devesvws Samba Member
Joined: January 05, 2004 Posts: 1540 Location: madison va
Posted: Wed Oct 03, 2012 4:51 pm Post subject: |
Those generic inline filter are available most anywhere, but as stated before they may not be able to handle the flow rate of a FI system which can be many times that of a carbureted system. |
Posted: Thu Oct 04, 2012 2:54 pm Post subject: |
devesvws wrote: |
Wildthings wrote: |
yes but very little fuel psi from tank to pump right? |
Yes, there is very little pressure to force fuel through the filter which could result in the pump cavitating. A prepump filter should have either a large filter area, a course filter medium, or both.
I have never tried using one of the later round FI filters as a prefilter. While it has a fairly fine medium, it is at least fairly large. Maybe someone who has tried using one of the later style filters as a prefilter will comment. |
dubbified Samba Member
Joined: March 03, 2010 Posts: 1406 Location: Redmond, WA
Posted: Sat Oct 06, 2012 10:56 pm Post subject: |
I've nearly a year on this setup, seems to work fine.
Dude at Napa had this to say when I asked him about any restriction..
It is used for many applications, but alot of people used them on 305/350 engines
I found it overkill for a 4 banger.
dont run a filter, see what happens..
Run a filter.. See what happens.
Either you replace a pump sooner, or later. Its really up to you.
I decided to see what comes of running a filter. |
Posted: Sun Oct 07, 2012 10:36 am Post subject: |
dubbified wrote: |
I have been running Vanagons as daily drivers for twenty plug years at this point and excepting a couple of years of driving a 83 1/2 with a stock cube prefilter I have never had a problem, in particular no pump failures at all. I do have stock tanks and not aftermarket ones.
These cheapy inline filters were very common add ons to almost all engines back before fuel injection became common place. What might have worked very well on a 350 with a 4 barrel may not work all that well with a FI 4 banger that actually flows much more fuel. It could be that their media is actually so course it doesn't cause any problem, but I personally would prefer a filter with a much larger media area. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17014 Location: Retired South Florida
Posted: Sun Oct 07, 2012 12:05 pm Post subject: |
From memory, the pump circulates about a gallon per minute back to the tank. That would be 60 gallons per hour. You would want to know what the filter's flow rate is. As the filter starts to accumulate crud, the flow rate will suffer. Any restriction on the inlet of the pump is not good for it. Crud is also not good for the filter either. So, use an adequate filter as suggested or possibly a filter that you can tie the FI return into before it returns to the tank. _________________ ☮️ |
