vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Wed Nov 09, 2011 4:13 am Post subject: Seat adjuster cams? |
where the hell do I get new seat adjusters from. Its those weird looking cam things inside the front seat bases.
Mine are rooted regardless of the rest of the seat looking NOS.
Anyone have any ideas? they are made from gay die cast and would explain how they wore so fast despite hardly being driven. |
supaninja Samba Member
vlad01 Samba Member
Posted: Wed Nov 09, 2011 1:43 pm Post subject: |
hmmmm....??
Bert!.... BERT! make us some
haha jk |
flyinglow94 Samba Member
Joined: January 17, 2005 Posts: 1164 Location: Las Vegas, Nevada
Posted: Wed Nov 09, 2011 4:10 pm Post subject: |
I wonder if they could or should be machined on more of an eccentric to recline a little more? I am re doing my seat and might need to answer that for my self. _________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.." |
vlad01 Samba Member
Posted: Wed Nov 09, 2011 4:49 pm Post subject: |
Yes they could a little bit more.
My idea is to have them CNC from steel and also have a weld on slot in solid thick steel to give exponentially more surface area to contact, say? 10-12mm wide instead of the few mm of the seat base frame. I noticed this thin and sharp slot just cut straight through the cam's sleeve.
there is ample room for an additional slot to be welded on. |
68notch Samba Member
Joined: August 16, 2007 Posts: 544 Location: Perth, Western Australia.
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33999 Location: Conejo Valley, CA
Posted: Wed Nov 09, 2011 6:00 pm Post subject: |
Traditional weak point in the seat design. Hard to source used ones that aren't also trashed.
Unless the owner was religous about leaning the seatback forward while adjusting (or if there was only one driver who never adjusted it!), the friction wore the cam surfaces out quickly. Also, the part that bears down on it doesn't cover the entire surface, concentrating the load. Just a very poor part design. A lot of load on the knob and roll pin holding it to the shaft, too.
I'd be up for buying a new one out of something stronger than the pot-metal the OEM parts are made of, as long as the price wasn't outrageous.
I wonder if this is a good candidate for one of those "metal printing" outfits, rather than requiring the complex machining or expensive casting mold other methods require. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Wed Nov 09, 2011 6:46 pm Post subject: |
Why not just take it to your local welder, and have him build them back up. You'll just need to find someone who welds aluminum. After all, that's how you repair "pot metal". _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vlad01 Samba Member
Posted: Wed Nov 09, 2011 6:51 pm Post subject: |
68notch wrote: |
Just a thought to try and fit the passenger side one to the drivers side even if it needs some modification. I guess the passenger side ones are probably quite good in comparison? |
nah, buggered too. |
vlad01 Samba Member
Posted: Wed Nov 09, 2011 6:54 pm Post subject: |
KTPhil wrote: |
you mean 3D printing? |
Posted: Wed Nov 09, 2011 7:00 pm Post subject: |
vlad01 wrote: |
68notch wrote: |
Other type 3s? _________________ John
68 Aussie notch
2011 Citroen Berlingo
https://www.facebook.com/Fastacraft
RHD dash pad project http://www.thesamba.com/vw/forum/viewtopic.php?t=475227 |
vlad01 Samba Member
Posted: Wed Nov 09, 2011 7:11 pm Post subject: |
I never see any good ones.
All my other type 3 that I owned in the past with the earlier (non 73 seats) seat were shocking. So bad the the shafts were broken and I had spare tires behind to keep the seat back upright and not falling flat.
This is the first type 3 with the non 73 3 point seats where the seats back was still upright and I could actually sit in.
I think action needs to be taken, people we need steel repops kits.
Only person I can think of that has the capabilities to make them quality and in reasonable quantity is Bert? who else do you guys know? |
Posted: Wed Nov 09, 2011 7:41 pm Post subject: |
vlad01 wrote: |
I could cast composite replicas that are full of metal powder and fibre for strength but that may not last either. It would appear original to look at though. _________________ John
68 Aussie notch
vlad01 Samba Member
Posted: Wed Nov 09, 2011 8:11 pm Post subject: |
obviously this ain't a job for our country. We don't "manufacture" anymore.
What if we develop 3d cad drawing and send it to someone capable in the US for the machining? |
vlad01 Samba Member
Posted: Wed Nov 09, 2011 9:26 pm Post subject: |
I don't think bronze would be good either and its too soft like die cast alloy.
Lanner probably could do it? |
Posted: Wed Nov 09, 2011 11:20 pm Post subject: |
Bobnotch wrote: |
Why not just take it to your local welder, and have him build them back up. You'll just need to find someone who welds aluminum. After all, that's how you repair "pot metal". |
I am thinking they break like the new car seats ( with some one trying to adjust them with there full weight on them when doing so). That is alot to ask from a Die cast or even an aluminum part.
If they are a Die cast alloy it is Hi in zinc like Hot Wheels. It melts at a much lower temp than aluminum. I guess I'm saying its not as easy as welding
aluminum.
supaninja wrote: |
I have been researching sand casting. It will be a hot minute but what about a cast bronze one?
BTW-we don't make anything anymore either
lad do you think Lanner could do it? |
I have also been looking into building a small foundry to melt all of my aluminum. I have cut a 6"x 10" pipe for the crucible .I'm looking to buy the clay and cement maybe this weekend to start poring the foundry in a 26 gal compressor tank . It will be a while though, with all my other projects, Stay tuned. _________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
BerT3 Samba Member
Joined: August 18, 2002 Posts: 1569 Location: Antwerp
Posted: Wed Nov 09, 2011 11:37 pm Post subject: |
vlad01 wrote: |
hmmmm....??
haha jk |
I have 2 NOS sets for mine - I can get you my old ones
BerT3 |
vlad01 Samba Member
Posted: Wed Nov 09, 2011 11:48 pm Post subject: |
BerT3 wrote: |
vlad01 wrote: |
hmmmm....??
haha jk |
BerT3 |
You should copy your NOS ones and repop heavy duty steel ones. |
vlad01 Samba Member
Posted: Thu Nov 10, 2011 4:25 am Post subject: |
The colprit!
wow nos looking under here!
Good condition yeah?
[/url] |
