germanysfinest Samba Member
Joined: January 19, 2008 Posts: 381 Location: L.A. CA
Posted: Fri Nov 04, 2011 8:11 am Post subject: Vanagon H4 headlights into Bay? |
Hi everyone!
I have a set of Euro spec Vanagon H4 headlights. Can these be made to fit a US spec bay? Any hints would be appreciated!
Thanks!
Alex |
ned Samba Member
Joined: June 28, 2004 Posts: 1574 Location: Arroyo Grande Ca.
Posted: Fri Nov 04, 2011 8:29 am Post subject: |
If you already have the H4s why not just try and put them in. If they don`t fit, which I think they will, you can always just put your original back in . You don`t even have to do both. You may need the hardware from inside the Vanagon head lite bucket though. |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Fri Nov 04, 2011 8:45 am Post subject: |
.. round lights or rectangular? |
copellos Samba Member
Joined: February 18, 2004 Posts: 937 Location: sonora ca
Posted: Fri Nov 04, 2011 8:46 am Post subject: |
go for the rectang....ill get my sawsall... |
Posted: Fri Nov 04, 2011 8:50 am Post subject: |
They dont pop right in because of the mounting tabs on them. They are the round units and I took them out of a Vanagon to convert my US Bay to European spec because I just moved back to Europe and took my bus with me .
Just wanted to see if anyone ran into the same problems before. |
josh Samba Member
Joined: July 13, 2003 Posts: 1773 Location: laid back in the tall grass
Posted: Fri Nov 04, 2011 8:44 pm Post subject: |
germanysfinest wrote: |
The 7" round headlights sold in the US are for the most part universal fit, even if you buy euro spec lensed ones. I actually pulled a set of euro spec H4s from a Vanagon and installed them in a bus. They fit just like stock.
I wonder if some Vanagons in europe got a different headlight setup. I know some GTIs came with some round headlights that are quite a bit bigger than standard 7". _________________
modok wrote: |
...If If stoner A takes a hit and then stoner B goes right away(not waiting two seconds), he's trying to suck on it while it's still got a vaccum, doesen't get much of a hit at all! Cause it hasn't filled back up all the way yet.
Stoner A is cylinders #2/4 B is #1/3 The plugged bowl is the throttle, the bong is the manifold |
