Another 2110 build *Head Advise Needed*
Page: Previous  1, 2, 3 ... 14, 15, 16, 17, 18, 19  Next
Forum Index -> Performance / Engines / Transmissions Share: Facebook Twitter
carlostam
carlostam is offline
PostPosted: Fri Dec 30, 2011 9:34 pm    Post subject: Reply with quote
VIN wrote:
was it in Hot VWs i saw that they chamfered the edge of the piston to clear the copper shim.?.?.
Vin I'm not sure but I'm not taking any risk having the piston smacking the copper shim. It seems lot easier just placing the right amount of barrel shims and having the piston staying inside the barrel then sticking out....
82 x AA 90.5 B c/w ,FK8 ,1.4 Scat pro comp rockers
CB lifters,5.4 connecting rods, 12 lb flywheel
Stock cam gear ,1 5/8 merged headers ,Dual 40 weber 36 ventury,Kennedy pressure plate stage 1
Stock 66 trans with 205/65/15 tires ,010 distributor
Bad Ass Ported 40x35.5 heads Dual Springs
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...;start=220
carlostam
PostPosted: Fri Dec 30, 2011 9:39 pm    Post subject: Reply with quote
Well, Here's the rockers. Have them mocked up on the bench just to see how they fit.
First thing I notice was that the base is set back. Its not centered at all. Is this normal for the Scat 1.4 Pro Comps??? Confused Confused Confused
See how it over hangs.....
modok
modok is online now
PostPosted: Sat Dec 31, 2011 1:18 am    Post subject: Reply with quote
honestly, it would be ironic if it scat rockers DID fit china heads perfectly,
that'd be like a solar eclipse man!
The rocker bosses look slightly too high, maybe a bit of core shift in the head casting, annoying, but it should still be strong enough to work
The scat rocker blocks are off-set like that, that is normal
rockers look like they would maybe hit valve covers, check it without the gasket to find out
Glen Urban
watch AvE on youtube
https://www.youtube.com/channel/UChWv6Pn_zP0rI6lgGt3MyfA
fredy a
fredy a is offline
PostPosted: Sat Dec 31, 2011 4:26 am    Post subject: Reply with quote
have do your lash caps fit ?
de one that came weed my scat lifters 1.4
is to big
thanks
sorry for the spelling
carlostam
PostPosted: Sat Dec 31, 2011 7:10 am    Post subject: Reply with quote
The rocker blocks look slightly too high, maybe a bit of core shift in the head casting, annoying, but it should still be strong enough to work
The scar rockers are off-set like that, that is normal
Hey the post above reminded me.....Are the lash caps supposed to fit snugged or do they have a slight play?......
Thanks
mark tucker
mark tucker is offline
PostPosted: Sat Dec 31, 2011 10:24 am    Post subject: Reply with quote
slight play is good,and the rockers have to be offset to get the ratio to work within the vw head size.and the china rocker blocks are slightly different than the vw, the scat heads I had hear last week had them a bit lower in the box,or atleast the stud was and the block was smaller& narrower.I think it is mainly smaller, dont think it will have any affect, have you seen the size of the shims thay sell?there smaller than that witch would be worse than what you have.I dont use any shims,never seen anyset up that needed them to work properly,just seen them used when the pushrods are a bit too long.witch is rong. look at the top ridge of the rocker arms thet look jagged, might want to deburr a bit.
as far as the head hiting the copper gasket as long as the gasket is biger than the bore and fits the head bore good I would not worry as the top of the pistons are smaller any way for expansion.I ran .060 gaskets that the pistons came threw +another .020", why you ask? to get the quench I wanted & I did not at that time have a head flycutter& the cylinder shims I had gotten from a vender in cali ,well that looked lik they were cut out with a can opener and serfaced with a body grinder.with that said they were within +-.012" of each other.I just wish I could remember who it was I got them from,too long ago.I ran the shit out of that motor for about 6 years then went biger, again.
mark tucker
PostPosted: Sat Dec 31, 2011 10:26 am    Post subject: Reply with quote
just noticed ,you need to get some longer chromoly rocker studs,and get probably rid of those shims.
modok
modok is online now
PostPosted: Sat Dec 31, 2011 1:36 pm    Post subject: Reply with quote
Some lash caps are a tight fit and some are not. Quality varies, look at he surface finish inside the lash cap and try to get an idea of how loose it is, should be tight to .002 play, any looser than that indicates crappyness for sure
the valve stem should be about .313"
Scat rockers do seem to be well made, but they don't fit very well sometimes, for some reason.
In all cases of these aftermarket parts, I hate to say, you just need to really investigate everything and do the best you can to make it all work together.
Comparison with stock parts and known specifications can show you what part is funky. These china heads are new enough that I have no idea what dimensions they changed, but it sure looks like they did change something.
Glen Urban
carlostam
PostPosted: Mon Jan 09, 2012 7:42 pm    Post subject: Reply with quote
Alright all, just started placing my bad ass heads on the engine and played around with the rockers. I placed old 1600 springs on the head. They were soft, hell I was even able to push them down by hand. It worked out just fine. I will be posting pics soon.
So be ready for me I'll be asking plenty of questions concerning this geometry stuff.
VIN
VIN is offline
PostPosted: Mon Jan 09, 2012 7:50 pm    Post subject: Reply with quote
Dancing
Co-owner, 2 Brothers Guns
[email protected]
Click to view image
carlostam
PostPosted: Wed Jan 11, 2012 5:06 pm    Post subject: Reply with quote
Need info on this.....
after what I though was the correct deck height of .050 on #1 and #2 was off. I have ordered the proper shims in order to get .050 deck.
