The perfect custom WHEEL? Size, offset/etc? (not tire)
airkooledchris
Location: Where the pacific ocean meets the redwood forest
airkooledchris is offline
PostPosted: Thu Nov 03, 2011 11:39 am    Post subject: The perfect custom WHEEL? Size, offset/etc? (not tire) Reply with quote
The custom car market has been exploding in size over the past ten years and custom wheel makers are everywhere these days.
You can get wheels made to any custom size you want now, which got me thinking - what would be the perfect wheel for us?
People usually settle for thing that are 'close enough to stock' - but have we been finding other offsets or overall diameter changes Vs stock to perform better for our busses?
This treads dangerously close to Tire Sticky thread territory, but we are usually fighting to find tires to fit the wheels we already have. What if you could run whatever sized wheel you wanted as a starting point?
Or has nothing in technology changed since these busses were built - that running with a different width/size/offset would give you any added benefit?
SEMA is going on right now, and there must be 40 different wheel manufacturers out there with the ability to setup their designs in nearly any size/offset and bolt pattern we want. Not saying it would be cheap, but is it even worth doing?
metahacker wrote:
... i would say that, if it's an option, (edited) not listen to any forum pessimism..
topaz.
topaz. is offline
PostPosted: Thu Nov 03, 2011 12:11 pm    Post subject: Reply with quote
I wish there was a Der Steiner Rad wheels made for a T2B offset and bolt pattern. Smile
RatCamper
RatCamper is offline
PostPosted: Thu Nov 03, 2011 12:45 pm    Post subject: Reply with quote
Honestly?
I'd like something either like a stock steelie or a Sunraysia steel wheel. 15", possibly 16" but the tyres I want might be too high profile. As for offset the stocks are close-ish already. If I could steal maybe an extra 1/2" inside and out that'd be nice.
Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002.
ccpalmer
ccpalmer is offline
PostPosted: Thu Nov 03, 2011 5:41 pm    Post subject: Reply with quote
OK I'll bite...
I want a wheel with chrome VW spinners! Or... floaters...
'71 Westy
airkooledchris
PostPosted: Thu Nov 03, 2011 9:48 pm    Post subject: Reply with quote
I like the steel style wheels as well, and the custom off-road guys do make steels in pretty much any size and setup you could want.
15 inch wheels with a bit of a wider stance would be nice, or even stagger them to put the wider ones out back and go closer to a stock width up front.
for a custom wheel that someone probably already makes, though who knows if they can do it in any size someone would want - I dig this style a lot:
they are old Shelby Cal 500's, which are 15x7's.
fastmc25
fastmc25 is offline
PostPosted: Thu Nov 03, 2011 10:34 pm    Post subject: Reply with quote
About as close as you'll get.... I too am a fan of the slots...
http://www2.cip1.com/ProductDetails.asp?ProductCode=C38%2DDR%2D738
Peace,
Paul
1973 Type181 Kubelwagen (Kubel)
1971 Transporter (Pickle)
1961 Deluxe Beetle (Christine)
1973 Adventurewagen Baja Bus (Clyde)
"I spent the first 20 years of my life trying to bag some weed....... and now the rest of my life ....just bagging weeds......"
chabanais
chabanais is offline
PostPosted: Thu Nov 03, 2011 10:36 pm    Post subject: Reply with quote
A couple of grand and it can be yours.
"I spud therefore I yam."
