rking6 Samba Member
Joined: June 08, 2010 Posts: 140 Location: Long Beach Ca.
Posted: Thu Nov 10, 2011 9:09 am Post subject: 30/31 solex |
I have a 1650 single port engine...I changed the carb. from a 28 pict. with a 125 main jet to the 30/31 pict. 125 main jet.. My exhaust pipe/plugs are full of carbon... It is also hard to start after a long drive, (after sitting for 15/20 min ) My question....Is this carb over jetted for my engine ?? Bentley says a 115 main is right ... would a 115 main work with the 30/31 carb ???..
Thanks for your advice.. Bob King 63 EZ bought in 69,, second owner |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51129 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Nov 10, 2011 10:05 am Post subject: |
Have you investigated other factors like fuel pressure, float level and whether the choke opens fully? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2041 Location: M*ssholia
Posted: Thu Nov 10, 2011 10:20 am Post subject: |
I don't think your carb is overjetted at all.
something else is going on.
check the float and float valve
measure your jets, and check your accel pump. |
rking6 Samba Member
Posted: Thu Nov 10, 2011 10:21 am Post subject: 30/31 solex |
Hey thanks for the reply... Its a new carb. not rebuilt....So,, the float is OK.. The fuel pump is original ,, So,, I think its not pumping too much to flood out the carb...I am going to get a 115, and a 120 main today.. Hopefully that will solve the carbon/starting problem.. Thanks again,, Bob 63 EZ camper,, Long Beach,, Ca. |
Posted: Thu Nov 10, 2011 10:38 am Post subject: |
just because the carb is new doesn't mean its setup properly.
ask around... |
rking6 Samba Member
Posted: Thu Nov 10, 2011 10:43 am Post subject: 30/31 solex |
Thanks,, I'LL investigate ... 63 EZ |
rking6 Samba Member
Posted: Thu Nov 10, 2011 12:14 pm Post subject: 30/31 solex |
I put in a 115 Main and a 135 air correction jet... Started right up. Now for a 3 hour tour..Thanks Bob King 63 EZ |
Culito 11010101
Joined: December 07, 2006 Posts: 5865 Location: Columbia Missourah
Posted: Thu Nov 10, 2011 7:16 pm Post subject: Re: 30/31 solex |
rking6 wrote: |
115? That's tiny...my 1600 would lean out with anything less than a 125. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
rking6 Samba Member
Posted: Thu Nov 10, 2011 7:30 pm Post subject: 30/31 solex |
I will try it for a few days and see what my plugs look like. Not planning any long trips until I figure out why so much carbon/rich ,,,.Do you have a single port also ??.. Thanks for your thoughts.. Bob king,, 63 EZ.. |
