fclmscott Samba Member
Posted: Mon Oct 10, 2011 12:20 pm Post subject: washer switch conversion to electric - dash mounted |
1st off this is copied from Doris at earlybay.com who I have to thank for providing me a clean look to a problem I was facing. I copied it here with a subject line that may be easier to find when doing a search for washer switch conversion and for safe keeping. There are other methods out there for making this conversion but I felt that this one was a bit cleaner. Thanks Doris!
As written by Doris;
I will start by saying that this has been done before and covered on other forums,however I thought someone may benefit from watching me do mine.there are few ways of doing this but I think this is the easiest.The principle is the same though.
I have a 69 Bay and it has had an electric screen washer fitted by the PO.The washer motor operation switch was a PTM (push to make contact) toggle switch just below the dash - very un sightly i.m.o. I wanted to retain my stock looking switch but still have the reliability of the electric washer system.
I decided to use the pushing action on the air switch and, by fitting a small PTM switch behind the push rod, the pushing action could be used to operate an electric switch....hey presto - stock switch - up graded to electric operation!
This is how I did it............
These are the tools I used...hobby tool & various attachments,measure,the PTM micro switch of course,the VW wiper/washer switch & a curcuit tester.
I bought the switches off ebay from a seller called bitsbox, I found they were just the right size & capacity.
I measured the diameter of the thread on the PTM switch - It measured 7mm.
so I drilled a hole slightly tighter (5mm) in the body of the washer switch so that the thread on the PTM switch to bite into the plastic body and stay secure. TAKE YOUR TIME at this point as once you remove the original moulding of plastic, you can't put it back, you would have to fill the hole with miliput or araldite and then re drill it and start again. Note,as you drill into the plastic moulding/casing you are obviously gutting the air switch, so you may have a few shreds of metal/spring and seals etc from the air valve come out.
After I made sure the hole was clear ( I wanted the push rod to have a clear throw when operated) I measured how far into the body of the washer switch housing the push rod came, then compared that to how far from the rear the PTM switch came.there was a bout 9mm difference, so I chopped off 9mm from the rear of the housing (where the air pipes had attached to).
....after several trial fits and minor adjustments (cuts!!!) the PTM swich screws neatly into the switch housing just at the right depth so as to be operated by the push rod on the front of the wiper switch..
I finally physically checked that it would work using a curcuit tester....
https://www.thesamba.com/vw/gallery/pix/855940.jpg
Job done! all I have to do now is either solder the connections to the washer motor or fit spade clips and re fit to Doris! |
RussellK Samba Member
Posted: Mon Oct 10, 2011 1:44 pm Post subject: |
I just bought a switch like that today that I was going to put under the dash. I'm sure glad you posted the writeup before I drilled my hole. That looks great. _________________ -Russ
'77 Westphalia
'68 Standard |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Mon Oct 10, 2011 3:42 pm Post subject: |
Just be really aware of clearance between the wiper linkage and that switch, it would be getting uncomfortably close in a flat screen bug _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
SLO-N-LO-69 Samba Member
Joined: July 06, 2006 Posts: 629 Location: Central Florida
Posted: Mon Oct 10, 2011 3:48 pm Post subject: |
Very cool idea, thanks for the write-up.
I'll be copying it btw. |
decobugma07 Samba Member
Joined: May 03, 2005 Posts: 1049 Location: Newtonville, MA
Posted: Tue Nov 29, 2011 10:13 am Post subject: |
This is so great. I received the micro PTM yesterday and I'll try this weekend. Just on time for Winter driving.
I have a 66 bug. So, I'll post picture with that style switch (not much different I guess). _________________ Custom labels available here
http://www.thesamba.com/vw/classifieds/detail.php?id=1217449
66 Bug "Trixie"
68 Bug "Deco" (parting out)
73 Bug "Blue Angel" (RIP) |
Kirkne Samba Member
Joined: September 02, 2013 Posts: 15 Location: Oroville, CA
Posted: Wed Jan 29, 2014 3:58 pm Post subject: |
this is just what i was looking for |
CalLookVdub Samba Member
Posted: Mon Jul 31, 2017 4:24 pm Post subject: Re: washer switch conversion to electric - dash mounted |
Have used this method several times. Works Great! _________________ My Rides
'58 beetle - L335 Capri Blue
'63 15 window Deluxe
'67 Squareback
'68 Sunroof beetle - 1st bug, bought back
'70 Bay window deluxe
'71 Bay window
'14 Jetta SE 1.8T |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Jul 31, 2017 7:00 pm Post subject: Re: washer switch conversion to electric - dash mounted |
I retained the stock switch, and just added a toggle under the dash for the electric windshield washer pump. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Wiskow Samba Member
Joined: August 04, 2018 Posts: 26 Location: California
Posted: Wed Nov 21, 2018 3:15 pm Post subject: Re: washer switch conversion to electric - dash mounted |
I have seen a couple mods to the wiper switch. Here is my mod using a3D printed housing.
https://www.thingiverse.com/thing:3229239
David_nc_72std Samba Member
Joined: August 22, 2015 Posts: 841 Location: Winston-Salem, NC
Posted: Wed Nov 21, 2018 5:10 pm Post subject: Re: washer switch conversion to electric - dash mounted |
Using that type of switch, it would probably be a good idea to run the pump off a relay, those switches aren't made to carry a lot of current. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Wed Nov 21, 2018 6:57 pm Post subject: Re: washer switch conversion to electric - dash mounted |
Washer pump doesnt draw much. Have been doing that for getting close to 10 years on quite a few cars. And there was a comment earlier about being careful about the depth. First one I did got eaten by the wiper assembly. _________________ D-Dubya Manx clone - 63 Short pan,1914.
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Fri Nov 23, 2018 6:55 am Post subject: Re: washer switch conversion to electric - dash mounted |
Cusser wrote: |
I retained the stock switch, and just added a toggle under the dash for the electric windshield washer pump. |
I put a push button under the dash, in the hole that was already there for the rear window defroster. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
seiyaTokyo Samba Member
Posted: Sat Nov 24, 2018 1:12 am Post subject: Re: washer switch conversion to electric - dash mounted |
Nice I will try it. Thank you very much. |
TheViking Samba Member
Posted: Sun Nov 25, 2018 9:41 am Post subject: Re: washer switch conversion to electric - dash mounted |
So nice! Want to do that to mine as well now! Do you have the link for the buttons? |
H2OSB Samba Member
Joined: April 14, 2013 Posts: 1294 Location: Modesto, CA
Posted: Sun Nov 25, 2018 10:09 am Post subject: Re: washer switch conversion to electric - dash mounted |
I don't mean to hijack, but I figure someone looking at this thread might know. Some time back someone did a write up on this, but mounted in a column switch(for a SUPER BEETLE...would love it if the Mexibeetle combo switch would work). Anyone have a link to that thread? I couldn't find it anywhere.
Thanks
H2OSB _________________ (o\_i_/o) I'm not a vegetarian because I love animals, I'm a vegetarian because I hate plants. |
Dake Samba Member
Joined: September 02, 2014 Posts: 481 Location: Georgia
Posted: Sun Nov 25, 2018 10:10 am Post subject: Re: washer switch conversion to electric - dash mounted |
You or anyone selling this part? |
anthax Samba Member
Joined: October 21, 2016 Posts: 283 Location: Hälsingland, Sweden
Posted: Sun Nov 25, 2018 10:23 am Post subject: Re: washer switch conversion to electric - dash mounted |
I used the knob for the Eber to run an electric washer pump.
I took the Eber out because I only drive my bug in the summer, so it was not used. |
Cheburashka Samba Member
Posted: Sun Nov 25, 2018 11:42 am Post subject: Re: washer switch conversion to electric - dash mounted |
anthax wrote: |
I looked up "Eber" and got "An early ancestor of the Isrealites." Maybe that knob isn't installed on Supers. |
Posted: Sun Nov 25, 2018 12:04 pm Post subject: Re: washer switch conversion to electric - dash mounted |
Yeah, been done on the wiper stalk, would try doing a search. I have not done that yet myself, but it was using a similar switch I believe. Had seen the post a couple years ago. Found one of several on this.
https://www.thesamba.com/vw/forum/viewtopic.php?t=502329&highlight=washer+switch+electric _________________ D-Dubya Manx clone - 63 Short pan,1914.
johneliot Samba Member
Joined: August 29, 2005 Posts: 2189 Location: Chico, CA
Posted: Sun Nov 25, 2018 12:07 pm Post subject: Re: washer switch conversion to electric - dash mounted |
"Doris" sure has manly hands. If you read the bottom line, Doris is the name of the posters car. _________________ John
There is no distinctly American criminal class - except Congress.
Mark Twain
69 bug - "The Grey Ghost" |
