DukeBradbury Samba Member
Joined: September 27, 2009 Posts: 400 Location: Spokane WA
Posted: Tue Oct 18, 2011 8:56 am Post subject: Rear Seat belt/Middle seat belt mounting |
I did search for the info, and found a couple threads that seemed promising but were incomplete.
I have a 1965 bus and would like to install middle and rear seat belts. I have the everything removed and easy access....
I was looking for seat belt mount locations off of a 67 (front and back) so I could duplicate what the factory did. Measurements and/or pics would be fantastic. |
voo Samba Member
Posted: Tue Oct 18, 2011 9:02 am Post subject: |
This is from a 66 standard with factory belts. Rear seatbelt mounting is behind the gas tank. These are the middle 2 with 2 more being outside the pic on the same "rail".
Posted: Tue Oct 18, 2011 9:17 am Post subject: |
Yes!!! Voo, exactly what I was looking for!
Any pics of the middle seat mountings? |
Clara Samba Member
velvetgreen Samba Member
Posted: Tue Oct 18, 2011 9:36 am Post subject: |
i believe that the bay window rear seat belt mounts (the ones that go behind the gas tank) are a different angle for the bays as they are for the splits.
i was able to massage them to fit but worth noting
also worth noting that the outer seat belt mounts in the rear need to go through the rear wheel wells.
Again I re-used bay window hardware for this purpose and this was much easier.
Dropping the engine and gas tank is a bit of a PIT just to install rear seat belts but tried to do it correct the first time.
if i am ever under the bus again i will take some pics |
Posted: Tue Oct 18, 2011 3:34 pm Post subject: |
Clara, thanks. And point well taken
I found tons of threads, just didn't end up on a picture or dimension that would work. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Oct 18, 2011 4:28 pm Post subject: |
There is another bracket/anchor that goes from the bottom of the tank bay down to the frame on an angle as well is there not? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
voo Samba Member
Posted: Wed Oct 19, 2011 5:07 pm Post subject: |
Last thing I want to do is mislead someone. My bus has two seatbelt codes 425 and 025, combined with titan red paint(before the black) on the seatbelt connections, which led me to believe it was factory. I must be mistaken. I will return to my seat in the classroom and continue to try and learn from the vast knowledge base here. |
SCZ9-1-1 Samba Member
Joined: May 20, 2003 Posts: 716 Location: Santa Cruz, CA
Posted: Thu Oct 20, 2011 5:11 am Post subject: |
My panel camper has seat belt M code as well, but they appear to be dealer installed with just holes drilled through the floor right behind the bench seat. No extra brackets. |
widehatch Samba Member
Joined: May 27, 2007 Posts: 775 Location: Memphis, TN aka The Armpit of the South
Posted: Thu Oct 20, 2011 6:05 am Post subject: |
i think my 67 kombi has middle seat belt mounts i think. i remember seeing factory style plugs. right now its sitting in the corner of my garage stuffed full of camper interior. give me a couple of days and ill clean it our and snap some pics. _________________ Missouri Micros |
Posted: Thu Oct 20, 2011 6:28 am Post subject: |
i just found a pic i already had. it sucks but you get the idea.
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Mon Apr 22, 2013 11:03 am Post subject: |
Do these help? Don't have any of the wheel well mounting point, but will try to get some.
Z Samba Member
Posted: Mon Apr 22, 2013 11:36 am Post subject: |
For the middle seats, these pics show the location pretty well, relevant to the other floor stampings. The seat belt bolts go into captive nuts attached to the bottom of the crossmember. I think there is a reinforcing plate between the nut and the crossmember itself. Again, will try to get a decent pic of this on my bus for you.
First pic shows the black plugs where the bolts go...second pic is a new KF floor stamping showing the flat spot and the hole for the bolt to pass through. Disregard the A, B and C markings - they are not relevant to this.
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Mon Apr 22, 2013 11:58 am Post subject: |
Just to add info to the thread, here's how to modify bay rear belt mounts for a split:
Stock bay left, modified for split right
Cut a couple small notches
Bend to 65 degrees and weld.
A lot easier than finding factory split brackets _________________ Tim |
Posted: Tue Apr 23, 2013 7:31 am Post subject: |
Thanks for the pics. I ended up making some seat belt brackets out of some 3.5" flat stock I had laying around. Not exactly like the factory, but they will work. I still need some pics of the outer bolt holes for the very back seat. I believe they go through the wheel well.
Here they are in the bus.
_________________ My 65 Deluxe build
http://www.thesamba.com/vw/forum/viewtopic.php?t=475798&highlight= |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Tue Apr 23, 2013 8:44 am Post subject: |
Nice job! |
Jerry Samba Member
Posted: Tue Apr 23, 2013 9:57 am Post subject: |
To use seatbelts for the middle seat, is it necessary to cut holes in the cargo floor mat? Were 67 cargo mats already cut for the belts? _________________ Looking for SO34 parts.
thevwcompound *instagram* |
Z Samba Member
Posted: Tue Apr 23, 2013 10:39 am Post subject: |
Here are (crappy) pics of the outer bolt areas. Good camera is w/o a cable at the mo, so these are as good as the cell gets.
