Split arm rest
Egypt Classic Cars
Egypt Classic Cars is offline
PostPosted: Sun Nov 06, 2011 11:39 pm    Post subject: Split arm rest Reply with quote
I am starting now the restoration of my 1950 split, I was very lucky that I found another 1950 split body in a vw workshop for around 29 years, I am using this body on my chassis as the last body have no title
I found this arm rest with the body it looks original but without a hole in the D shape, also the previous owner drill the bottom part to attach it with the arm rest body, I need to know how this bottom part originally attached to the arm rest body?
Ashraf
1950 Split Window
1953 Zwitter
beetlekey
beetlekey is offline
PostPosted: Mon Nov 07, 2011 10:48 am    Post subject: Re: Split arm rest Reply with quote
Hi,
you are lucky owner of 53 - 55 armrest.
Marcus
If you are searching for vintage keys, look here:
https://www.facebook.com/WagenmanufakturHO
Egypt Classic Cars
PostPosted: Mon Nov 07, 2011 12:30 pm    Post subject: Reply with quote
If this for 53-55 arm rest what about the following picture it is from West coast for the interior of 1950 split?
Ashraf
1950 Split Window
1953 Zwitter
splitjunkie
splitjunkie is offline
PostPosted: Mon Nov 07, 2011 1:04 pm    Post subject: Reply with quote
West Coast does nice work, but their restorations are not necessarily 100% correct. As with any shop, ultimately it comes down to how correct the owner of the car wants it to be and how much money they have to spend.
Chris
ewanzke
ewanzke is offline
PostPosted: Fri Oct 12, 2012 4:37 pm    Post subject: Arm Rest 1950 Split Reply with quote
Uh, sorry for the q:
Does this bottom of the armrest have upholstery or just the plain "plastic" material?
virtanen
virtanen is offline
PostPosted: Sat Oct 13, 2012 12:09 am    Post subject: Reply with quote
Bottom has a painted sheet metal part, have you lost it?
Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects
ewanzke
ewanzke is offline
PostPosted: Sat Oct 13, 2012 9:43 am    Post subject: Thanks Mika Reply with quote
Thanks Mika.
No, I got into a bizzare argument about it. Mine is correct, metal...no upholstery...can be opened for access to the screws...thanks and greetings from Mexico...
Heini
DavidJean
DavidJean is offline
PostPosted: Mon Oct 15, 2012 4:36 am    Post subject: Reply with quote
Hi!
Here are a few pics of the 50 arm rests. It is made of 2 pieces of metal.
Hope it helps!
Greetings from Belgium Smile
'50 split
'60 ragtop:
http://www.coxlessinoise.be/phpBB2/viewtopic.php?t=13051
Older VW projects:
http://vintagevw.free.fr
fusca66
fusca66 is offline
PostPosted: Mon Dec 09, 2013 5:17 pm    Post subject: Reply with quote
Hello DAvid,
My 51 is missing the arm rests, and I have a friend who works with wood, talked with him and told me he manages to come make a copy if I had the measurements, if not annoyance you , can you could pass the measures to me for I try to make a copies on wood? I'm not as purist trying to find or pay a fortune in a metal, then covered anyone will see. :wink:
Thanks and greetings from Brazil :D
DavidJean wrote:
Hi!
Hope it helps!
Greetings from Belgium :)
Bug 1966
Na duvida não ultrapasse
beetlekey
PostPosted: Mon Dec 09, 2013 10:54 pm    Post subject: Reply with quote
DavidJean wrote:
Hi!
Hope it helps!
I have copys of them in stock. They are often missing. Little stronger material.
Marcus
