AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Mon Apr 08, 2019 5:49 pm Post subject: Re: Little Buddy-type portable heater for Van? |
I run the little buddy off my refillable propane tank. Hated those green bottles. _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
kamzcab86 Samba Moderator
Posted: Mon Apr 08, 2019 5:51 pm Post subject: Re: Little Buddy-type portable heater for Van? |
westyventures wrote: |
These silly flame heads that screw onto a bottle? O.M.G. - why? Might as well use the Westy stovetop. I travel almost always with long-fur dogs, and know that maintaining a constant temperature in a camper uses less fuel, everything stays warm to the touch, and more pleasant to live in for a month or two on the road - that's why I use and sell Propex plus Espar diesel furnaces in some of my diesel / no propane rigs. I and my 'kids' are worth it. |
A) I don't have one real dog, let alone multiple long-fur dogs.
B) I don't live in my van, nor do I spend a month or more on the road.
C) I don't generally camp in freezing weather.
D) I don't use the heater as a furnace; the longest I've ever run a heater inside my van has been a couple of hours. As said up ^^^there, I don't sleep with a portable heater running.
E) I don't take the heater on every road trip.
F) Calling it a "silly flame head" shows you don't know the product and, perhaps, should refrain from making inflammatory (pun intended) remarks regarding them.
Thus, for some travelers the portable heaters are preferred. For others, the built-in furnaces work best. I realize you sell the product, but, sorry, I, personally, am not spending $800 on a furnace that will take away a chunk of my storage space and, more importantly, go unused 95% of the year. I do what's best for me, others do what's best for them.
And, yes, I know someone who died as a result of CO poisoning inside his camper shell.
?Waldo? wrote: |
Yipes! Back when I was in my 20s I did a cross country trip in a '74 westy with one of those (no heat otherwise). No thanks! I STILL have a headache from it. |
And I wouldn't be stupid enough to run a portable heater inside my vehicle while driving.
I've said it a hundred times now: My heater is not run inside a closed-up van; in fact, I try not to run the heater inside the van at all unless it's necessary. My heater is not run while sleeping. _________________ ~Kamz
2016 Golf GTI S
WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Mon Apr 08, 2019 6:10 pm Post subject: Re: Little Buddy-type portable heater for Van? |
?Waldo? wrote: |
The amount of water that is put into the air is significant. |
Well, if properly vented the exiting residual heat shoves a lot of that (moisture)outside fairly quickly. I usually open the skylight about 1/2" unless it's raining hard, then the door windows also down half an inch. On occasion I'll even have the slider door window open about an inch. But keep in mind most users of the Buddys have them on in the evening and again in the morning, not all night.
?Waldo? wrote: |
The Westy kitchen is perfectly designed to deposit that moisture in the fiberglass insulation behind the cabinets. |
I have a weekender so the kitchen issue is solved |
westyventures Samba Member
Joined: December 29, 2004 Posts: 2306 Location: Oregon Outback
Posted: Mon Apr 08, 2019 6:36 pm Post subject: Re: Little Buddy-type portable heater for Van? |
kamzcab86 wrote: |
These silly flame heads that screw onto a bottle? O.M.G. - why? Might as well use the Westy stovetop. |
You don't have to agree, but I M O the 'Stansport' rudimentary 'heater' is unsafe to have inside a van, regardless of whether you're careful with it or not. |
cmayna Samba Member
Joined: August 18, 2014 Posts: 1148 Location: SF Bay area, CA
Posted: Mon Apr 08, 2019 6:37 pm Post subject: Re: Little Buddy-type portable heater for Van? |
My wife is my Little Buddy and she keeps me very warm at night in the Dub. _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
?Waldo? Samba Member
Posted: Mon Apr 08, 2019 6:38 pm Post subject: Re: Little Buddy-type portable heater for Van? |
kamzcab86 wrote: |
?Waldo? wrote: |
And I wouldn't be stupid enough to run a portable heater inside my vehicle while driving. |
I wouldn't either, now.
WestyBob wrote: |
?Waldo? wrote: |
Well, if properly vented the exiting residual heat shoves a lot of that (moisture)outside fairly quickly. |
The amount of moisture added to the vehicle is proportional to the amount of added heat. To 'properly' vent the moisture, you would need to exchange enough air that you wouldn't get any heat benefit from running the heater. |
Tobias Duncan Samba Member
Joined: January 15, 2013 Posts: 1391 Location: Taos NM
Posted: Mon Apr 08, 2019 9:03 pm Post subject: Re: Little Buddy-type portable heater for Van? |
I am a desert camper 95% of the time so the extra moisture does not even register. In the winter in Taos you get some condensation on the windows in the morning but its gone soon after you get going.
