The main brake lights are still fine, just annoying that the edge of the upright crosses right over the end of the lights. I wanted to set it up for two spares as my plans are (were?) to do S. America at some point soon. |
outwesty Samba Member
Joined: June 06, 2006 Posts: 1074 Location: Tahoe City
Posted: Wed Oct 24, 2012 2:16 pm Post subject: |
Nicely done Karl, I really like how your new van is turning out. Make sure you figure out a way to carry your snowboard back there |
Posted: Thu Oct 25, 2012 6:42 am Post subject: |
Thats great. I did a 3rd brake light on the face of that back "shelf" of the AC bulkhead. It turned out great as well, but I have tint now and it shows up slightly dimmer now to the viewing public.
I have been told by one shop that they wouldn't inspect my vehicle because of my Thule T2 hitch mount rack. They said it obstructed the view of the brake lights. I took it off and they threw stickers on. I have been planning on wiring this thing with small LED trailer type lights and running the wiring through the hitch so it would be pretty much invisible. I have trailer wiring harnesses on all my vehicles I use this rack on. so it would be pretty easy.
where in S.America? going surfing? or just getting your Westy some sun? _________________ 87 multivan
86 scirocco RIP
71 Baywindow RIP
1972 Super RIP
1969 Bug RIP
1974 Super RIP |
mutantfab Samba Member
Joined: September 09, 2012 Posts: 85 Location: Bay Area
Posted: Mon Dec 03, 2012 10:23 pm Post subject: |
Why do a majority of the commercial tire racks attach to the body below the rear door instead of on the rear door itself?
Brian |
Posted: Tue Dec 04, 2012 8:26 am Post subject: |
mutantfab wrote: |
Brian |
The spot below the hatch is a structurally stronger place to mount it.
The rear hatch is on two hinges and a latch mehcanism.. The rear hatch can move and flex. In fact it is desgined to "adjust" much like your car doors, so that it closes properly and seals properly.
If you hang stuff on the door (and yeah, I know people do it) it can cause problems.
Imagine driving over 60 miles of washboard to a Baja beach... with a carrier mounted to the body and hatch together.
Its gonna take a toll on the latch and hinges.
Its also more "out of the way" down there by the license plate.. Doesn't stick out and catch on stuff.
Just had my passeneger side Burley swing away fine tuned last weekend.
Getting a few coats of magic paint and I'll post up some picks of the pair.. in action. _________________ -89 GL Westy, SVX.. finally.
danfromsyr wrote: |
NC Dude Samba Member
Posted: Tue Dec 04, 2012 9:17 am Post subject: |
Thats too bad Karl-I too want a structurally robust rear bumper solution for my 2WD and am really digging your bumper. I hope to get some time in Alaric's garage next spring and hopefully, if your still in the area, see it in person. |
almo Samba Member
Joined: January 27, 2011 Posts: 174 Location: In the back sleepin
Posted: Mon Mar 11, 2013 10:55 pm Post subject: |
What rims/tires are those? Me likey _________________ San Francisco/Mayo Ireland
1986 2.1L Westy 2wd 4-spd Sold!!!!
1987 2.1L Westy syncro
2005 Subaru legacy 2.5Gt Wagon 5sp MT |
Posted: Tue Mar 12, 2013 6:24 am Post subject: |
South African 'Carat 2'. No longer available. |
maxdefied Samba Member
Posted: Thu Jun 06, 2013 11:22 am Post subject: |
Don't know about Burley's carrier but the RMW is SWEEEEEEET and I love it! |
yiucycle Samba Member
hans j Samba Member
Joined: May 06, 2006 Posts: 2715 Location: Salt Lake City UT
Posted: Thu Jun 06, 2013 2:31 pm Post subject: |
yiucycle wrote: |
Have anyone use this:
http://www.etrailer.com/Trailer-Cargo-Control/Stromberg-Carlson/TR-2.html
The PO put on a C channel steel rear bumper and i think it would work and way cheaper($30) than other method. I probably will bolt it on first and find a position i like and either have it weld on or bolt on to the bumper. It looks like it will be pretty low compare to other setup. |
Don't forget you still have to open the hatch! _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
How will you open the rear hatch with that carrier and tire welded in place? |
Posted: Thu Jun 06, 2013 2:44 pm Post subject: |
it folds down, click on the link and you will see it fold to 90 degree. You can barely see the hitch pin on that pic. _________________ 1980 2.8LV6 Fiero ASI/Riviera Vanagon
"there is no point in being embarrassed of all the stupid shit i done and will continue to do"
