JohnJohn Samba Member
Posted: Fri Jul 19, 2013 8:37 pm Post subject: |
That's going to make a little difference in look...and make me want to take those KYBs off the front
_________________ 69 Square
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Fri Jul 19, 2013 8:39 pm Post subject: |
JohnJohn wrote: |
joey1320 wrote: |
That is one beautiful squareback you got there. Those wheels look super cleeeaaaaannn!!!
I would go two/one combo on the suspension, that's the plan for my rust bucket lol.
Keep the pics coming, loving the wagon
Btw, your R60 CountryMan will burn the clutch if you are not careful, those are really sensitive. Also the oil pump solenoid has been known to leak oil, which can cause a wiring failure. Last thing, keep an ear out for the engine cooling fan, it's ok if it runs up to 10min cooling the engine after shutting it off, but not longer than that. If it runs much longer you can have an issue with the thermostat or the engine temp sensor. Nice car btw, those are fun |
Joey, the R60 is in right now, trying to get MINIUSA to replace the '12 clutch with the new '13 clutch pack. Had an R53 and R55 before. Here is that car.
and the build thread: http://www.motoringunderground.com/forum/showthread.php?t=23218 |
Nice build!
While they are there, you might as well pay for a rear main seal to get installed. Also keep an ear out for a light clicking/swooshing noise while moving. We have had a few front wheel bearing housings crack. _________________ **1971 Super Project
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
Posted: Fri Jul 19, 2013 8:42 pm Post subject: |
joey1320 wrote: |
Nice build!
While they are there, you might as well pay for a rear main seal to get installed. Also keep an ear out for a light clicking/swooshing noise while moving. We have had a few front wheel bearing housings crack. |
after the R55 turbo went out and I bought this car I extended the bumper to bumper to 100k. It's only got 16k on it right now. _________________ 69 Square |
Posted: Fri Jul 19, 2013 9:32 pm Post subject: |
JohnJohn wrote: |
joey1320 wrote: |
Nice build!
after the R55 turbo went out and I bought this car I extended the bumper to bumper to 100k. It's only got 16k on it right now. |
The main issues with the N14/18 engines is the oil consumption. BMW says 1qt per 750miles is perfectly normal. Check the oil twice a month and change it every 7.5k miles.
As far as the rear main seal, they wouldn't just replace it, even when doing a clutch, so it's up to you if you want to pay for the extra repair. One thing to note, it will be the cheapest rear main seal you ever pay for in your life
Back to the vw, that's a beauty! _________________ **1971 Super Project
Bobnotch Samba Member
Posted: Sat Jul 20, 2013 8:22 am Post subject: |
JohnJohn wrote: |
If the KYB's are gas shocks, you'll want to swap them to an oil shock anyway (it'll ride a lot nicer). I use lowered link pin bug shocks, in the oil style, versus the gas charged. Make sure you re-set the tire pressures (see the glove box sticker for recommendations, or do a search of the forum), as that can affect how the car rides and handles too.
Yes, the tire size WILL change the speedo reading, however, IF you use the GPS app while you're driving, you can find out how close/or off, the existing unit is with the "correct sized" tires. Most of us wait until after we've done the change, so we know what our reading is with the given tire.
The chart you gave above assumes that the speedo reading is "on the nose" right now, but most read a little fast to keep you from getting a ticket. When you go to the smaller diameter tire, it'll actually get pretty close some times.
The speedo in my old 71 Notch was like this, in that it read slow with the stock sized tire, but right on the money with a 195-60-15 combo. My 65 Notch was the opposite, in that it read fast with the larger tire size, and even faster with the 195-60 combo. That's why I suggested using the GPS app after you make the change, to "re-calibrate" your speedo. Then you'll know what the "real world" reading is. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Jul 20, 2013 8:33 am Post subject: |
It's an automatic...no need to worry about speeding really. _________________ 69 Square |
Posted: Sat Jul 20, 2013 9:21 am Post subject: |
JohnJohn wrote: |
It's an automatic...no need to worry about speeding really. |
You haven't caravaned with Jim Adney going to an Invasion, have you? They'll run 80mph or more with no trouble. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat May 15, 2021 1:58 pm Post subject: Re: New To Me Type3 |
It's only been 8 years and I'm finally putting this back together.
What the heck is this part and where does it go?
69 Square Auto
lawn ninja Samba Member
Joined: January 02, 2006 Posts: 1009 Location: Round Rock, TX
Posted: Sat May 15, 2021 2:17 pm Post subject: Re: New To Me Type3 |
JohnJohn wrote: |
69 Square Auto
That goes in the door. It's kind of a theft inhibitor and I think it also guides the back edge of the window when its being rolled down. Where in Austin do you live? _________________ Jason
My 64 1500 S Notchback project here
My 58 sedan project here
My 63 Ghia here |
Posted: Sat May 15, 2021 2:18 pm Post subject: Re: New To Me Type3 |
lawn ninja wrote: |
That goes in the door. It's kind of a theft inhibitor. Not sure that it serves any other purpose than that. Where in Austin are you? |
Thanks!
I'm in Leander. _________________ 69 Square |
Posted: Sat May 15, 2021 6:05 pm Post subject: Re: New To Me Type3 |
JohnJohn wrote: |
lawn ninja wrote: |
Thanks!
I'm in Leander. |
Nice. I'm over in Round Rock, right on the Georgetown border. _________________ Jason
My 63 Ghia here |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22462 Location: Escondido CA
Posted: Sun May 16, 2021 1:02 pm Post subject: Re: New To Me Type3 |
JohnJohn wrote: |
lawn ninja wrote: |
Thanks!
I'm in Leander. |
Covers the lock and door mechanisch but also holds the felt channel for the back of the door, inside glass regulator. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Sun May 16, 2021 2:39 pm Post subject: Re: New To Me Type3 |
lawn ninja wrote: |
That goes in the door. It's kind of a theft inhibitor and I think it also guides the back edge of the window when its being rolled down. Where in Austin do you live? |
Thank for calling it a theft inhibitor! That really helped me get it back in and help me figure out the angle I had to use to get it in as well. It went in pretty easy thinking that is had to cover something… not easy but easier. _________________ 69 Square |
Posted: Tue May 18, 2021 6:03 pm Post subject: Re: New To Me Type3 |
Took back the 1” of rear leg room that the VW marketing team gave us in 1969.
