Seat Heaters
r39o
Samba Polizei
r39o is offline
PostPosted: Mon Dec 31, 2012 11:49 am    Post subject: Reply with quote
I have VW factory heaters. These fit the Recaros well. Heck, they might even be Recaro brand....have to look.
VW ones are known to fail too. BUT, the fix is known also. You just have to google for it. They use a controller "relay" and it is a number 59, if I recall. Some of the aftermarket ones do not regulate the heat and are sort of on or off and I have found you can get too toasty with them. Our new Jetta came with heated seats and it is nice options we did not order....
This is a sort of back burner for me as the factory seats are not too bad and it does not get too cold around here. But, I collected the parts and should put them in one day....ya right!
insyncro
Banned
insyncro is offline
PostPosted: Mon Dec 31, 2012 11:37 am    Post subject: Reply with quote
Two of the universals failed right where the rivets are on the pockets of my favorite style of work pant.
They dug in and tore the heating element.
I now put 1/4" memory form over the elements.
The foam is from my local upholsterer and they said it should be able to handle the heat.
We shall see.
insyncro
Banned
insyncro is offline
PostPosted: Mon Dec 31, 2012 11:32 am    Post subject: Reply with quote
I have had a few universal heater elements crap out over the past few years.
I am using Recaro replacement parts now.
They are much higher quality than the universals I first tried.
Any Recaro dealer can order them...$175-$275 depending upon the size of them.
The Specialist or LXF Recaro seat can be special ordered with seat and lumbar heat.
[email protected]
john@aircooled.net is offline
PostPosted: Mon Dec 31, 2012 11:28 am    Post subject: Reply with quote
I am doing this soon, and was going to drill a hole in the center of the swivel with a grommet on each piece of metal it goes through. Not sure how many pieces we have to go through yet or if the middle is an option at all.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
r39o
Samba Polizei
r39o is offline
PostPosted: Mon Dec 31, 2012 11:26 am    Post subject: Reply with quote
plummerdesign wrote:
Seat heaters are on my list. On the Westy, both seats rotate. So what is the best way to keep from damaging the wiring leads when turning the seats?
Cheers,
Jeffery
(Westfalia travel/camping videos at YouTube link below)
I have swivels, heaters and Recaro seats waiting to be installed.
I am thinking of putting a hole in the middle of the swivels to allow the cable to go through, if it is possible.
Otherwise you need a long enough service loop and the cable tied away so it does not get caught. In this case, I do not know what a good routing is.
This is a topic I sort of forgot about....
plummerdesign
plummerdesign is offline
PostPosted: Sun Dec 30, 2012 10:15 pm    Post subject: Reply with quote
Cheers,
Jeffery
It is old and green and it makes me grin.
1984 Westfalia 1.9
Jaraqui
Jaraqui is offline
PostPosted: Sat Dec 22, 2012 5:27 pm    Post subject: r39o Reply with quote
Digging through the archives, I saw this conversation you had with 'insyncro' about seat heaters.
I'm about to re-assemble my driver's seat after a rebuild and cleaning, and have a complete OEM heated seat setup (rheostat, column shroud, harness, '59' controller. I bought aftermarket heating elements.
According to Bentley, there's a temp sensor in the OEM seat element that plugs into the 6-pin under seat connector. The aftermarket elements I have only have power and ground leads.
Did you figure out whether you needed thermistor-controlled heating elements to use the VW harness? I couldn't determine whether the temp sensor is needed from Insyncro's comments.
Thanks for any guidance, and Happy Holidays.
David K
r39o wrote:
insyncro wrote:
r39o wrote:
insyncro wrote:
I have installed carbon fiber heating elements to my stock Vanagon seats.
I wired them to the relay and control unit found in Canadian Syncros and Tristars.
Worked like a charm.
Really makes winter driving comfortable.
So those heating elements have a thermistor that works with the "relays?"
Which brand and model of element did you use?
Yes and well above most budgets around here.
They are available on eBay.de
The VW factory elements for my Recaros are about $90 each which is not too bad, I think compared to what the aftermarket ones cost. I can get the factory ones wholesale in the US last time I checked.
But, the control and "relays" are quite expensive to purchase new, but thankfully you can get them out of other model VWs used. Not like they are falling off trees, but you can get them.
Knowing myself I just put them on high or low. The variable feature of the stock VW is sort of lost on me.
BUT, I do have everything to do the job now and forgot to order the pads until this thread came up.
