Bosch cross reference generator numbers
jtmbee51
jtmbee51 is offline
PostPosted: Fri Nov 11, 2011 12:54 pm    Post subject: Bosch cross reference generator numbers Reply with quote
I've looked thru many posts and can't get the right info. I have a 66 beetle and need a new or rebuilt 6 volt generator. What bosch numbers would work on this car? My existing bosch gen is #LJ/REG180/6/2500L3. Any thread for bosch numbers would be greatly appreciated.
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Fri Nov 11, 2011 2:47 pm    Post subject: Reply with quote
This is from a 1968 Bosch parts book. This listing only goes through 65, but 66 was the same.
And this is a VW listing.
jtmbee51
jtmbee51 is offline
PostPosted: Fri Nov 11, 2011 6:46 pm    Post subject: Reply with quote
THANK YOU VERY MUCH!!
62ItalianRagtop
62ItalianRagtop is offline
PostPosted: Thu Dec 20, 2012 12:04 pm    Post subject: Reply with quote
Hi, I have also a Bosch LJ/REG180/6/2500L3 on my 62.
Which is the vw code for the correct armature ?
113.903.213 or 111.903.213 C ?
Thanks
LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/
The Android
PostPosted: Thu Dec 20, 2012 1:41 pm    Post subject: Reply with quote
Excerpt from the parts manual - the items listed correspond to the numbers in the big 51-71 generators chart posted above.
On that chart, the 2500L3 is item 8.
So that makes the 113 903 213 the match.
FYI - you can find the parts manual here - although some of the generator pages are missing. (my chart above is complete though)
http://oacdp.org/type1part.html
And you can find a cleaner copy, but in German, here:
http://www.vw-classicparts.de/et_katalog1970/index.html
-Andy
62ItalianRagtop
PostPosted: Thu Dec 20, 2012 1:49 pm    Post subject: Reply with quote
Thank you Smile , is this one good in your opinion ?
http://www.thesamba.com/vw/classifieds/detail.php?id=1354163
nlorntson
Crazy VW Lady
nlorntson is offline
PostPosted: Sun Nov 24, 2013 12:00 pm    Post subject: Reply with quote
The missing picture from Glutamondo's first post