As far as danger , math is your friend. Just calculate the BTUs and make sure you have right number of square inches open to the outside and you CANNOT die.
I recognize that this board errs waaay on the side of caution and thats fine but many many people run these units in all sorts of campers and tents and live to tell the tale. The only danger is you forgetting to crack the windows the correct amount.
Safety is about understanding the actual risks and deciding what is right for you.
Many people would never get in a vintage van because of lack of air bags and crumple zones. |
Posted: Mon Apr 08, 2019 9:35 pm Post subject: Re: Little Buddy-type portable heater for Van? |
I hope I'm not repeating anything in this long thread but in Portland (OR) over the past months there has been what seems to be a small but growing 'run' on a Wabasto diesel heater kit -- I think this is it:
https://www.walmart.com/ip/12V-5KW-Diesel-Air-Heat...gIAk_D_BwE
It's actually available from other sources like Amazon too but a nearby friend got his for $160 and by the time installation was complete (he and a friend) it came to $200. I know of three others who have purchased/installed with one intending right now so you could say it's become 'all the rage'.
I did see up close my friend's in operation -- whisper quiet with a 10 liter tank and a remote. He said it's been operating perfectly so far but ask him in five years and we'll see |
Posted: Mon Apr 08, 2019 9:54 pm Post subject: Re: Little Buddy-type portable heater for Van? |
That's the same type of heater as is discussed in the thread I linked above and my inquiry was specifically regarding what advantages the heater buddy would have over that type of heater.
WestyBob wrote: |
Some Buddy upsides:
(1) They are portable.
(2) They don't require drilling holes in the rig.
(3) They are easy and quick to set up.
(4) If used correctly you shouldn't have condensation plus rusting to a nub.
(5) They heat the westie up very quickly - even the small one.
(6) I think they are cheaper than an on-board system ? |
Here's my take on those 'upsides'.
(1) Being portable is a disadvantage, IMO, as opposed to a decent install in an appropriate location. Portable means that it is in the way taking up prime real estate. Installed intelligently means that it is in a permanent location out of the way and taking up space that is difficult to access for easy storage.
(2) I'm not a purist. I like to do quality work that meets or exceeds the original factory designs, but holes that fit that description don't bother me.
(3) There is the initial installation to consider for the Webasto style heater, but once installed nothing is easier or quicker to 'set up' than a heater that is already installed and just needs a button pushed.
(4) That's not an upside over no additional humidity at all being introduced to the vehicle.
(5) Similarly, that isn't an upside to the heater buddy over one of the webasto style heaters. If anything the webasto style will do a better job of heating up the vehicle as it doesn't require additional ventilation.
(6) I haven't priced out the heater buddy prior to seeing the link that was posted to the one on Amazon costing 180 euros. At that price the Webasto knock-off is less expensive. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Mon Apr 08, 2019 10:35 pm Post subject: Re: Little Buddy-type portable heater for Van? |
I'm actually a big fan of my Big Buddy as well.
Portability means I can use the thing sitting outside the van on a cool night when open fires are not allowed.
I can also use it inside my house as an emergency heat source.
It has a built in fan that uses replaceable batteries to circulate air around the interior.'
I have a couple ways to hang/mount it that reduces the space issue.
We use it to heat the van prior to bed, then turn it down to the pilot light and it keeps our insulated van comfortable all night. Then the first one up turns the knob to low and it heats the interior before we officially crawl out of the bed.
In summer, we don't carry it.
We leave it on when out of the van for a few hours on winter trips. Awesome - like coming home to a warm house, it's so cheery.
Now I find out it can even keep my coffee warm! (Thanks, Sodo).
Downsides:
I can forget to pack it.
I do worry about combustibles getting in front of it.
Though they're everywhere, it requires me to carry propane bottle spares just in case, though it's the same thing our two burner camp stove uses for uniformity of fuel.
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Mon Apr 08, 2019 10:39 pm Post subject: Re: Little Buddy-type portable heater for Van? |
I think you just justified what is best for you, Waldo !! |
Posted: Mon Apr 08, 2019 10:58 pm Post subject: Re: Little Buddy-type portable heater for Van? |
Oh, and I forgot. As purchased, it is the only portable heater I found that will run overnight on low if I want/need it to. I think it's internal dual bottles will let it run about 11 hours. However, I purchased a full size RV propane bottle and a 15 foot hose that allows it to run for a reeeeaaaallly long time if I were to need it. I have not perfected a tank mount but am thinking roof mounted, or simply on the ground with the hose running in the window. So there is the ability to make one of these semi permanent or seasonal. I mount mine on the back of the passenger front seat, but have built a bracket I have not yet mounted as I'm still thinking.
