Gerrelt Samba Member
Joined: December 22, 2004 Posts: 682 Location: The Netherlands
Posted: Sun Nov 25, 2018 12:40 pm Post subject: Re: washer switch conversion to electric - dash mounted |
I did this for on my 1973 curved windscreen super beetle too.
Details here:
http://www.gerrelt.nl/section-modifications/window-washer-switch
I too was worried the current drawn by the washer motor was too much for the switch, so I used a relay to wire it:
It's been working perfectly for about 10 years. _________________ homepage
_________________ |
H2OSB Samba Member
Joined: April 14, 2013 Posts: 1294 Location: Modesto, CA
Posted: Sun Nov 25, 2018 4:18 pm Post subject: Re: washer switch conversion to electric - dash mounted |
Ahh, thank you. I searched for micro switch, column switch, and wiper switch. Never dawned on me to search washer bottle, but that is the article I was referring to.
H2OSB _________________ (o\_i_/o) I'm not a vegetarian because I love animals, I'm a vegetarian because I hate plants. |
H2OSB Samba Member
Posted: Sun Nov 25, 2018 4:22 pm Post subject: Re: washer switch conversion to electric - dash mounted |
I should have thought of you Gerrelt. You've done most everything to your car I want to do. I stole your rear brake idea for my son's car.
Wiskow Samba Member
Joined: August 04, 2018 Posts: 26 Location: California
airschooled Air-Schooled
boxer74 Samba Member
Joined: July 03, 2011 Posts: 709 Location: Ontario, Canada
Posted: Wed Jun 24, 2020 10:14 am Post subject: Re: washer switch conversion to electric - dash mounted |
Did you end up making this work? I'd like to try the same. _________________ 74 Super
84 Westy |
Wiskow Samba Member
Posted: Sun Sep 12, 2021 10:41 am Post subject: Re: washer switch conversion to electric - dash mounted |
Ya! It has been working flawlessly. My only problem now is the stream of water is too strong it shoots over the car |
raydog Samba Member
Joined: February 09, 2006 Posts: 1163 Location: Cape Cod
Posted: Sun Sep 12, 2021 11:19 am Post subject: Re: washer switch conversion to electric - dash mounted |
Wiskow wrote: |
Just move the aim of the nozzles down lower at the windshield. You do realize they are adjustable. _________________ Come on, It's not rocket science. KISS |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Sun Sep 12, 2021 11:26 am Post subject: Re: washer switch conversion to electric - dash mounted |
Quote: |
You do realize they are adjustable |
a pin (pointy kind not writing kind) into the holes. They are a ball swivel _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
raydog Samba Member
Posted: Sun Sep 12, 2021 12:02 pm Post subject: Re: washer switch conversion to electric - dash mounted |
I have sometimes found that they can be suborn. I have had a pin bend before the swivel ball moves. An alternative could be a small 4" awl with a sharp point. Do not jam it in there. _________________ Come on, It's not rocket science. KISS |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Sun Sep 12, 2021 1:22 pm Post subject: Re: washer switch conversion to electric - dash mounted |
I’ve found that a tiny bit of WD-40 will loosen up the nozzle sprayers. A few seconds after spraying, a pin will move them easily.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Dr Ann Samba Member
Joined: May 11, 2023 Posts: 2 Location: Perth, Australia
Posted: Fri May 12, 2023 12:00 am Post subject: Re: washer switch conversion to electric - dash mounted |
Hi guys, just got to say a big thank you for the electrics details and micro push button info… I just managed to get my new electric washer wired in this way and it’s brilliant. It works so well I need to get a pin out and alter the trajectory from the nozzles now!!
By being sble to do this it saved me from having to drill another hole in the dash … as I had already used the existing hole for the button for my spotlights!!
Anyway thanks for the ideas!!love them!! Thanks for taking the time to post them. Much appreciated! It really helped out!!
(and while I was getting the spots and the washer sorted out I managed to get a repair plate fixed in and an “old” radio and speaker back in too .. so it’s all looking really ship shape now!! 👍👍👏👏
Busstom Samba Member
Joined: November 23, 2014 Posts: 3853 Location: San Jose, CA
Posted: Sat May 13, 2023 10:26 am Post subject: Re: washer switch conversion to electric - dash mounted |
^ ^ ^ I just noticed you have a later model which probably had a padded dash at one time. Did you de-pad the dash yourself? I've always wondered how all the switches get adjusted for the loss of thickness when the padded portion is removed...I've seen some where the switches had large gaps behind the knobs after removing the dash. Yours looks really good. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏 |
Puppy67 Samba Member
Joined: October 04, 2022 Posts: 221 Location: Bristol, UK
Posted: Sat May 13, 2023 12:20 pm Post subject: Re: washer switch conversion to electric - dash mounted |
Busstom wrote: |
^ ^ ^ I just noticed you have a later model which probably had a padded dash at one time. Did you de-pad the dash yourself? I've always wondered how all the switches get adjusted for the loss of thickness when the padded portion is removed...I've seen some where the switches had large gaps behind the knobs after removing the dash. Yours looks really good. |
In UK, most (if not all) of Europe, Australia, etc. we didn't get the US padded dash on models with torsion bar front ends. Only super beetles had padded dash for us. |
Posted: Sat May 13, 2023 12:36 pm Post subject: Re: washer switch conversion to electric - dash mounted |
Puppy67 wrote: |
Busstom wrote: |
Luckyyyyyyyyy!!!
Actually, after I posted, I began to wonder whether certain markets got it. So, there must be part numbers for dash switches that don't "fit" the US spec pad, so maybe those are the ones to go after when de-padding a US dash? _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏 |
plastikman187 Samba Member
Posted: Tue Jun 06, 2023 3:53 pm Post subject: Re: washer switch conversion to electric - dash mounted |
I did something very similar to this on my 71 super.
I ended up using the relay, last time I had the frunk open and the wiring all split out I ended up putting the relay into the original fuse block. This mod works great, I have owned this car since 2003 and before that it was my dads. He had installed an electric washer bottle, but never hooked it up. I remember him using a spray bottle out the window when I was a kid LOL.
Anyway, I'm not really adding anything to this thread other than "me too" Everything in my super looks totally stock and this worked excellent. |
deltakilo172 Samba Member
Posted: Fri Dec 29, 2023 8:32 am Post subject: Re: washer switch conversion to electric - dash mounted |
Good day all. Looking for some guidance and parts for an electric wiper fluid install I want to put in my car. I don’t want to use the spare tire pressure any longer for the obvious reasons (lol). I purchased a kit online but now now trying to find a push switch that I can install in one of the blank openings on my dash to keep the look as original as I can. I have a 1979 VW Super Beetle Convertible (fuel injected). Any adviice and where I can source the proper parts would be greatly appreciated. Attached is a picture of my dash for reference.
By the way and as an option, is my factory signal arm system able to be used with this after market electric windshield wiper bottle upgrade? Wasn’t sure exactly how the factory system worked other than knowing the wiper fluid squirts when the signal arm is pulled but assumed that was just a mechanical type of cut off and not operated through an electrical switch.
