VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Thu Oct 27, 2011 2:45 pm Post subject: Recommended compression ratio |
what compression ratio is recommended for a Engle W140? this is for a.... interesting build. _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
baked beetle Samba Member
Joined: September 23, 2006 Posts: 1162 Location: Alberta, Canada
Posted: Thu Oct 27, 2011 2:48 pm Post subject: |
10.5:1 + _________________ These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
____________________
66' His
57' Theirs
63' Hers
62' Drag Bug - Theirs 13.1 @ 101 mph (GONE) |
Posted: Thu Oct 27, 2011 2:58 pm Post subject: |
Stratospheric! awesome! .... hi-po, hi-po to grind the cylinders we go.... .... race fuel, oh race fuel... where for art thou oh race fuel? _________________ Schnell, SCHNELL!
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Thu Oct 27, 2011 3:41 pm Post subject: |
baked beetle wrote: |
10.5:1 + |
That's what I'm running with my FK-44... _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
SamT Samba Member
Joined: April 17, 2009 Posts: 1761 Location: Rule, Tx
Posted: Thu Oct 27, 2011 4:08 pm Post subject: |
is engine for a race car or street? |
Posted: Thu Oct 27, 2011 4:22 pm Post subject: |
I ran 11:1 on premium Shell gas 92 octane. But I'm in Canada and we have good gas _________________ These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
66' His
57' Theirs
63' Hers
Posted: Thu Oct 27, 2011 7:01 pm Post subject: |
SamT wrote: |
Street......three-four days a week.....and I will be driving it distances to shows......and yes it will run cool.......black magic in the heads and running ALL factory doghouse tin.....93 octane fuel...tuned properly....gonna be fun
........or were you talking about the posters 140 _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Thu Oct 27, 2011 7:09 pm Post subject: |
Yeah, run 12:1 you'll be fine!!
You guys are nuts! What's your engine specs other than a W140 cam? _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
Posted: Thu Oct 27, 2011 7:24 pm Post subject: |
DarthWeber wrote: |
You guys are nuts! What's your engine specs other than a W140 cam? |
Nah......that's just too much.....10.5:1 is perfect for 93 octane......and the FK-44..........
....yeah, what's the rest of the motor? Who's doing the heads for ya? _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Thu Oct 27, 2011 7:26 pm Post subject: |
Won't work for everybody
the high CR is ok for in town and short bursts, but try to race up a mountain pass with your 10-1 and let me know how it goes.
knock knock, rattle rattle
who's there?
it's your rings and rod bearings, they have some complaints |
Posted: Thu Oct 27, 2011 7:32 pm Post subject: |
modok wrote: |
who's there?
No mountains here ..........I'll have gauges to keep track of it.........and the "black magic"! _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Posted: Thu Oct 27, 2011 7:33 pm Post subject: |
And if I get too crazy and run it into the ground I can just build another and create another thread! _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Posted: Thu Oct 27, 2011 7:38 pm Post subject: |
modok wrote: |
who's there?
Actually talked to my buddy Raymond about a little 1835 he built for a guy named Ray Hulvey.....10:1 compression ratio and dude drives it everywhere.....drives the shit out of it ........daily........and has been for over a year......it still runs strong.......Berg was a great innovator and basically the grandfather of the hot rod VW scene, but he was a bit full of shit when it came to compression ratio......or maybe just a tad closed minded ......anyway, its not being built to last forever .....being built for fun _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
modok Samba Member
Posted: Thu Oct 27, 2011 7:51 pm Post subject: |
It can be done you just have to pay attention.
As it is now I run mid grade gas at 9-1 even, then if the temp goes over 80 and the humidity goes under 20% I just fill with premium gas before getting on the highway.
I used to adjust the timing a lot, now I leave the timing alone and adjust the gas
I never seen an engle 140, only heard they exsit whatever duration it has I bet it wants 9.5-1 at the least |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Thu Oct 27, 2011 8:04 pm Post subject: |
fivelugshortaxle wrote: |
modok wrote: |
who's there?
Actually talked to my buddy Raymond about a little 1835 he built for a guy named Ray Hulvey.....10:1 compression ratio and dude drives it everywhere.....drives the shit out of it ........daily........and has been for over a year......it still runs strong.......Berg was a great innovator and basically the grandfather of the hot rod VW scene, but he was a bit full of shit when it came to compression ratio......or maybe just a tad closed minded ......anyway, its not being built to last forever .....being built for fun |
Berg's opinions on compression ratios were formed at a time when the composition (and quality) of gas was changing rapidly. His recommendations were for customers that expected stock life from modified motors and yes, he erred on the side of caution. You have to remember this is a guy that got some 140,000 miles on his own 138hp bus motor.
Yes, higher cr in your beast will give more power, but as you say, it won't last forever. And if you push the limits hard enough it won't be a drive any where beast at the drop of a hat either. It's all about what you want... _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Posted: Thu Oct 27, 2011 8:05 pm Post subject: |
modok wrote: |
I don't think the humidity ever drops below 20% here in GA........ _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Posted: Thu Oct 27, 2011 8:48 pm Post subject: |
modok wrote: |
Mitey62 wrote: |
Posted: Thu Oct 27, 2011 8:50 pm Post subject: |
ALB wrote: |
modok wrote: |
who's there?
Yes, higher cr in your beast will give more power, but as you say, it won't last forever. And if you push the limits hard enough it won't be a drive any where beast at the drop of a hat either. It's all about what you want... |
Exactly! Nah.....won't be abusing the motor.....will get pushed at the track on a every now and then basis but will be driven smoothly most of them time...and at freeway travel I'll be sensible.....no screaming down the highway at 80 MPH for me....just occasional bursts of speed, nothing for extended periods.....65 Mon on the nose is just fine for me....should keep fan speed at the sweet spot......CRAP....SHIT.....I CAN'T WAIT TO BE CRUISING IT AROUND! _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
ALB Samba Member
Posted: Thu Oct 27, 2011 8:51 pm Post subject: |
modok wrote: |
Engle W140- 313' adv dur, 274' @ 0.050" .424" cam lift .465" (1.1:1)
and for those interested in cam trivia;
Engle W160- 328' adv dur, 288' @ 0.050" .433" cam lift .475" (1.1:1) _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Posted: Thu Oct 27, 2011 8:53 pm Post subject: |
ALB wrote: |
modok wrote: |
Engle W160- 328' adv dur, 288' @ 0.050" .433" cam lift .475" (1.1:1) |
W160?...wow! _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