As another bonus, I can also use it in the Mitsubishi Van and have used it in the LandCruiser as well where I mount it on the overhead grab handle farthest back in the cargo/sleeping area. We've also used it in the boat cabin. So if you have other vehicles the portability works for you there also. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
CoastieLFS Samba Member
Posted: Wed Jun 02, 2021 11:12 am Post subject: Re: Little Buddy-type portable heater for Van? |
Just came across this thread. Thought I would add to the discussion by sharing my own post on how I typically use the Little Buddy while supporting local cafes...
https://www.thesamba.com/vw/forum/viewtopic.php?t=685759&highlight= _________________ '95 Eurovan Camper (2.5L)
'01 Weekender
Portland, OR |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Wed Jun 02, 2021 12:14 pm Post subject: Re: Little Buddy-type portable heater for Van? |
Nice revival
I moved on from the Buddy. My CO alarm went off a couple of times I forgot to open the windows. My bus was also heavily endowed by moisture from the LP combustion, and I could tell that was just not a good long term solution.
Not knocking those who do use them, but the are costly in different ways. Death would be the ultimate cost. Smaller creatures, like 3 dogs, perhaps, might expire more quickly than you, and then IF you woke up, you would get to have that on your shoulders, too.
Read the CDH thread.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9241284 _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Posted: Wed Jun 02, 2021 12:24 pm Post subject: Re: Little Buddy-type portable heater for Van? |
bobbyblack wrote: |
Nice revival
I moved on from the Buddy. My CO alarm went off a couple of times I forgot to open the windows. My bus was also heavily endowed by moisture from the LP combustion, and I could tell that was just not a good long term solution. |
hmmmm.... as an experiment, i sealed up my van and ran the Buddy to see what the CO level would do. after a couple hours, the flame extinguished via the oxygen deprivation safety feature and the digital CO detector stayed at zero.
what WILL spike the CO detector immediately is running the stove for a pot of coffee.
yes, the moisture is a problem. gotta have venting open but you do even if there is no propane heater inside. _________________ -dan
www.thefixitworkshop.com |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Wed Jun 02, 2021 12:34 pm Post subject: Re: Little Buddy-type portable heater for Van? |
I have read that yellow flame is an indicator of CO production. Set/clean/maintain/etc your burners for blue flame.
A buddy heater on high, and maybe dirty/old etc (????) can havre orange flame.
I don't know if orange counts as yellow. _________________
....KTMs, GasGas, SPOT mtb |
Posted: Wed Jun 02, 2021 12:43 pm Post subject: Re: Little Buddy-type portable heater for Van? |
on the stove, i have perfect blue flame with white tips. puts out CO like crazy as does ANY indoor propane cooking stove.
the Buddy uses a cermaic catalyst to turn the flame into a glowing substrate. very clean.
the O2 sensing on the Buddy and other propane heaters is is not some high tech device that measures the oxygen, but is just the relationship between how the pilot flame burns and the position of the thermocouple that keeps the gas valve open. As the oxygen level decreases the flame pulls away from the thermocouple and the gas valve shuts off. it works but is also why Buddy heaters don't like real high altitudes. _________________ -dan
Nuthin2It Samba Member
Joined: December 31, 2011 Posts: 306 Location: Marietta, GA
Posted: Thu Jun 03, 2021 12:42 pm Post subject: Re: Little Buddy-type portable heater for Van? |
I have a Mr. Heater Portable Buddy Radiant Heater. As to how much to open a window for ventilation, I actually read the owner's manual! In the part that nobody reads, the "General Safety Instructions," it says:
"This heater requires a vent area of 9 square inches (example 3” x 3” opening) minimum for adequate ventilation during operation."
That means that one of the 29" wide front door windows needs to be rolled down about 0.3". And I suspect that the 9 square inches is a very conservative number.
As for me, I roll down both windows about 1/2" just to be sure. _________________ 1985 Westfalia 15 degree EA288 Boxeer |
vegpedlr Samba Member
danfromsyr Samba Member
Posted: Thu Jun 03, 2021 7:44 pm Post subject: Re: Little Buddy-type portable heater for Van? |
interesting for spot warming.
Fuel: Butane (Nozzle type gas canister)
Consumption: 71g/h (840kcal / 3,333BTU /0.98kW)
butane is 21640BTU per pound.
the canisters are 8oz.. is that weight or volume?
so thats 10,820btu per can.
so about 3hrs per can about a buck an hour.. _________________
Abscate wrote: |