Moglet
'90 Westy Syncro, EJ-22, other bell's & whistles
268K miles
Faithful companion since 1996
Next stop, Ushuaia?
creative native
creative native is offline
PostPosted: Sat Dec 03, 2011 2:11 pm    Post subject: Reply with quote
At this point, I believe I have all components to install the heated seat/seats in my 1986 Westfalia. I have the VW rheostat, raised upper column cover in brown, #59 heated seat relay. I believe all I need now are the heated pad elements and the wiring harness. Does anybody know where I can find these or the VW part numbers? I've been told that the heated seat wiring harness from an early 90's Jetta MK is the same...can anybody here verify that? If I should find the wiring harness, but not the heated pads, does anybody here know if aftermarket heated pads will work? I will appreciate any information and help!
r39o
Samba Polizei
r39o is offline
PostPosted: Sun Oct 16, 2011 2:49 pm    Post subject: Reply with quote
insyncro
Banned
insyncro is offline
PostPosted: Sun Oct 16, 2011 1:38 pm    Post subject: Reply with quote
r39o
Samba Polizei
r39o is offline
PostPosted: Sun Oct 16, 2011 12:24 pm    Post subject: Reply with quote
I "discovered" our new Jetta V has heated seats. I never looked close before. The other day I drove it and it got cool in the evening. While playing with the controls (worse than a Vanagon!) I found the push button control in the middle of the hot / cold (left) and the vent control (right.) I noticed I only need two positions. Warm and Hot (and Off.)
I mention this as I may not really need to integrate the variable factory system which uses a thermistor to keep temperature at what you set via the (EXPENSIVE) controller.
In other words an after market setup may well be all I really need. (I won't use it a whole lot here in So Cal anyways.)
Any input?
r39o
Samba Polizei
r39o is offline
PostPosted: Wed Oct 12, 2011 10:06 pm    Post subject: Reply with quote
a914622
a914622 is offline
PostPosted: Wed Oct 12, 2011 8:00 pm    Post subject: Reply with quote
I just scored the stock top plastic part that holds the seat/heater switch. (only a buck fifty) you got to love the wrecking yard!!
Post pics on the way you go! I have a set of eurovan seats waiting to go in after a good wash and heaters.
jcl
87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru
big swifty
Location: Formally in Republic of VT; now in Hollywood, FL
big swifty is offline
PostPosted: Wed Oct 12, 2011 6:07 pm    Post subject: Reply with quote
Lux-51 DIY
Evan
1987 Vanagon Syncro // Westfalia pop-top graft // Factory new ALH. 11mm IP. AFN 110 RC 2,3,4 // S7 turbo// Titan P502's
2013 Golf 4d TDI. No mods. Yet.
1991 Jetta coupe TD. Giles Superpump. Custom tall 5 speed. FOR SALE!
insyncro
Banned
insyncro is offline
PostPosted: Wed Oct 12, 2011 5:53 pm    Post subject: Reply with quote
Syncroincity
Syncroincity is offline
PostPosted: Wed Oct 12, 2011 5:47 pm    Post subject: Reply with quote
I installed the heatedseatkits set in my Subaru under leather, worked great, install is a breeze, they provide very nice wiring harnesses, all modular with plugs, all you do is provide +12v and a ground, and find a place to mount the switches.
Take the opportunity to machine wash or dry-clean your upholstery while it's off. Smile
'86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight=
2doorsdown
2doorsdown is offline
PostPosted: Tue Oct 11, 2011 6:15 pm    Post subject: Reply with quote
I don't see VW listed on the Check site. Do you remember what the kit ran you and did you get the DIY? Thanks again. Pre Heating the bed sounds like I'll make it on the wifes good side with this mod Wink
big swifty
PostPosted: Tue Oct 11, 2011 4:39 pm    Post subject: Reply with quote
I have the Check brand in my Jetta and in The van. Thumbs up!
Evan
PDXWesty
PDXWesty is offline
PostPosted: Tue Oct 11, 2011 10:43 am    Post subject: Reply with quote
Here's two other posts with info.
http://www.thesamba.com/vw/forum/viewtopic.php?t=267239
http://www.thesamba.com/vw/forum/viewtopic.php?t=393280
89 Westy 2.1 Auto
danfromsyr
danfromsyr is offline
PostPosted: Tue Oct 11, 2011 10:36 am    Post subject: Reply with quote
don't forget you can (should) install seat heaters in the back bench too.
not just for passanger comfort or while chilling in the mobile chalet..
but to preheat the beadding too Wink
Abscate wrote:
