rustbus Samba Member
Posted: Mon Oct 17, 2011 4:31 pm Post subject: |
busdaddy wrote: |
Alodine is for aluminum but may sort of work on mag or at least a mag/al alloy, I was going to dig out some of mine and try it but haven't had a chance.
Get yourself a bottle and do some experimenting: http://www.aircraftspruce.com/catalog/cspages/alodine1201.php As for pre cleaning most recommend an alkaline bath IIRC, think a shroud would fit in your dishwasher? |
hah, i do dishes by hand, so im SOL as far as that goes!
i may go the experiment route. i'll see if the original coat can be removed at all _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
Posted: Mon Oct 17, 2011 4:33 pm Post subject: |
raygreenwood wrote: |
Busdaddy is spot on. Here is the process you are looking for. It can be more involved and nasty than you think.
http://www.finishing.com/faqs/magnesium.html
Be aware,,,you are going to need chromic acid (sulphuric acid and dichromate mixture and chromium trioxide). Some of the byproducts are Chrome 6 (hexavalent chrome)....which is highly highly carcinogenic. Ray |
ugh thats nasty, i cant see myself getting through all those steps and baths without getting it in my eyes.
busdaddy's link is for a brush applied product, right? i dnno. this may all hinge on if the original coating can be easily removed. _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
nathansnathan Samba Member
Posted: Mon Oct 17, 2011 7:52 pm Post subject: |
My dad who is a retired tranny man would coat the cases that he'd rebuilt with aluminum spraypaint. With the way aluminum reflects I always thought is was about as bad as white for how dirt shows up.
SGKent wrote: |
the transmission was cleaned then sprayed with CRC heavy duty corrosion control. I used aluminum paint on the shroud and it is holding just fine.I don't epxect it to last 100,000 miles but when it gets bad I will do it again - or maybe sooner with a color closer to original or a powder coat.
The trans looks really good. Is the stuff sticky?
What do you think about using it on the fan shroud?
It looks about the right gold color, though the pics of the differential in the test I'd posted, it looks darker. btw, those tests he concluded that gibbs wasn't holding up to outside conditions as well as the crc. His tests didn't include any engine heat though so it's not like it's conclusive. |
junkyardave Samba Member
Posted: Mon Oct 17, 2011 8:26 pm Post subject: |
hey just a thought you could pollish it by hand .
first have it soda blasted then sand it down with 150 grit
then keep going to higher grits and to reach tight spaces use a dremel
the only reason i know of this is my brother in law has did this in the past
for manifolds and transmisions .this sounds like a lot of work
to me. |
Westfabulous Samba Member
Joined: January 07, 2007 Posts: 4207 Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Posted: Mon Oct 17, 2011 8:48 pm Post subject: |
junkyardave wrote: |
to me. |
That is good advice too. That is exactly what I did to create this (minus the soda blasting), and I am very happy with the outcome:
_________________ *****************
"I will gladly pay you Tuesday for a hamburger today." |
Rob R Samba Member
Joined: April 24, 2006 Posts: 145 Location: Park City, Utah
Posted: Wed Oct 19, 2011 5:56 pm Post subject: |
I bead blasted my fan shroud and painted it with Glasurit clear.
Posted: Wed Oct 19, 2011 7:56 pm Post subject: |
awesome, thanks Rob for the pictures. that looks good! _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
74westy Samba Member
Joined: September 08, 2007 Posts: 143 Location: Auckland, New Zealand
Posted: Thu Oct 20, 2011 2:48 am Post subject: |
I'm trying to get the same OG look for the fan housing. I started with soda blasting to clean up and remove any corrision. This acheived mixed results. Now I am in the process of cleaning further with Tergo paint remover and metal conditioner. This contains phosphoric acid which I read was good for cleaning alumiium. This is working ok and gives a raw metal finish. I'm just brushing on, leaving for a few minutes and lightly scrubbing with a tooh brush.
The finish is a bit patchy but has the "gold" hue in some plaes. This "gold" hue is similar to the inside areas of the housing which have been sealed up from new when the two halves were bolted together at the factory. _________________ 1974 Westfalia 1800 AW Stock, Twin 34PDSIT
1970 Type 3 Fastback 1600TL Automatic |
SGKent Samba Member
Posted: Wed Jul 15, 2015 4:14 pm Post subject: |
I want to add to this old thread. Been doing some research on magnesium coatings for the 091 I am rebuilding. One example is Dow1 which is here.
http://www.thesamba.com/vw/classifieds/detail.php?id=587241
What I have discovered is that the processes made by Dow are no longer available although the formulas are so some folks still do them Dow 1 and Dow 17 were commonly used on mag alloys. I've learned that the processes were originally designed to be sacrificial - they protect the part while it is passing thru the manufacturing process and while it is on the shelf. Once on a car some of the processes can be gone in as little as 24 hours in say a place where slush with road salt gets on them. In open air they go away and change color as they go away. The gold turns to light gold in awhile, then a silverish, then dark gray - hence why we see so many colors. The inside of my trans for example is gold where the oil protected it from oxygen and gray outside where water and oxygen got to it. Ducatti uses a paint process to control their mag from oxidizing but the cost of the paint from colorrite is like $50 a can. ColorRite Ducati magnesium gold paint is the color.
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
notchboy Samba Member
Joined: April 27, 2002 Posts: 22461 Location: Escondido CA
Posted: Wed Jul 15, 2015 5:05 pm Post subject: |
What happened to Westfabulous? I thought he was well into cracking it?
So Im sure Mr Ruiz found an aircraft coater. Has you send him your stuff as a middleman then sends it back to you? Ive never run down the process here - and with all the Boeing engineers into ACVWs they have the answer on where and how for sure.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51148 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Jul 15, 2015 5:28 pm Post subject: |
The formula for Magnesium pickle solution was in many of the manuals I trained on for aircraft maintenance, it's not a proprietary Dow thing, they just packaged it already made. With the right connections in the chemical industry all the ingredients are still available, the issue is many are restricted or require some elaborate handling and disposal procedures, that's why no shops will do it anymore. Another issue was modern helicopters don't use magnesium for transmission cases, etc. like the old school ones did, many of the shops we contacted responded with a "chrome pickle?, what's that?", one said they would try some modern equivalents but after a few months the only thing they had done was lost a sample shroud.
Westfab and I are still on this, he's just taking a little break from the bus project to deal with other more important things, when we get back on it you'll read about it here. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Jul 15, 2015 7:38 pm Post subject: |
T127 industrial engine, zero hours, no coating on fan shroud. Note that since this picture was taken the fan shroud has become a corroded mess having been stored in a covered but unheated area.
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Wed Jul 15, 2015 8:23 pm Post subject: |
busdaddy wrote: |
Westfab and I are still on this, he's just taking a little break from the bus project to deal with other more important things, when we get back on it you'll read about it here. |
Not to convince anyone to work with things they are not prepared for.... but businesses. .....have to conform to EPA documentation, permitting and disposal regulations......however......the the Federal and most state EPA's......have a home exemption clause. I can use chemicals at home with no permit that 99% of all companies in the US....cannot.......and I am not required to do any more than local laws state for disposal or air emmisions.
So.....jf you want, to chrome pickle at home. ....buy the stuff and have at it. Just be warned....chrome 6 is more than, just carcinogenic. Ray |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Wed Jul 15, 2015 8:50 pm Post subject: |
here's my take....
stop over thinking this. glass bead the stuff, prep, tint your clear with gold, different ratios for different coats to give that crappy uneven finish.
someone send me a beaded shroud and I will work my magic...free. you pay for shipping and materials _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
SGKent Samba Member
Posted: Wed Jul 15, 2015 10:51 pm Post subject: |
Quote: |
The formula for Magnesium pickle solution was in many of the manuals I trained on for aircraft maintenance, it's not a proprietary Dow thing, |
Just Google Dow 1, Dow 17, magnesium finishing etc. The formulas come up BUT the point is that even if someone pickles it, besides costing a small fortune if they have it done commercially, the finish will go away with corrosion and moisture in the air unless they store the car as a show car and don't drive it in any weather. All the coatings on the mag are sacrificial meaning they are not designed to last, just keep it nice until shipped, or act as a base to paint. One can clear coat them if they want and that will help protect the finish. Or, simply find a paint color equal to Ducati magnesium gold paint. Have your paint shop mix a quart because it looks like there is a close GM equal.
Duplicolor Gold Mica - Bgm0491
Colorrite: http://www.amazon.com/Magnesium-Engine-Touch-Up-Aerosol-Desmosedici/dp/B00FJI9KWM
Example of ColorRite:
Here is Joe Ruiz's Dow 1
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Wed Jul 15, 2015 11:12 pm Post subject: fan housing |
The paint is UGLY and won't last and looks like a cross between the
SF49ers and Notre-Dame helmet colors.
Yuck! _________________ V.W.owner since 1967 |
SGKent Samba Member
Posted: Wed Jul 15, 2015 11:15 pm Post subject: Re: fan housing |
old DKP driver wrote: |
Yuck! |
Then pay Joe to Dow 1 your shroud once a year That is the process VW used. Per Joe "The parts are walnut blasted in preparation for the chem. treatment.... The chem. process that is applied is a DOW #1.... I don't know what you mean about durability / lasting since it is a sacrificial coating as applied by the factory back then to prevent oxidation to the magnesium in Germany's damp climate."
Dow 1 used on 356 from Joe's ad here. It is a fine process, according to the specs online it removes .0005" in the process and goes away over time - which is why it is gone on most of our shrouds except under things like grease that kept oxygen away. If Westfabulous and BusDaddy find something else that is great. I posted what I found here to save the next person some trouble when researching it. The inside of my 091 case is gold. The outside mag brown and gold with the amber cosmoline on it. I did not want to paint it black like Rick suggested and others do. Weddle uses silver with black highlights. Maybe pink with green dots would be nice As for shrouds - gold when brand new, shortly thereafter light gold-silver, then silver then mag gray-brown. All are correct for a shroud because the Dow 1 process ages. The newer processes used today that hold up are white.
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Jul 15, 2015 11:37 pm Post subject: yuck =GOLD |
That's why I have mine powder coated BLACK .......
& shiny and easy to wipe off the dust.
There were only a couple of years that VW actually used the gold colored
finish and most were 74 models including those in the 412 type-4
It's obvious it was an experiment that may have cost more $$ than it was worth.
Yeah, I was there back then and they looked Purty but, $$$$ talks and
that's not what the vw was interested in Cost reduction before the H2O MODELS with the famous Dasher. and it had No gold anywhere.....
anodizing a fan housing is/was. not a selling point just an experiment. _________________ V.W.owner since 1967 |