My question is #3 and #4 have the correct .050 deck height can I start with the valve geometry on that side while I wait for the shims???
Also, what is the best way to start with the pro comps scat 1.4 rockers. Been reading tons of threads going back to 2007 but seem that scat has changed.
Some threads say just measure one rocker for push rod length while other say do each one individually. Confused Confused Some say that the FK8 lobes are different for each valve?? Some say that the scat rocker tend be more like a 1.5 ratio and it goes on and on. I know I know its the samba .
I would really like to get some help on how to start this. I'm a fast learner but sometimes just need that little push.
Thanks
Carlos
carlostam
PostPosted: Fri Jan 13, 2012 5:09 pm    Post subject: Reply with quote
Today I cut the push rods after getting the swipe on the lash cap correct. I had to use .090 shims on the base in order to get the swipe right.
Now here's the questions.... I measured full lift and its withing .005 of what the cam card indicated. My problem now is that at half lift the rocker is at an angle compared to the push rod. I have read and read that the push rod and the rocker adjuster needs to be straight with each other.
How do I fix this. I have been reading but can't seem to get the answer.
Need Help please. Modok are you out there Wink
All swipes are even:
Bad picture but swipe is in the middle and centered:
Full lift:
modok
modok is online now
PostPosted: Fri Jan 13, 2012 5:56 pm    Post subject: Reply with quote
THe angle on the pushrod side does like a bit much
How does it all look if you go without shims under the rockers?
Glen Urban
carlostam
PostPosted: Fri Jan 13, 2012 6:07 pm    Post subject: Reply with quote
Modok, I really haven't tried that yet. My thought are in two parts.
First, I shoot for the even swipe on the lash caps with the shims. Thinking this was most important.
Second, If I remove the shims I thought it will bring the rocker lower and make the angle worse.
Now I'm second guessing if I have the right length on the push rods. The way I was told was to make sure all the adjuster were set the same way and that there were no lash and this was with the .090 shims...
Your input will be highly appreciated. What will be more important that the angle of the push rod and adjuster cup is straight or the the swipe on the lash cap is centered??
Sorry dude, firs time Shocked Shocked
mark tucker
PostPosted: Fri Jan 13, 2012 6:12 pm    Post subject: Reply with quote
the closer to being in line at full lift the better in most cases.(where is the most pressure on everything??? full max lift) different rockers have different radi on the foot and that can & will change the ratio and how the geo can be set up.
with your pattern is the foot pulling/pushing on the stem and staying in 1 spot due to the stem bending?or is it sliding?walking?I have seen rolle rockers bend the valve stem .030 instead of rolling across them,most rollers dont roll but slide&roll when running.I dfl coat my lash caps&rockers to try to keep oil there and have them slide/walk instead of pulling/pushing,grabing
with the rockers high you may just have them pulling instead of walking across the face, just check it for your self and do some thinken,it,s not hard.thats where adjustable pushrod comes in handy to see what hapens at a bunch of different hights.you can also check the degrees of the cam at the valve .and watch it change as you move the rocker up&down, most of the time down will make more power as the raito go's up at lower lifts with lower pushrod seat, witch = more power.
modok
modok is online now
PostPosted: Fri Jan 13, 2012 6:27 pm    Post subject: Reply with quote
Honestly, the most important part, IMO, is the angle of valve to rocker
In this picture here, the angle of the red lines is near 90 degrees. This 90degree point should be at 1/3- 1/2 lift, to make for minimal side force on the valve stems.
SO, for me, getting this close would be step #1, this can be changed by changing stem height, lash caps, or shims under the rockers
Then, I'd worry about the contact of the foot being centered
Then, I'd look at what the pushrod is doing
The common belief assumes that if the contact patch and the way the adjuster looks is right, the angles will be right. Hopefully this assumption is correct, but it is not always. For instance in the picture the contact point is way off, for some reason.
I assume nothing.
Glen Urban
mark tucker
PostPosted: Fri Jan 13, 2012 6:38 pm    Post subject: Reply with quote
not for me.
back on the copper shims/gaskets, why would the piston hit them? and why is your cylinder hanging out of the head?how is the cylinder hanging out of the head??
as for the min side force , would you rather have it farther off at low lift when there is less pressure and more likely the rocker foot will slide with low pressure than when the pressuere is high at 1/2to 2/3 to full lift?where it wont slide but will bend the stem& kill the guide. why not?done it for years,t&d & jessel sets thiers up about the same, they even have special tools to set it up corectly & how much to compecsate for lower lift cams & extreamly high lift cams.not to worry everybody does this stuff differently.
modok
modok is online now
PostPosted: Fri Jan 13, 2012 6:49 pm    Post subject: Reply with quote
jezel rockers are roller rockers
you see any rollers here?
these are wiper foot type rockers
the differnt designs are not the same
On valve side--
ball adjuster: 90 at half lift
wiper: 90 at 1/3 lift
roller rocker.... I donno, who cares, they are too heavy anyway Wink
Glen Urban
mark tucker
PostPosted: Fri Jan 13, 2012 7:46 pm    Post subject: Reply with quote
havent you seen the mohawk ? some are non roller. and the roller makes no diff on geo.
modok
modok is online now
PostPosted: Fri Jan 13, 2012 7:53 pm    Post subject: Reply with quote
I though the same thing too, before I ever though about it, but then I started thinking, and looking at how the rockers are designed on all the heads that came in over the last few years.
If you have an example of a production rocker that is not designed as I describe, tell me what it is, and I will have a look at next chance
Glen Urban
Reply to topic    Forum Index -> Performance / Engines / Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 15 of 19
